Blown Amp/Mixer
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: Blown Amp/Mixer
    Well what are your plans with this thing? If it were for personal use i'd ground the center tap for normal use and add the appropriate ground lift switch for when it's needed (it is needed sometimes).
    A working TV? How boring!
    • Trinite
      • Dec 2010
      • 143
      Re: Blown Amp/Mixer
      Likely going to resell it. The previous owner was getting rid of it. I'll probably stick in a ground lift switch (was thinking the same thing you were) and sell it as a "modded" unit.
      • Trinite
        • Dec 2010
        • 143
        Re: Blown Amp/Mixer
        Pulled the HS off, looked at it more closely. Here is what I found: The VR failed shorted (input to common pin) and that in turn caused the nearby zener diode (1N4572A) to also fail shorted, shorting the common pin to ground.
        I hooked it up to power again, only to find that there was another short. One of the diodes (1N4007) on the 18V rectifier failed shorted and was shunting AC through the filter capacitors. Sounded like one of the caps vented too, but I'm replacing those anyway. Quite the catastrophic failure, apparently. After removing the offending diode, everything worked (but I didn't keep on for long, probably not good to do on just half-wave rectification).
        All that from a VR failure...
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          Re: Blown Amp/Mixer
          1N4007? Man, talk about cheap.
          • Trinite
            • Dec 2010
            • 143
            Re: Blown Amp/Mixer
            This just gets weirder. The voltage stored in the capacitors are as follows: 80V for the primary rail and 40V for the secondary rail. As the transformer uses a split tap, the specified voltages apparently only reference one side of the winding to center tap, and not across both. So the unit is running at double the voltage than what is specified on the transformer output.
            This is the problem: The 7815 is rated for a maximum of 30V. The input is 40V. It is connected to ground in series with a 1N4752A zener diode (the number I posted previously was a typo). The diode has a reverse-breakdown voltage of 33V. I'm assuming this is some lousy attempt to limit the voltage going through the 7815 VR?
            • Scenic
              o.O
              • Sep 2007
              • 2642
              Re: Blown Amp/Mixer
              i'm starting to wonder how the hell this thing lasted as long as it did...?
              40V on that 33V zener as a half-assed attempt at limiting the voltage going to the 7815...
              zener took a crap, 7815 got the full 40-ish volts and decided to 'splode a little..
              • Trinite
                • Dec 2010
                • 143
                #27
                Re: Blown Amp/Mixer
                Makes me concerned that when I fix and sell this thing, I will be getting a complaint that it blew after a few months use...
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  #28
                  Re: Blown Amp/Mixer
                  Use a 2W zener. Or two of them 1Nwhatevertheywere in parallel.
                  • Badcappy
                    Banned
                    • Aug 2007
                    • 52
                    #29
                    Re: Blown Amp/Mixer
                    You can replace the 7815 with a 15V regulator that can withstand a higher input voltage.
                    • Scenic
                      o.O
                      • Sep 2007
                      • 2642
                      Re: Blown Amp/Mixer
                      highest i've found is 35V
                      digikey: LM341T-15-ND
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 4962
                        • New Zealand
                        #31
                        Re: Blown Amp/Mixer
                        High quality, made in China!
                        You know it's el-cheapo when you see those multi-patterned ribbon cables
                        -David VanHorn
                        • Th3_uN1Qu3
                          Believe in
                          • Jul 2010
                          • 6031
                          #32
                          Re: Blown Amp/Mixer
                          Which is exactly what the 7915 supports in the first place so you still need that pesky zener.
                          • Trinite
                            • Dec 2010
                            • 143
                            #33
                            Re: Blown Amp/Mixer
                            Might just put a fuse in series with the zener. Also might add a bleed resistor, as the capacitors were still holding charge after 48 hours, so I decided to discharge them with a pencil lead
                            http://www.youtube.com/watch?v=bmTtuj9WKKM
                            • Trinite
                              • Dec 2010
                              • 143
                              #34
                              Re: Blown Amp/Mixer
                              It looks like it's been cut with a hacksaw.
                              You know, it's quite the "hack" job. Definitely "cutting" corners
                              Anyway, I got another hack job shown in the uploads. In this one it looks like they made a mistake in the PCB layout and went about cutting traces and running wires to reroute the connections. I also did my own hack job to try and fix the zener diode-VR hack job. I installed a 3A fuse in series with the zener, so if something does go wrong again, it will only knock out the 48V phantom power to the mics, instead of taking out the whole unit. Also replaced the 40V filter caps with some nice Nicichon audio caps; also replaced some of the other cheapo brands.
                              Got it up and running. Seems to be working alright, although the VR heatsinks are quite warm. Next up will be to test the audio functions.
                              • Trinite
                                • Dec 2010
                                • 143
                                #35
                                Re: Blown Amp/Mixer
                                Looks like this is quite the trainwreck. I couldn't get sound out of the speakers, so I took the front panel off the unit and found two toasted resistors. These supply a positive and negative voltage to an array of opamps, one of which had had failed shorted. The opamps are PJ4558CD - couldn't find them on Digikey so replacing them with NJM4558D. The resistor codes were unreadable; fortunately, the value (47ohm) was printed on the board.
                                Thankfully parts are cheap, otherwise this would be quite the moneypit...
                                The PCB does indicate a 4580 chip should be placed where the 4558 chips are. Would the more expensive 4580 be a better choice in this application? The 4558 has a GBW of 3MHz and the 4580 has a GBW of 12MHz, while the original chip only has a GBW of 2.5MHz.
                                NJM4558: http://search.digikey.com/scripts/Dk...NJM4558D%23-ND
                                RC4580:http://search.digikey.com/scripts/Dk...296-15368-5-ND
                                • Th3_uN1Qu3
                                  Believe in
                                  • Jul 2010
                                  • 6031
                                  #36
                                  Re: Blown Amp/Mixer
                                  4558s? Aw man... they sound like ass.
                                  Now, the problem is that they are STUPID stable (because of their low bandwidth) so if you upgrade them to higher quality ones and the circuit is designed poorly, the "better" opamps may oscillate. Been thru it myself.
                                  The 4580 is *slightly* better, but since they're both dirt cheap i'd just get how many you need of both of them. If the 4580s cause trouble you can go back to the 4558. If all the mixer is full of 4558s just buy 4558s - coz it's still gonna sound like a 4558 even if it passes thru only one of them.
                                  • Trinite
                                    • Dec 2010
                                    • 143
                                    #37
                                    Re: Blown Amp/Mixer
                                    The unit consists of a total of 20 4558s. 8 on the inputs, 4 on the output, 7 on the EQ and one for the headphones. I could replace them all, but knowing this unit the circuitry is probably quite poorly designed. Seems like I should just get some 4558s then.
                                    • Hotiron
                                      • Feb 2011
                                      • 12
                                      #38
                                      Re: Blown Amp/Mixer
                                      Seems to me The 15V reg is being propped up by the 33v zener for 48V Phantom power So 40v input is wrong.
                                      Waste of time and money upgrading the op amps on this thing, replace with any cheap dual device NE5532 or whatever is in your parts bin.
                                      Those burned resistors would have been fuseable to save the main regs.
                                      Time is Logarithmic: The Older You Get The Faster It Passes.
                                      • Th3_uN1Qu3
                                        Believe in
                                        • Jul 2010
                                        • 6031
                                        #39
                                        Re: Blown Amp/Mixer
                                        NE5532 will oscillate if you drop it directly where a 4558 used to be, it's happened to me. Better just keep it safe and get 4558s.
                                        • Trinite
                                          • Dec 2010
                                          • 143
                                          #40
                                          Re: Blown Amp/Mixer
                                          The input power is 40V (-20V/+20V). However, the phantom power uses two capacitors coupled with the AC inputs and is supplied with a +20VDC bias. So the reg is actually getting 60V.
                                          Also, I do not know if the previous resistors were fusible, since they were burned beyond recognition, but I am replacing them with fusible ones.
                                            Acer Predator PT315-51-7815 Notebook Specification for Upgrade or Repair
                                            This specification for the Acer Predator PT315-51-7815 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the PT315-51-7815 boardview and PT315-51-7815 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-06-2024, 11:44 AM
                                            Acer Predator PH317-51-7815+Helmet VR Notebook Helios 300 Specification for Upgrade or Repair
                                            This specification for the Acer Predator PH317-51-7815+Helmet VR Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the PH317-51-7815+Helmet VR boardview and PH317-51-7815+Helmet VR schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-06-2024, 06:45 AM
                                          • Longon
                                            Behringer Pro Mixer DJX-750
                                            by Longon
                                            Hi all....I have been using my Behringer mixer quite comfortably for a number of years now and generally it's been trouble free apart from a replacement crossfader. Recently input three channel fader began to bleed a little and causing the mixer to light up like a Christmas tree! I realise the unit is ageing now and although I'd put some hours on it over the years it's not been abused. Following the issue I planned on replacing the faders and ordered the necessary parts. In the meantime whilst awaiting the replacements I continued to use the mixer up until the channel fader started to give feedback...
                                            08-11-2025, 02:17 PM
                                          • cmlewis89
                                            LG 47LB5DF blown power supply board
                                            by cmlewis89
                                            Hi folks,
                                            I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
                                            09-03-2024, 07:50 PM
                                          • Bektronics
                                            Schematic Digital Audio mixer RCF type M18
                                            by Bektronics
                                            Hello dear audio friends.
                                            I am feverishly looking for the full electronic schematic (not a block diagram) of the RCF type M18 digital audio mixer.
                                            The device does not make a WIFI connection with my Apple tablet and yet I have already installed the recent app on it.
                                            I suspect that there is a problem in the mixer itself with the WIFI card and of course I would like to see this on an extensive schedule before opening the device.
                                            Thanks in advance if anyone can help me with this schematic.
                                            Of course, all information about this digital mixer and possibly references...
                                            07-24-2023, 06:40 AM
