Realistic Chronomatic-223 - dead left channel
  • lti
    • May 2011
    • 2548
    As the title says, the left channel does not work in this clock radio. When adjusting the volume, popping noises can be heard from the left channel. At all other times, the left channel is completely silent. Also, the right channel plays constantly and only becomes slightly quieter when the balance is turned all the way to the left. Inside, there are two TBA820M amplifier ICs. The left speaker works when connected to another amplifier.
    What are some possible failure points? This problem might have existed since the clock radio was new. I was told that it never worked properly.
  • lti
    • May 2011
    • 2548
    Re: Realistic Chronomatic-223 - dead left channel
    I was able to get the left channel working for a few seconds. The volume control is either broken or very dirty. The balance control is dirty.
    There are a lot of bad solder joints.
    • lti
      • May 2011
      • 2548
      I got it to work by cleaning the volume and balance controls. I still need to resolder some points. I might work on that tomorrow.
      • lti
        • May 2011
        • 2548
        I resoldered the three points pictured above and cleaned the tone control and the headphone jack. The radio section now works properly.
        The Sleep button doesn't seem to work, but I can't get the button board out of the case. The company that made this clock radio for Radio Shack decided to coat the screw heads in some kind of adhesive. Some screws can't be removed.
        Also, both the alarm and the radio play at the same time in Alarm mode. If Auto mode is selected, only the radio plays as the alarm.
        • Sik_6ty_Sixx
          HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
          by Sik_6ty_Sixx
          So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
          02-18-2025, 05:06 AM
        • karatzdi
          Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
          by karatzdi
          I know some might say... just buy another one. Sell it as parts..!
          So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
          Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
          Spent some time downloading the Service...
          06-11-2024, 08:38 AM
        • HelpMeRepair
          Yamaha RX-A3010 left channel no signal
          by HelpMeRepair
          Hi everyone , I have a rx-A3010 that all alllll the channel working except of Front left , if someone can lead me on what to begin wit it would be very helpful
          what I did so far ,
          factory reset
          test all other channel
          tone test
          dissasemble and look , visual inspection witout full dissasembly
          looked at all the mosfet for temperature to see if they eas operating
          scratch my head couple of time
          thanks in advance all help is appreciated , service manual are welcome too ! =)...
          11-14-2024, 02:48 PM
        • eccerr0r
          old X58 triple channel board... memtest86 memory speed?
          by eccerr0r
          Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
          Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
          Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
          06-28-2025, 09:06 AM
        • xfreakx
          Yamaha XP7000 Crackling in left channel
          by xfreakx
          Hi guys,
          I have a problem with the power amplifier Yamaha XP700, I hope someone can help or point me in a direction.
          The amp started occasionally to crackle in the left channel which in a short time period got more frequent and after a while the crackling occurred instantly on power on.
          While checking for loose connections the amp's protection kicked in and turned the amp off. From then the protection turned the amp off in between 1 - 5 seconds after power on.
          I switched the mono blocks for a test to make sure the error is in the block itself...
          06-29-2023, 05:30 AM
