Well gang, here goes my first thread.
I have a pair of Klipsch ProMedia Ultra 2.0 speaker hooked to my laptop. Only bout 4 yo. I have moved several times these past two years. The puter is on a deep table with the speaker less than three feet apart and w/ the left sp near my seat.
Just this last week I came to realize that the right sp wasn't working. I checked all connections, (aber es war kaputt). I opened the right speaker and exposed the T amp there. One of the 470mfd caps had
The caps that blew for Panasonic is a higher voltage but I see no prob since the size is ok. If I do replace all the caps I thought to bump the voltage on the others as well since one value is only available at a higher voltage. The other concern in a question of what solder was used in the assembly. I use 63/37 out of habit. The boards are separated and the bad caps removed. I have been away from the bench for a number of years and the hands have turned to crap. I sure miss the Pace solder sucker used on my last job. Any and all comments gratefully accepted
