Sonos Play 1 with blown cap and fuses
  • BMCappelletti
    • Nov 2021
    • 151
    • Brasil
    Hi there.
    I was given a Sonos Play 1 (yeah, very old) that does not turn on.
    Checking the main board, I can see a blown cap, that connects to two blown fuses. Right by the LAN port.
    Where should I start looking for the main fault?
    Thank you.
    • 31072
    Re: Sonos Play 1 with blown cap and fuses
    lightning strike,
    r27,r46 and more
    i cant zoom in because fucking IMGUR was used
    • BMCappelletti
      • Nov 2021
      • 151
      • Brasil
      Originally posted by stj
      lightning strike,
      r27,r46 and more
      I see those are gone, along with the cap.
      Imgur works just fine here to see full image.
      Try these links.
      MOD Edit: Images copied and posted to badcaps
        • 31072
        desolder the network transformer and meter the coils in it.
        if it wont boot without the transformer then it may have fried the network chip - i hope it's seperate and not part of the cpu!
        • BMCappelletti
          • Nov 2021
          • 151
          • Brasil
          Would it be the one with the number 2 next to it, with TP366 printed between its legs on the back side of the board?
            • 31072
            cant find it in the photo!
            desolder the network transformer connected to the burned bits and then meter the pads on the board to see if other stuff is shorted.
            i presume you already did the finger test to see if any chips are cooking
            • BMCappelletti
              • Nov 2021
              • 151
              • Brasil
              I did use a thermal cam and nothing seems to get hot.
              I'll try removing it later and check for shorts on the pads. I'll report back.
              Thanx.
                Surface Mount Fuses Fundamentals Datasheet
                TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                10-07-2024, 06:07 AM
              • MrzPdlch
                Blown fuses on Gigabyte GTX 980TI 6GB
                by MrzPdlch
                Hey everyone,
                I just went ahead and unscrewed a faulty GTX 980 TI from Gigabyte. What I found beneath the cooler was, as it seems, a common issue of that card. Two blown fuses on the bottom right corner of the card next to a MOSFET.
                Now my question would be if there is any schematics of that card available to figure out which are the blown components so I can try and replace them together with the mosfet if needed.
                Find some pictures of the actual GPU together with a picture of how it should look like.
                I also wonder whther it might be a problem that there...
                03-10-2024, 04:14 PM
              • Goldwing1973
                Sonos Play 1 pulsing power supply
                by Goldwing1973
                I'm rather new to repairing electronics, i do know the basics of most components but never actually repaired a PCB, but i want to change that.
                So, i bought a faulty Sonos Play 1 speaker with the intention of finding the fault, and replace the damaged part.
                Well, i did find the fault, i replaced parts that i thought caused the problem, but no-go.
                The problem is a pulsing power supply, when i connect the mains to the board and hook up my thermal cam i see R306,307 and 308 getting warm, but i assume that's normal.
                But, whats is not normal is the pulsing of resistor...
                07-04-2025, 12:59 PM
              • dbuergi
                Sonos Play 1 Gen. 2 with no power
                by dbuergi
                i got a Sonos Play 1 Gen. 2 with no light and no power. Until now i only worked on Gen. 1 and know which components "like" to blow up but at this board everything looks fine. Until now i also didn't find any short.
                The only problem i found was chip 6D9 heating up to 110c when power supply is connected. Since this is a PMIC i will replace it.
                Do you have any other ideas what to check or can these chips get faulty without any other component quitting the job?
                09-12-2024, 12:23 AM
              • gozotto
                Sharp LC-40LE812E fuses blown
                by gozotto
                I repaired a Sharp LC-40LE812E TV with the main power board DPS-126CP B.
                All fuses blown and the capacitor C7813 (220pF 1KV) was cracked. After replacing both, the TV works again without any problems. After 2 weeks the same problem apears with the same symptoms. What can the C7813 blown again and again? The schematic can be found here.
                Thanks in Advance
                gozotto
                04-04-2022, 12:14 PM
