Blown Amp/Mixer
  • Trinite
    • 143
    #41
    Re: Blown Amp/Mixer
    Here is a diagram of the circuit that provides the +60V to the phantom power reg.
    Note: Ground reference is provided by the transformer center tap and is not referenced to the -20VDC output.
    • Trinite
      • 143
      #42
      Re: Blown Amp/Mixer
      Been busy lately, but finally got around to fixing this unit. Replaced 2 op-amps, 2 burned out resistors, added a bleed resistor on the high voltage section and added a ground-lift switch.
      Ended up learning quite a bit about audio systems in the process as well.
      • Agent24
        I see dead caps
        • Oct 2007
        • 4953
        • New Zealand
        #43
        Re: Blown Amp/Mixer
        Nice job!
        -David VanHorn
        • Trinite
          • 143
          #44
          Re: Blown Amp/Mixer
          Also replaced all the non-name caps in the amp section, which got rid of a lot of the AC hum, along with grounding it. Actually sounds quite decent now. In any case, it's a much nicer unit than when I first started.
          Just for laughs, I uploaded a pic of the warning label to show the quality of the "Engrish" used, which also implies the original build quality of the unit.
          • hardwareguy
            • Jun 2006
            • 405
            Re: Blown Amp/Mixer
            Those crooked heatsinks need to be set so they cannot touch...those are NOT isolated TO220 devices on those heatsinks. You have a short circuit hazard.
            • Trinite
              • 143
              #46
              Re: Blown Amp/Mixer
              I checked. Both heatsinks are grounded, so them touching is not an issue. The 7815 and 7812 regs each are grounded through the center leg, so their contact with the heatsink again poses no issue. Otherwise, I would have straightened them out; but in this case, the work was unnecessary and a posed a risk of PCB damage, so I left them as is.
              • Agent24
                I see dead caps
                • Oct 2007
                • 4953
                • New Zealand
                #47
                Re: Blown Amp/Mixer
                I had a feeling that would probably be the case...
                -David VanHorn
                  Acer Predator PT315-51-7815 Notebook Specification for Upgrade or Repair
                  This specification for the Acer Predator PT315-51-7815 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the PT315-51-7815 boardview and PT315-51-7815 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                  09-06-2024, 11:44 AM
                  Acer Predator PH317-51-7815+Helmet VR Notebook Helios 300 Specification for Upgrade or Repair
                  This specification for the Acer Predator PH317-51-7815+Helmet VR Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the PH317-51-7815+Helmet VR boardview and PH317-51-7815+Helmet VR schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                  09-06-2024, 06:45 AM
                • cmlewis89
                  LG 47LB5DF blown power supply board
                  by cmlewis89
                  Hi folks,
                  I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
                  09-03-2024, 07:50 PM
                • Bektronics
                  Schematic Digital Audio mixer RCF type M18
                  by Bektronics
                  Hello dear audio friends.
                  I am feverishly looking for the full electronic schematic (not a block diagram) of the RCF type M18 digital audio mixer.
                  The device does not make a WIFI connection with my Apple tablet and yet I have already installed the recent app on it.
                  I suspect that there is a problem in the mixer itself with the WIFI card and of course I would like to see this on an extensive schedule before opening the device.
                  Thanks in advance if anyone can help me with this schematic.
                  Of course, all information about this digital mixer and possibly references...
                  07-24-2023, 06:40 AM
                • drscoot
                  HP X360 convertible battery blown fuse error, not charging
                  by drscoot
                  HP Modelnumber: 14-dh0061nb​
                  This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
                  The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
                  I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
                  And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
                  All these 3 batteries are charging...
                  12-15-2023, 05:54 AM
