DTT2500 Subwofer not working? Dry Joint?
  • newtoCaps101
    • Jul 2011
    • 93
    Hi Guys, So from yesterday I am trying to fix my old and reliable Creative Cambridge Sound Works DTT2500. Recently it developed a Hum that keeps growing as I increase the master volume. And the subwofer also isn't working. The Hum I think is being caused by a bad cap inside its Brick Power Adapter(?) which I plan to replace. But I cant seem t figure out why the sub isn't working.
    I think its actually the AMP that is not sending the signal to the sub, because I plugged in a speaker where the sub would be and still no sound. Could it be a dry joint? or something else I should be looking for? It's dual PCB design one on the top and one on the bottom.
    What do you think? anyway to fix this? really can't spend $200 on some good speakers right now.
    Sorry about the bad picture quality.
  • Toasty
    • Jul 2007
    • 4171
    Re: DTT2500 Subwofer not working? Dry Joint?
    Get the boards separated and get a look at, and pics of, the lower one. Note where the sub output jack traces go to, and investigate the output chip/transistors and any power resistors in that area.
    The hum could be from the power pack, you're right. But getting the sub output fixed may be the answer. I've seen blown amps in a channel cause feedback/hum to the other outputs before.
    veritas odium parit
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      The hum is 100% from the power pack. Replace that bulged capacitor then worry about everything else.
      A working TV? How boring!
      • newtoCaps101
        • Jul 2011
        • 93
        Okay So I just replaced the Cap on the power pack. The hum is 80 - 90% gone. I can stll feel a little bit of it when I have the speaker close to my ear. But the Subwofer, I wasn't able to figure anything out, I removed both PCB's, they both look to be in good condition, no blown caps or transistors from the looks of it.
        However I didnt find any chips other than some caps and transistors on the first PCB (big one at the bottom). The top small PCB seems to have a chip or two and some shielding. But being the noob that I am I wasn't able to remove the RF/ EMI shielding, they are pretty nastily soldered! I cant seem to find a way to de solder it and take it out without using my dremel to cut it off or something.
        Here are some pics. Looks to be okay, no?
        the sub output lined in red. But after reading the PCB, I think the top PCB is responsible for all the outputs and processing including the sub as the audio link connector leads to there.
        Top PCB with RF/ EMI Shield
        cant remove the shield
        • Toasty
          • Jul 2007
          • 4171
          The middle one (which you haven't shown) on the aluminum heatsink is the sub amp. Please photo and report the chip number.
          Leave the top board alone.
          veritas odium parit
          • newtoCaps101
            • Jul 2011
            • 93
            Do you mean this one?
            I actually thought these were some kind of "Mosfet" chips that needed to be cooled. Sorry for the bad quality but should be readable.
            I also found this topic, if you scroll down to post #8. http://www.overclockers.com/forums/s...d.php?t=508585
            its a guy who had similar problems with his DTT3500 (mine is DTT2500) and he somehow opened the Faraday cage / RF/EMI Shield and Exposed the ZORAN chip and replaced some caps there. So A bit confused.
            • Toasty
              • Jul 2007
              • 4171
              TDA7360 Datasheet:
              Unit has protection for "noisy" power supplies (pin 7) and it may be staying off due to that. Find the rest of the hum in either the power supply adapter(only 1 cap?) or this board. I'd start with the larger ones down the end (near fuse) as they might be across the incoming power from the adapter.
              Then I would compare voltages between the 3 chips to the datasheet as a starting point.
              Per Hansson from the other thread is a member here also. If he doesn't see this and pop in, I'd send him a PM.
              That shield comes off with a sufficient soldering iron and some good wick.
              veritas odium parit
              • newtoCaps101
                • Jul 2011
                • 93
                Thanks Toasty! So that could be it, the Power Adapter preventing the sub from working? Okay, let me try to replace that Cap again in the power supply. (yea only 1 big 6800uf 25v cap - look here https://www.badcaps.net/forum/showthread.php?t=16001)
                Until a new order comes around. Where do you think I can salvage a capacitor of around 6800 uf / 25V or more? A Radio? or any other electronics I should look into?
                oh and I'm no good with the soldering wick. Any tips on getting that shield out? And do I even need to take the shield out now?
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  Let the shield be for now. Use a larger iron and a desoldering pump if you really want to see what's under it. Do you have a multimeter handy? You can make some measurements on the amplifier ICs to see whether they are working, in standby mode, or broken.
                  • newtoCaps101
                    • Jul 2011
                    • 93
                    I have a digital multimeter, but I dont know how to use it. no kidding ..ya i know.
                    its one of these stuff, I was going to ask how to use it here eventually but....
                    Since I dont have a second 6800uF 25V cap. Would it be possible for me to maybe rig multiple smaller 2200uf or more caps to make up for that one big cap? just so that I can test it out for now you know.
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      Yes you can use multiple small 25v caps. As for the multimeter, ask and you shall receive: http://www.ladyada.net/learn/multimeter/
                      • newtoCaps101
                        • Jul 2011
                        • 93
                        okay, most of my caps were 10v 2200uf, so let me order another 25v 6800uf cap online. its sunday here, so should take a couple of days.
                        I'll be baaak (says with a strong austrian accent)
                        • newtoCaps101
                          • Jul 2011
                          • 93
                          I'm Back! Just got my new Rubycon Cap and replaced the old one with it. taada! Now all the humming looks to be gone and my speakers and sub are working!
                          Thank you!
                          Now The only problem left is the sound / volume control knob. ( i know, knob noob_ ) When I move it to turn up or lower the volume I get some crackling noises. Sometimes It causes my subwofer to go out of sync / stop working.
                          Anyway I can repair the volume control knob so it doesn't make noise when moving it or interfere with the subwofer or something? thanks again!
                          • Th3_uN1Qu3
                            Believe in
                            • Jul 2010
                            • 6031
                            Take off the knob, spray some contact cleaner inside the potentiometer, and it should work.
                            • newtoCaps101
                              • Jul 2011
                              • 93
                              Thanks. Actually right after making my earlier post I did some google and figured something out. I used some mineral oil (since I dont have any contact cleaner and then moved the knobs a lot of times. It fixed the issues. So I am very happy
                              One last thing I noticed was a very low White noise, No hum, just a low "white noise" which gets higher as I increase the volume. when volume is in 50 - 60% I can hear it if I am close to the satellite speakers. the noise goes away as soon as I unplug the audio source. I was suspecting it was some issue with the audio source being a front panel audio port powered by onboard audio that I was using to test the thing?
                              • Th3_uN1Qu3
                                Believe in
                                • Jul 2010
                                • 6031
                                Yes, front panel ports are slightly noisier than the ones mounted on the rear, directly on the board. It could just be the soundcard though. Nothing to worry about, if it bothers you then it's time to get a better soundcard.
                                • newtoCaps101
                                  • Jul 2011
                                  • 93
                                  Yea, I figured the same, its probably due to the onboard audio and front ports I am using to test it lol. But I think I have a good sound card (onboard) though on the PC I want to use it on so hopefully it will be just fine.
                                  Thanks for all the help uN1Qu3
                                  • newtoCaps101
                                    • Jul 2011
                                    • 93
                                    hey uN1Qu3, Toasty; after months of service the thing is starting to act strange again.
                                    I started a new topic: https://www.badcaps.net/forum/showthread.php?t=18833
                                    Some help please guys?
                                    • anthonyd
                                      • Feb 2017
                                      My unit works fine except for occasional intermittent drop in audio about 50-70%, very annoying. The signal from computer doesn't drop but both satellites and woofer drop the same. Tapping board, signal input plug 1/8" not the cause. I hand soldered the complete board and problem still there, I use a different PS 3amp 12volt and tried different ones. It seems like it would be a cold solder joint but that's been ruled out, if it was the driver IC it would not occur on both satellite and woofer. Perhaps in the input preamp stage? Anyone with that problem?? Also, ruled out the potentiometer control. Thanks for any help.
                                      • TyMercer
                                        Can I flash a working BIOS from one computer to another of the same make, model, etc?
                                        by TyMercer
                                        Apologies if this is the wrong forum, but I'm not looking for a specific BIOS file, I'm trying to understand how one makes a clean BIOS file. So here's the background. I have 2 HP EliteDesk 800 g2 mini 35w pcs. One is working fine; the other doesn't have display out or working USB's nor does it have any flashing error lights. The CPU does get worm enough to cause the fan to spin up, so I think it's posting, but I just don't know. I had it working at one point but trouble started when I tried to put in a drive caddy that had a cooling fan on it. I thought it would be compatible but wasn't...
                                        Yesterday, 09:39 PM
                                      • MMH3
                                        Dell Optiplex 5050 SFF - strange behavior and service_mode jumper not working anymore
                                        by MMH3
                                        i have many 5050sff. all of them, and how i experienced over many years for all about 250 DELLs goin through my hands, are fully flashable and can be serviced in any way when the service_mode jumper is set.
                                        Never ever i experienced problems with that.
                                        Now i have one 5050sff machine, where this jumper isnt working at all.
                                        I do not get the normal messge that the jumper is set when booting and a short test with FPT just confirms this. Everything is locked -->> EVEN for reading !?
                                        The history of the machine is that i used it in my office...
                                        03-23-2025, 09:28 PM
                                      • DynaxSC
                                        GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
                                        by DynaxSC
                                        I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
                                        There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
                                        The board is generally working now, all PCIe ports are working, Windows installs normally.
                                        However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
                                        The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
                                        03-10-2025, 12:27 PM
                                      • obelix24
                                        Macbook Air 2020 (a2179) - touch id not working
                                        by obelix24
                                        Hi i have one Macbook Air 2020 where touch ID is not working (it's not scanning fingerprints). Touch ID was working before, there is no error message during scanning fingerprint it's just not scanning on screen you can see only fingerprint but there are no red updates as when it's working. Power button is working fine.
                                        I've checked boardview and also schematics but i'm not able to find anything related to TouchID ... i have similar issue on a2338 where there was problem with PP3V0_TOUCHID​ and after replacing UT610 it was working but here i'm not able to find anything related to...
                                        02-09-2025, 12:57 PM
                                      • hopkok
                                        Lenovo Legion 16ITHg6 NM-D721, keyboard not working, LEDs too
                                        by hopkok
                                        Hi masters, I need your help.
                                        I am working on Lenovo Legion 16ITHg6
                                        Motherboard number NM-D721, no BV, no schematic but I am attaching very closes ones.
                                        INPORTANT: My motherboard version is with IT8258 IC, that is controlling keyboard and RGB LEDs.
                                        My problem is on UI142, +3VALW_AG is not stable, floating from 0V to 3,3V.
                                        AGKB_PWR_EN_N signal is floating too (that is why+3VALW_AG not stable).
                                        Power LED is not working as well, power button working well.
                                        UI26 ??? is there any firmware too? Powered by +3VALW_AG.
                                        Motherboard...
                                        05-04-2025, 09:35 AM
