Yamaha AX-430
  • JEWilson
    • Sep 2007
    • 369
    • Scotland, United Kingdom
    Yamaha AX-430
    Rec'd this item as damaged.
    The item has been dropped.
    This is a project for the kids bedroom (when fixed).
    The front panel source selection pcb has been broken.
    It is only a single side pcb so, I should be able to repair this.
    I am having issues however with sourcing replacement parts.
    These include;
    1. A number of source selector switches
    2. A balance pot
    There is a loudness knob missing on the front as well
    as the Volume control knob. Both the pots and the
    mech. fixings are in place though.
    I have attached 2 pdfs
    First, is a set of pics of the amp
    Second, is a set of pics with the damaged parts
    FYI, the balance pot is a 250kMN
    The switches appears to Alps SPEC type but since
    this amp is circa 1989, I cannot (immediately)
    appear to find the relevant or correct model.
    The service manual states these as SLR-34URC3H
    Any views?
  • Longbow
    • Jun 2011
    • 623
    Re: Yamaha AX-430
    The photos do not definitively show that either the pot or the selector switches are damaged. The first step is to repair the broken pcb. If possible, remove parts directly on the fault line. Super glue works wonders on this pc material. Make certain the pieces make a good fit first. Apply superglue, press together, and then spray lightly with super glue accelerator.
    Next repair the broken traces with #30 insulated wire. It is best to connect end points, rather than bridging the broken traces. Photos of the damage to the switch and pot would help.
    Is it plugged in?
    • JEWilson
      • Sep 2007
      • 369
      Re: Yamaha AX-430
      Hi
      Thx for responding
      Ok.
      The picture of the pot - second pdf only illustrates
      the type of pot and mech. footprint I require.
      Trust me, the damaged pot is destroyed beyond repair.
      But where can I get the correct pot?
      The leftmost three switches in the second pdf are damaged
      The plastic blue material is the internals of each switch
      A normal switch, black colour can be seen to the right
      I know these switches are broken, they do no mechanically
      work correctly. I have tried them
      Thanks for the suggestion with superglue and accelerator
      Where can I get the latter?
      Cheers
      • 999999999
        • Sep 2006
        • 774
        Re: Yamaha AX-430
        Are you sure you sent the correct 2nd PDF? I'm not seeing any switches in that pic.
        If you can't find the POT, pick one electrically equivalent in function. Fortunately it looks to be panel mount so the replacement merely needs to be same dimensions or shorter body so it will fit in the space between the circuit board and the front panel, then you can use wire to connect the pins to the traces.
        If you simply cannot find one short enough, then there is the fun part. You drill a hole through the entire circuit board big enough to slip the new pot through and rejoin any component traces removed by the drilled hole with jumper wire.
        Superglue accelerator isn't really necessary, it just speeds up the process. You can instead wait for the glue to dry. Considering the potential stresses on the PCB from pressing buttons, I would also fortify the area where the crack was with some epoxy overlapping the joint by about a centimeter in each direction. Just make sure that doesn't get in the way of remounting the circuit board back in the amp.
        Even better would be to rough up the area slightly with sandpaper so the epoxy adheres better, or at least wipe it thoroughly with alcohol first.
        • JEWilson
          • Sep 2007
          • 369
          Re: Yamaha AX-430
          Hi
          2nd and 3rd pics on images0030.pdf show the switches
          • 999999999
            • Sep 2006
            • 774
            Re: Yamaha AX-430
            It looks like a tedious repair. I don't have any drop in replacement suggestions, but I could be a devil's advocate and suggest that if you have a will, you can spend more time than it's worth and have it working.
            I don't know the clearances though, building up a replacement circuit can depend on how crammed and jammed the board is relative to things around it. When push comes to shove (if you were on the space shuttle or a remote island) there's no end to how many standoffs and aux boards you could screw in to make it work, but obviously not being in front of it or being able to determine your will, I can only wait and help with your ideas.
            • ClockChip
              Advice sought - Selector switch knob repair
              by ClockChip
              Hello Everyone,
              I am seeking to repair a knob on an old (circa 1971) Panasonic clock radio (a model RC-6900). The good news is that I have the small, easily lost knob. The bad news is that the knob has come off a slotted post and I need to re-attach it in such a way that I won't have to worry about it coming loose again.
              Here is a picture of the bare slotted post (if I have the term right) the knob should be attached to:
              As you can see, this is an Old School selector switch, which means it's pretty stiff. Put another way: the knob has to fit...
              07-20-2024, 04:52 PM
            • sretchko
              Sony Receiver STR-4800SD L/R Balance
              by sretchko
              Hey fellow solder fume lovers, I have a Vintage Sony Receiver STR-4800 SD that has me stumped.
              The Balance Pot has to be set at about 30 degrees (11 o'clock) to the left for the output to be balanced (see photo). I'm using an oscope, sig gen 1kHz sine, 8 ohm dummy load).
              When output is balanced (11 o'clock left) both channels clip at about 19 vac / 45 watts RMS, Amp is rated at 35 watts so I know the amp modules are good. Square wave also looks good when turning bass & treble pots and is in phase.
              I pulled the balance pot, (Dual 10K MN Taper) cleaned with...
              Badcaps Electronics Repair Forum & Schematic Search
              04-17-2024, 06:02 AM
            • sanalelevenstar
              Yamaha RX-V485 Wn9711 Update
              by sanalelevenstar
              Help Needed: Yamaha RX-V485 Network Issue After Firmware Update (WN9711 Error)
              I'm facing an issue with my Yamaha RX-V485 receiver. During a firmware update, the process failed, and now the USB, Bluetooth, and network functionalities are not working. Occasionally, the receiver displays the error code WN9711.
              I came across Yamaha Technical Bulletin No. 0103, which describes a similar issue for models like the RX-V4A, RX-V6A, and RX-A2A. According to the bulletin, the issue can be resolved by shorting soldering points (e.g., J260 for RX-V4A or...
              12-04-2024, 04:32 AM
            • XxMicroSoldering
              ASUS Rog Strix G17-712LV Laptop Liquid damaged
              by XxMicroSoldering
              Hello Guys
              I have a ASUS Rog strix laptop that I bought recently to fix and the previous owner spilled water on it . He brought it into a repair shop for them to check it out and instead of fixing it they damaged the battery connector of the laptop ! Other than that they damaged damaged nothing . But since the liquid damage the laptop only turns on and the keyboard lights up and then immediately turns off. I really want to repair this laptop and I also have experience in repairing phones etc and laptops and a bit of soldering but the diagnosing part is where I need help with and...
              10-17-2024, 10:45 AM
            • sanalelevenstar
              Yamaha RX-V485 receiver. After encountering a "version error"
              by sanalelevenstar
              I'm having trouble with my Yamaha RX-V485 receiver. After encountering a "version error", the USB, Bluetooth, and network functions have stopped working, making it impossible to perform a firmware update through normal methods.
              After doing some research on forums, I found that earlier Yamaha models with similar issues (like the internal error message) could be fixed by shorting or soldering specific pads—such as R896—and then powering on the unit to enter a service/boot mode that displays the model info and allows recovery.
              I managed to find the service...
              09-10-2025, 01:54 AM
