Carver CT-Seven
  • kaboom
    "Oh, Grouchy!"
    • Jan 2011
    • 2507
    Carver CT-Seven
    Looks like the TC9152P has gone leaky. Between 6 and 14V with high source impedance present at the two output pins. As it's a bilateral switch, this also backfeeds into the sources and phono stage. The 'tuner' input does not couple signal through at all. I've got audio from the tuner board when signal tracing.
    This DC leakage gets thru the coupling caps for opamps IC452/453, since they are the 'wrong' way around. With DC offset and their bias upset, the audio is rather distorted. Feeding a source into the tape inputs bypasses the TC9152 and the output signal is fine.
    But wait, there's more! One or more of the opamps in the big bank for the 'Sonic Holography' may also be leaky. When engaging into the signal path, there is a pop in both channels. Immediately, right goes dead and left still has signal, but no effects can be heard whatsoever. This backs up my guess of bad opamps...
    PDFs too big, so links are here:
    -Paul
    "pokemon go... to hell!"
    EOL it...
    All style and no substance.
    guilty,guilty,guilty,guilty!
    guilty of being cheap-made!
  • kaboom
    "Oh, Grouchy!"
    • Jan 2011
    • 2507
    Re: Carver CT-Seven
    I'm going to use a bank of 5 DPDT signal relays and 5 PN2222s as coil drivers. Five 4148s will be used as back-EMF suppression. The owner may not want the Sonic Hologram fixed, but I've got something in mind for the opamps.
    Replying to your own post- what a way to blow it.
    EOL it...
    • kaboom
      "Oh, Grouchy!"
      • Jan 2011
      • 2507
      Re: Carver CT-Seven
      Gonna try some JRC/NJR NJM4580s. Even though they're 8-pin, it won't be a problem.
      EOL it...
      • kaboom
        "Oh, Grouchy!"
        • Jan 2011
        • 2507
        Re: Carver CT-Seven
        All done!
        I just now posted- this was completed a few days ago, after all the parts came.
        It turned out that another analog switch was leaky, from the -15V supply to GND, so another relay replaced it.
        The bank of 5 are the input switches and the one by itself is the 20dB 'mute' attenuator.
        The caps in the power supply were replaced with 105 degree units. The ones on the input/preamp/hologram board were also replaced.
        I also was asked to look over the M-500t power amp. I vacuumed out the dust and resoldered some connections on a few power resistors. As well as make sure heatsink/chassis screws/etc were tight. This is a 'rail-switching' amp- up until a certain output level, the rails run at +/-40V. When more voltage is required, a comparator drives driver transistors that drive those four big (commutating) ones right below the power trans. This instantaneously brings the rails up to ~+/-74V. Some fast diodes prevent the high voltage from backfeeding.
        By way of C503 and C504 in the power amp, chassis 'ground' floats at ~60V, unless there's a true path to ground. My guess is that the power amp was left plugged in and connected to the CT-7 via the audio cable. Possibly a grounded source was unplugged from the CT-7. This would cause the following:
        Grounded source connected, both shell and tip of RCA plug- all is well
        Beginning to remove RCA plug, shell breaks but tip still made- BAD! Now the leakage, no longer 'bypassed' by the shell of the RCA, flows from ground into the ground pin of the 'input select' analog switch. It then backfeeds through the IC (kills it), out of the signal pin(s) and up the center conductor of the audio cable.
        Only a guess though...
        Enjoy the pix, and those TB-34 output transistors!
        -Paul
        EOL it...
        • AstutePauciloquent
          Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
          by AstutePauciloquent
          Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
          I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
          11-23-2023, 11:02 PM
        • howardc64
          Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
          by howardc64
          Failure Symptom
          No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
          Where is the short?
          Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
          Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
          05-27-2025, 02:56 PM
        • JayPoorJay
          Converting +/- 5v to a Usable Hz Signal
          by JayPoorJay
          Good morning.
          I have posted here before and have gotten AMAZING advise (thank you!). I'm back for more. This BCaps Sub Forum is so well attended I thought I would post here.
          This question is for an automotive application but has to do with what are essentially electrical questions and problem solving... If this is inappropriate I get it. Feel free to delete it or move the question.
          The V 12 Jaguar XJS is notorious for overheating in stop and go traffic in hot weather... Y'all will be potentially helpinh a LOT of people. The solutions and directions...
          08-07-2022, 08:35 AM
        • Xristakis795
          samsung ue40d503problem reboot logo only when i have input signal from hdmi and tuner
          by Xristakis795
          hi to all
          i have the above model ue40d5003
          the damage was definitely caused in my case by a generator that I installed burned the protection at power supply of tv and created the following problem
          when I have not connected the antenna, any input source lights up normally i can insert on the menu and the tv doesnt reboot
          when I connect,the antenna or hdmi signal however, when it goes to show an image, the image appears momentarily and then restarts appears the logo and the same again.the lights of standby blinking continously
          Can you tell me from your experience...
          02-09-2023, 03:17 PM
        • Scruit
          What is a normal composite signal range for a C64?
          by Scruit
          Hello all,
          Working on my first C64 / Breadbin / 250407. Purchased as non-working. Getting black screen.
          More detail below, but for those that want to get right to the question.... Here are a few waveforms comparing the Pin15 output on the VIC chip (luma/sync) to the pin 4 on the AV socket (composite signal).
          https://imgur.com/gallery/PpqcqPY
          My question is: Is the composite waveform range of 0.1v-1v too low for a c64?
          More detail:
          Symptoms are that that I get...
          04-28-2022, 05:33 AM
