Hilariously cheap car audio amp (Cougar C-300.4)
    Re: Hilariously cheap car audio amp (Cougar C-300.4)
    I'm an idiot!
    But, also, the manufacturer is one too.
    I assumed (rather sensibly or not?) the REMOTE input was a 12V signal to turn on the amplifiers. But NO, it powers the TL494, which powers up the amp chips. I had a 1k in series to limit current (It simply said "to car stereo" so I made a guess), hence the 5.3V supply.
    Now the amp powers up with a 17.5V supply.
    Observations:
    - Amp is now much louder. However, it still has a limitation of around 35W per channel. Better than before, but still not 75W per channel.
    - I can get the amp to draw about 7.2A from a car battery. (Set up with the bench supply as a parallel 4A charger @ 14.4V.) However, the inductor/toroid converter starts saturating and whining, and the output clips at around 15V; it looks like a square wave. I imagine one channel could do 60W, but if you tried two channels, the combined limit would kick in.
    Thermocouple says amp IC hits 70C on tab, FETs run relatively cool at 55C, inductor gets pretty hot (hard to probe but around 65C.) I'm not sure if there is a current limit on this converter as I can't see a sense resistor. Could be using FETs. Each FET gets a different gate drive which looks ugly (will upload pics later.)
    Got annoyed with the sound from it, so using a 4 ohm rheostat for now.
      OK, started tracing through the circuit for the SMPS. Definitely some type of push-pull converter. Feedback is accomplished through a 15V zener diode, so it has regulation. Unfortunately, as the blue trace shows in the below video, it is simply incapable of regulating under any substantial load. I don't even want to think how it would cope with two loaded channels, let alone all four - in fact I did notice when running before with the 1k how badly it coped with four channels, it was very quiet. At peak amplitude, it's not much better than a ~15.5V input, a high side car battery gives 14.4V so it's a lot of expense for no real gain; and with all four channels loaded? Who knows! It could be even worse than just running off the battery, as it is a semi-isolated topology (with shared ground.)
      Wonder how this could be improved - could it simply be the toroid is incapable of supplying the demanded load? Maybe better feedback compensation? Better output capacitance? (currently just a single 2200u 25V "Jyco", probably not even low ESR.)
      http://www.youtube.com/watch?v=Ljy23...ature=youtu.be
        OK, here's the traced SMPS. Couldn't trace the base of Q5. It looks like the top blue traces are just silkscreened on; the actual traces are on the bottom side. Cut one of the blue "traces" and I still get a solid short across it.
          Fixed an error - thought that string of resistors was strange!
          I've noticed this converter seems to mostly operate at around 5% duty cycle, and under full load about 20%. Seems like a bad design to me.
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            • Romania
            #45
            Yes, the top traces are just silkscreened, this is a single sided board.
            A few observations: Are you really sure C4 is 100p and not 1n? With 100p, the frequency would be 733kHz, the TL494 can't even do that. Most likely C4 is 1n and the frequency is 73.3kHz.
            That's a really weird arrangement with the zener there. Also, what Q5 does is really interesting. Assume Q5 is off (open switch), then the divider to the inverting input of the error amp in the 494 is formed by R12 and R16+R17, which gives ~4v Vref. With the transistor on, you get also R4 in parallel with R6+R17, which gives ~2.2v Vref. It appears this converter has a switch that "steps" the output voltage for some reason. You should check the C-E drop of Q5 during operation to see whether it's on or off, if it's on, you should see near zero since the currents involved are very small.
            A working TV? How boring!
              C4 is marked 102. Now I realise it's the first two digits, times 10^multiplier; in other words, 1n. The snubber cap is also wrong, I'll update the schematic shortly. And take some pictures of the waveforms.
              • mikey5791
                Help on car amplifier only one channel works
                by mikey5791
                Hi all forum members,
                Fyi, i have been working on this old model PCT-4082 (4 channel car amplifier). The owner said only one channel is working.
                My initial finding is this amp originally use Toshiba 2SA1943 and 2SC5200 transistor for its output but after opening the top casing i found it used Toshiba A1941 (pnp)and C5198(npn). I desoldered all the 4 pairs transistors and found 1 piece A1941 open(tested "OL" on all legs) and replaced the 1st pair with 2SA1943 and 2SC5200, thats why you can see in the picture it is the bigger size transistor. The other A1941 and C5198 all...
                08-06-2025, 10:36 PM
              • Francesc V.
                Rotel RSX-1056 amplifier. Troubleshoot a noisy channel
                by Francesc V.
                Hi:
                I've realized that one of the channels of this amplifier has no proper sound.
                This is the signal at the speakers output.
                As long as the audio coming in to the amplifier board (blue) looks ok although with some noise due to the wire, I think that there's nothing to look at the preamp section.
                Now, I could start looking at components to see whether I find the guilty one.......but I would rather prefer to ask for advice. Here there is the amp. schema. Which points would you check with the oscilloscope to gather...
                07-15-2025, 01:33 AM
              • Sik_6ty_Sixx
                HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
                by Sik_6ty_Sixx
                So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
                02-18-2025, 05:06 AM
              • eccerr0r
                old X58 triple channel board... memtest86 memory speed?
                by eccerr0r
                Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
                Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
                Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
                06-28-2025, 09:06 AM
              • AudioGuy88
                How to bias a Plinius Odeon 6 channel amplifier
                by AudioGuy88
                I am working on a Plinius Odeon 6 channel amplifier. Not much wrong with it, but I replaced some caps (20 years old) and decided to check the bias current.
                The manual says
                1.
                Code:
                [1] Check the right DC servo is set within its operating window.
                Use VR2 to set TP5 to within –3.0 to +3.0 volts.
                [2] Check the bias current is correct once the amplifier has warmed up, typically 15 minutes.
                Use VR1 to adjust the rail current to 140mA or 52.5mV across any emitter resistor (35mA per
                device).
                I am assuming...
                01-28-2023, 09:30 PM
