I have a bid on a KLH CD Recorder and so far i'm the highest bidder for a total of $1.04 Free Shipping NO SALES TAX! Don't know if it works! but I did contact the seller. What Electronics have you got cheap off of ebay?
This could be one lucky day coming up
Tags: None
Re: This could be one lucky day coming up
Nothing that cheap. But got a nice pair of refurb Sennheiser wireless headphones for my mom, who has trouble hearing her TV. $139.00 in the stores. Ebay was $60.00 buy it now, offered $50.00 got 'em.
My wife uses a pair late at night, and we've always been impressed with the sound. So to me, good deal.36 Monitors, 3 TVs, 4 Laptops, 1 motherboard, 1 Printer, 1 iMac, 2 hard drive docks and one IP Phone repaired so far.... -
How do you connect earphones to a TV where there's no headphone jack?Comment
some have them by default... and they make rca to 3.5mm female adapters...sigpic
(Insert witty quote here)Comment
I have a sharp television. I hooked up the headphones to the audio out ports, I wonder if I have to disable the sound from the menu to get them to work...
If that's the case, I think I can attach external speakers with a headphone port so that there would be both general and headphone audio at the same time. If the headphones were amplified, the volume could be kept relatively low while the headphones could be turned higher.
If this doesn't work, I was thinking about opening up the TV and "tapping in" to the speaker connectors and routing a headphone port through the plastic. It's not pretty, but will this work as a last resort?Comment
by sam_sam_samWhen I originally started with my DVR recorder it had 4 individual switching switching power supply’s that were sh*t so I bought a 7 amp 12 volt switching power supply and modified the output plug and put a four output power supply cable to match the input power supply cable inputs
Which worked for over 14 years until a few days ago when the cameras went dark no picture anymore well it turns out now the switching power supply has stopped working altogether now so I have to troubleshoot what has happened to this power supply more later on today what I found
This... -
by Ady2017I have recently inherited a Panasonic DMR-EZ48V DVD/VHS combo after my dad died. I tried to record a DVD with it and it worked for about 5 mins before it suddenly stopped. Since then it just keeps making a noise like it is trying to read a disk but then gives a 'no read' error message. I have tried numerous DVD's and it is definitely the recorder that is the problem. I did find a youtube video showing that capacitors on the power board were a common problem on these and so I went ahead and replaced the capacitors but it is still doing the same thing. I now think that it could be the laser that...
by sam_sam_samThese cheap non brand capacitors at it again
Last night we had a power outage [ long drawn out trying three to come back up before going out completely ] and when I went to turn the DVR camera recorder back today no go 3 bad capacitors ( one capacitor no ESR reading on DVR board the other 3 capacitor on the power supply board over 40 ohm this is not a misprint ) on the external switching power supply and one capacitor on the DVR camera recorder board where the power supply that goes to the hard drive disk is
Well at least I have the cameras back on line I to try the... -
by UNITRAXHitachi TRK 8010k
Is it possible to have an aux input in place of the radio on the am band range? When connecting to the tape recorder, I have additional tape noise. There is an integrated circuit HA11251 in the schematic. Which pin is the am radio output on?
Radio tape recorder diagrams and HA11251 datasheet included...-
by KartowlHi, my TV image started showing those lines and the image faded away, but sound is still coming from it, what could be the cause and is it fixable? I thought it could be the tcon board but I red on the internet that it could be a failing panel
... - Loading...
