Boss delay DD-3 (square ship taiwan) problem
  • Camarada78
    • Jan 2021
    • 28
    • Brazil
    I have a Boss DD-3 (square chip taiwan version) in my bench with a very weird problem. I found no similar problem online, nor a solution for it. It is driving me nuts.
    It passes sound on bypass no problem but as i turn it on it has a constant a noise (that can be clearly shaped by Delay Time, Volume and Mode, but very subtle by Feedback).
    - sounds ok on bypass
    - noise is there even without input connected.
    - all electrolitic caps were changed (!)
    - all tantalum caps were checked, ok.
    - most ceramics were cheked. too many to keep track.
    - many resistors checked.
    First i thought it would be a feedback problem (because it sounds as if it has almost infinite feedback). but even removing the feedback pot and the caps around it, the noise continues. I am afraid it is the main chip that's gone bad.
    Anyone experienced something similar with this classic pedal?
    (Schematic annexed)
  • Unluckyfett
    • Jul 2024
    • 8
    I have the exact same problem, I started another thread about it. Did you ever find a resolution? At this point I'm looking at IC8 as being the problem.
    • Unluckyfett
      • Jul 2024
      • 8
      The problem is the DRAM. I replaced the IC and its fixed now. Hopefully this helps someone in the future.
      • redwire
        • 3910
        Thanks for the follow up. Schematic says IC6 is M5M4464L-12 DRAM, I think you meant that not IC8 some op-amp.
        Other thread: Boss DD-3 (b) Problem
        • Unluckyfett
          • Jul 2024
          • 8
          Yes and no. IC6 was the problem. When I posted originally, I speculated IC8 because of the waveforms. However, I misunderstood the DAC process, and with some help from another forum, I narrowed it down to DRAM.
          • redwire
            • 3910
            OK that makes sense.
            Commonly I see guitar pedal's input get zapped from static electricity, the tip of the 1/4" jack which can kill/damage the input stage.
            JFET or op-amp if a pedal uses that.
            • r ez a
              5300 2 in 1 (18828-1) boot delay, tpm error
              by r ez a
              hello my friends
              i have a laptop here that came for this error
              "Alert! TPM device is not detected"
              and daley in boot
              i flashed bios with different files,aslo clean ME files
              but delay was still there
              is there any other reason for 15 sec delay in boot?
              than​
              02-03-2024, 08:23 AM
            • Steadily7-Colossal0
              bose soundlink color 2 strange behavior
              by Steadily7-Colossal0
              My dad gave me his bose soundlink color 2, claiming that the charging port was loose. I opened it up, plugged it in, probed around with a multimeter, and I can measure 5V all over the board. I wiggle the charging cable around, no change. The port looks fine: sturdy, clean contacts. I measure across the battery wires and I get 0V, so I assumed the battery was the problem. But then a few minutes later after I disconnected and re-connected the daughter board with the buttons, lights were flashing and I was reading 3.3V across the battery wires. The only logical explanation for this I could come up...
              12-12-2024, 03:20 PM
            • Soma89
              Boss TU-2 Tuner lagging upon hitting footswitch
              by Soma89
              My tu2 boss tuner has about a 5 second pause before it can start tuning. Doesnt matter how the pedal is powered, it always has this brief lag before it senses a note. Only upon hitting the footswitch from off to on. What part do you think can be causing this? I will add a schematic..can it be a power supply or footswitch issue?
              https://i.postimg.cc/Dhxc0Sr0/Boss-TU-2-schem.gif
              03-29-2023, 01:34 PM
            • Domenicoo
              Boss Audio Crossover BX-45
              by Domenicoo
              Good morning, can anyone send me the "Boss audio BX-45" diagram or check the acronym of the Q3 and Q4 transistors. Because from the previous repair I find myself (Q3 2N5551) while (Q4 SS8050) and it doesn't seem correct to me. Can anyone help me thanks.
              05-29-2024, 04:12 AM
            • mekvit
              Toshiba dynabook T552/58HR delay POST
              by mekvit
              Model number: Dynabook T552/58HR
              Serial number: 5D014496Q
              Motherboard number : DK10FG-6050A2509901-MB-A02
              Problem: Delay POST and hangs on windows logo when graphics driver is installed
              I have done everything possible, it has no graphics, bios bin I downloaded from this site didn't work. Please I need a clean bios. Thanks.
              Below is my bios bin file.....
              05-20-2024, 08:09 AM
