Blown Amp/Mixer
  • Trinite
    • 143
    Blown Amp/Mixer
    I have received a GVDaudio Power Mixer BM8800 that has a problem with repeatedly blowing fuses. Upon opening it, I found a voltage regulator that was blown (KA7815). There is also a capacitor that is poorly soldered and is loose (marked in image).
    I looked around for a replacement VR, but as I have little experience with silicon, I would like a second opinion on my selection: http://search.digikey.com/scripts/Dk...296-13999-5-ND
    All of the capacitors are Rubycon/Nichicon/Chemicon, save a few. The two large input capacitors are 4700uF 63V "HD C.E.", which filter the 48V input. There are two 2200uF 35V "NOBBY", which filter the 18V input. Other than that, there are three 1000uF 25V "XINGLONG" capacitors and a 47uF 63V "NOBLE" capacitor. Any of these need to be replaced while I am at it?
    The unit is powered by a massive toroidal transformer, if anyone wants to see how big these things get compared to a SMPS.
  • Scenic
    o.O
    • Sep 2007
    • 2642
    Re: Blown Amp/Mixer
    ouch.. never seen that happen to a good old 78xx linear voltage regulator
    especially since those are supposed to have a thermal protection built in.
    I'd replace the noname craps while i'm at it. i mean.. you're already in there.. so why not..
    looks like it's pretty crappy overall build quality though.. :/
    oh and don't forget to check the diode in front of the toasty 7815
    The 7815 from the digikey link should be fine. it's actually capable of 1.5amp output instead of 1amp of the toasty one, so it should run a bit cooler.. and perhaps not burn up
    • Trinite
      • 143
      Re: Blown Amp/Mixer
      I'm baffled myself as to what could have killed it. Power surge perhaps?
      I assume the primaries on the 40V are fine, replacements for those are expensive anyway. I can replace the primaries on the 18V, however, if need be.
      I'll go ahead and replace the rest. I'm also considering adding a cap before the VR (lack of filtering may have done it in, possibly).
      Also, as I have never worked with audio equipment like this, what aspects would you say would make it a crappy build? Just some knowledge I can use for future reference.
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        • Romania
        Re: Blown Amp/Mixer
        Most likely the reg is taken from the main power supply. Equipment used in live events tends to see a lot of dirty power, from generators and such. Probably the AC supply was too high, and the manufacturer's failure to take into account such tolerances, made the rails go over the input voltage capability of the regulator, which is 40 volts IIRC.
        What is its rated power output? It looks like run-of-the-mill Chinese equipment.
        A working TV? How boring!
        • Trinite
          • 143
          Re: Blown Amp/Mixer
          The unit is rated for 250W per speaker, for a total of four (2 left speaker outputs, 2 right outputs). So an assumed total of 1000W max power.
          I looked at the transistors responsible for output (see attached image) and there are two Toshiba 2SC5200 NPN transistors and two 2SA1943 PNP transistors. Each is rated for 15A, so at 40V that would give a maximum of 600W per channel. So looks good at least on the transistor side. Seems the rectifier bridge (GBJ25J) can handle 25A @ 100C, so that just makes 1000W at 40V. Looks like they're really pushing it on rectification. So probably an overrated unit.
          I could attach an MOV to the input, if you think that would improve unit durability.
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            • Romania
            Re: Blown Amp/Mixer
            And they're pushing it on regulator input voltage as well. If the reg is indeed fed from the main rail, there is zero headroom. Check that before you replace it.
            • Scenic
              o.O
              • Sep 2007
              • 2642
              Re: Blown Amp/Mixer
              that, plus basically no cooling.. wtf?
              • Trinite
                • 143
                Re: Blown Amp/Mixer
                The main transformer has two windings. One for the 40V output and another for 18V output. The VR draws from the 18V rail, so it is within spec. It has no heatsink, but there are 3 other VRs that do, so assume the one that blew provided power to a relatively light load (or should at least, anyway).
                • Wizard
                  • Mar 2008
                  • 2296
                  Re: Blown Amp/Mixer
                  And really poorly designed!
                  All the regulators should be on one big plate or finned heatsink (insulated as necessary) and arranged properly. Not willy nilly. And that 4 transistors does not looks like can do 250W per speaker. Not at all. Regulator tend to die by voltage falling off or shorted, and should had fuse on output or 1 ohm resistor just in case. Exploded regulator means output might had shorted out.
                  FYI: good linear regulators have thermal overload built in, this one is fairchild brand.
                  Good one tend to have 8 transistors and two even four transformers for that claimed wattage much and 1KW from that transformer. Impossible.
                  PS: be really wary if the amp transistors are true copy, there were plenty of fakes out there on that particular part numbers were popular ones to copy using really underrated semiconductors. Make sure you get these from good supplier.
                  Cheers, Wizard
                  • Trinite
                    • 143
                    Re: Blown Amp/Mixer
                    Couldn't find any specs on the transformer, but going by weight (2.2kg), it would seem to be comparable to a 250VA toroid. So, more like 250W combined max output for the entire unit - and even that is probably stretching it.
                    • Trinite
                      • 143
                      Re: Blown Amp/Mixer
                      Tested the output path, no obvious shorts. Seems that it provides the selection voltage for switching between 12V and 48V phantom power on the mic connections. So no major load on it, apparently. Odd that it would blow. However, it does seem that it draws directly from both 18V rectifiers, one supplying +18V to the input pin and the other supplying +18V to the common pin. Perhaps too much dirty power for it handle? There is a spot on the PCB to add a filter cap, so I ordered one for that.
                      • Th3_uN1Qu3
                        Believe in
                        • Jul 2010
                        • 6031
                        • Romania
                        Re: Blown Amp/Mixer
                        Never seen a reg blow due to input ripple. It might just be the occasional dud part - for example, the 78L05 supposedly has short circuit protection. I tried it out and it left a hole.
                        • Scenic
                          o.O
                          • Sep 2007
                          • 2642
                          Re: Blown Amp/Mixer
                          the 78Lxx's don't have any protections against short circuits or too high temperature.
                          all the others do though..
                          - the 78Mxx (500mA)
                          - the "normal" 78xx (1A ; the ST 78xxCV up to 1.5A)
                          - the 78Sxx (2A)
                          - and the pretty rare 78Txx (3A) in TO3
                          • Th3_uN1Qu3
                            Believe in
                            • Jul 2010
                            • 6031
                            • Romania
                            Re: Blown Amp/Mixer
                            Then why does everyone list it in their datasheets in big bold text? http://www.datasheetcatalog.com/data.../0/78L05.shtml
                            • Scenic
                              o.O
                              • Sep 2007
                              • 2642
                              Re: Blown Amp/Mixer
                              no idea.. i've never seen a TO92 78Lxx where the short circuit protection actually worked.. it always blew them ._.
                              the normal 78xx's just shut down and continue working after a soft restart (if the short is gone obviously..)
                              • Trinite
                                • 143
                                Re: Blown Amp/Mixer
                                From what I can see, all the traces running out of the VR terminate in resistors, the lowest of which are around 460 ohms. Hoping then that it was just a defective part.
                                As for build quality, this is laughable. I dug a bit deeper into the unit and found an improvised connector cut out of a larger part (great way to cut corners...literally). Check the photos below:
                                • Th3_uN1Qu3
                                  Believe in
                                  • Jul 2010
                                  • 6031
                                  • Romania
                                  Re: Blown Amp/Mixer
                                  It looks like it's been cut with a hacksaw.
                                  • Trinite
                                    • 143
                                    Re: Blown Amp/Mixer
                                    And a few other deficiencies I've noticed. The power switch is located on the neutral side, leaving everything before it live, even when off. Also, there is nothing attached to the ground connector.
                                    • Th3_uN1Qu3
                                      Believe in
                                      • Jul 2010
                                      • 6031
                                      • Romania
                                      Re: Blown Amp/Mixer
                                      More common than you might imagine. Here in Europe the mains plug isn't polarized so it can be inserted either way. It's a 50/50 chance which end goes to the power switch since no one bothers with double pole switches.
                                      Built-in ground lift! Woohoo!
                                      • Trinite
                                        • 143
                                        Re: Blown Amp/Mixer
                                        There is a 75V potential between the transformer center tap and ground
                                        Although I would assume it is not very high current.
                                          Acer Predator PT315-51-7815 Notebook Specification for Upgrade or Repair
                                          This specification for the Acer Predator PT315-51-7815 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the PT315-51-7815 boardview and PT315-51-7815 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 11:44 AM
                                          Acer Predator PH317-51-7815+Helmet VR Notebook Helios 300 Specification for Upgrade or Repair
                                          This specification for the Acer Predator PH317-51-7815+Helmet VR Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the PH317-51-7815+Helmet VR boardview and PH317-51-7815+Helmet VR schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-06-2024, 06:45 AM
                                        • Longon
                                          Behringer Pro Mixer DJX-750
                                          by Longon
                                          Hi all....I have been using my Behringer mixer quite comfortably for a number of years now and generally it's been trouble free apart from a replacement crossfader. Recently input three channel fader began to bleed a little and causing the mixer to light up like a Christmas tree! I realise the unit is ageing now and although I'd put some hours on it over the years it's not been abused. Following the issue I planned on replacing the faders and ordered the necessary parts. In the meantime whilst awaiting the replacements I continued to use the mixer up until the channel fader started to give feedback...
                                          Yesterday, 02:17 PM
                                        • cmlewis89
                                          LG 47LB5DF blown power supply board
                                          by cmlewis89
                                          Hi folks,
                                          I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
                                          09-03-2024, 07:50 PM
                                        • Bektronics
                                          Schematic Digital Audio mixer RCF type M18
                                          by Bektronics
                                          Hello dear audio friends.
                                          I am feverishly looking for the full electronic schematic (not a block diagram) of the RCF type M18 digital audio mixer.
                                          The device does not make a WIFI connection with my Apple tablet and yet I have already installed the recent app on it.
                                          I suspect that there is a problem in the mixer itself with the WIFI card and of course I would like to see this on an extensive schedule before opening the device.
                                          Thanks in advance if anyone can help me with this schematic.
                                          Of course, all information about this digital mixer and possibly references...
                                          07-24-2023, 06:40 AM
