Marantz PM-66SE Burns Transistors
  • petehall347
    • Jan 2015
    • 4450
    • United Kingdom
    Re: Marantz PM-66SE Burns Transistors
    quickly get voltages at bases of q754 q756 .
    on another note do have the means to connect a series light bulb to the mains power to limit the current ?
    • hyva_ana
      • Sep 2022
      • 21
      • Finland
      Q754, first rises to about -12V then starts dropping.
      Q756, first rises almost -17V then starts dropping.
      I have to build that light bulb current limiter.
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8713
        Seems Q754 Q756 and Q758 should be in cutoff but they're not ... somehow Q758 is shorted or has the wrong polarity?
        Check the npn/pnps carefully if the transistor still tests good...
        adding original board photo to this thread too...since icloud is so slow for non apple users apparently.
        • hyva_ana
          • Sep 2022
          • 21
          • Finland
          Now I tested all of these transistors:
          Q757, Q758
          Q753, Q754
          Q751, Q752
          Q755, Q756
          Q759, Q760
          All of those are good and in right position.
          • hyva_ana
            • Sep 2022
            • 21
            • Finland
            And now:
            QN01, QN02, QN03
            Q701, Q702, Q703, Q704
            Q801, Q802
            This means that whole board is stripped out of transistors, and none of them is faulty (or at least not shorted). How close these small transistors (2SC2240 and 2SA970) should be each other in terms of gain?
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8713
              Put all the transistors back except Q757-Q764. you should be testing at steady state - after everything settled. When you mentioned -12V@B(Q754) and -17V@B(Q756) this was a bit large of a differential but should be okay - as long as the difference between the two pins stay less than 4v or so apart after settling. According to the schematic they should settle to 3.4V difference or so, 1.7V each to GND when idling/silent.
              At the next stage with Q758/Q760 installed, their bases need to be within 3v of each other. It says 2.4V or 1.2v to GND at idle/silent.
              The gains of Q753-Q764 don't matter very much, they just need to work as transistors.
              • hyva_ana
                • Sep 2022
                • 21
                • Finland
                #27
                Now those transistors are back in their places, except Q757-Q764.
                Q754 @B 17.8V, Q756 @B 14.5V
                Q758 @B 17.8V, Q760 @B 14.5V
                I don't know if I'm just too tired or what, but I could almost swear that when little earlier I measured those bases of Q754 and Q756, the voltages were negative, and now those are positive...
                But now, state is steady.
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8713
                  17.8V-14.5V=3.3V so this is actually good for Q754/Q756 but its absolute value should not be so high unless there's an input bias (are you shorting the inputs to 0v during testing?)
                  With the voltages at 14-17v, Q756 and Q760 should be cutoff, but you're saying the B-E junctions of Q754 and Q756 are 0 volts difference and thus shorted?
                  R762 is in place? Did it fry?
                  What is the voltages at Q702 and Q704 (B,C,E)? In any case the voltages on the drivers are looking like they shouldn't cause the drivers to fry unless the wrong devices were inserted or pins swapped.
                  • hyva_ana
                    • Sep 2022
                    • 21
                    • Finland
                    #29
                    I'm taking a few days off from this project. I'll get back to it soon.
                    • hyva_ana
                      • Sep 2022
                      • 21
                      • Finland
                      #30
                      Back again.
                      What exactly you mean by this: are you shorting the inputs to 0v during testing?
                      Q754 B-E: 0.62V. Q756 B-E: 0.58V
                      Components that warms up: Q763, Q764 (1k resistors between B-E), Q756, Q760, Q704, Q703 (warmest), Q728, R732.
                      R762 is in its place and not even getting warm.
                      Q702 B: 22.6v; C: 18.6V; E: 23.2V
                      Q704 B: -16.7V; C: 13.9V; E: -17.2V
                      Those are readings when I'm driving that board with two in series connected BPS, with voltages marked back side of the board: +24V and -18V.
                      But, when I connect board into its own transformer, that gives +/- 41.6V and then things are getting really hot. Especially those 1k resistors connected between B-E in Q763 and Q764 gets burning hot almost immediately.
                      What is the "right" way to try to figure this thing out?
                      • alfatv
                        • Sep 2020
                        • 353
                        Check C-E of Q801, Q802, they are probably shorted.
                        Then check the voltages from attached screenshot.
                        +24V and -18V must be there otherwise something else is wrong with those regulators.
                        • hyva_ana
                          • Sep 2022
                          • 21
                          • Finland
                          #32
                          Those are not shorted.
                          Q801: B 24.4V; C 41.0V; E 23.8V
                          Q802: B -18.0V; C -40.3V; E -17.5V
                          • alfatv
                            • Sep 2020
                            • 353
                            OK, but +24V and -18V are not the only voltages. +/-38V are used for the amp.
                            • petehall347
                              • Jan 2015
                              • 4450
                              • United Kingdom
                              #34
                              i think something is wrong at around q752 q702 q722
                              get voltages for those 3 .
                              • hyva_ana
                                • Sep 2022
                                • 21
                                • Finland
                                #35
                                Q752: B and C; voltage rises to about 26V for a little while and then rapidly drops to about 10 V, then it drops more slower towards zero - the lower it get's the slower it drops. But, when I cut the power off, the voltages rises rapidly to about 15V, and then drops to zero within couple of seconds. This same thing applies to Q702 collector.
                                Q752: E -25.6V
                                When I measured voltages again from Q752 E, it goes first to about +22V, then it rapidly drops to couple of volts and then slowly to zero and from there to negative voltage (increases slowly). Now when I cut off the power, voltage jumps to about +10V, the drops to couple of volts, then suddenly goes to -3V and jumps around, till it gets to 0V or something like that...
                                Q702: B 40.3V; E 40.8V
                                Was that Q722 a typo? I strongly think that there are no such transistor on that board.
                                • petehall347
                                  • Jan 2015
                                  • 4450
                                  • United Kingdom
                                  #36
                                  i meant q704
                                  see what voltages for other channel as well
                                  • hyva_ana
                                    • Sep 2022
                                    • 21
                                    • Finland
                                    #37
                                    Here are some voltages:
                                    https://www.badcaps.net/forum/pictur...&pictureid=968
                                    Now all the voltages were pretty stable, unlike on earlier measurements. Things really seem to change on this amp board...
                                    I don't know much of these, but I just wonder those QN03 voltages, or especially collector voltage.
                                    • eccerr0r
                                      Solder Sloth
                                      • Nov 2012
                                      • 8713
                                      if E-Q752=-25.6V and C-Q752=26V to 10V to 0V, this transistor is not working properly. If the transistor is working and not getting hot, this would imply R752 is broken.
                                      However I'm worried about measurement errors as the numbers reported post 35 are different in post 30 for Q702.
                                      I do apologize for all helping, we sometimes ask people to do things over and over again whether by mistake or TLDR, but sometimes this does show some measurement errors and without accurate measurement we can't deduce what's wrong.
                                      When I said input shorting, I meant the inputs to the entire amplifier - just want to make sure you didn't have some signal, especially one with a DC offset, going into the amplifier. Reduce the number of variables going on here.
                                      just saw your new post which seems to invalidate measurements in post 30 and Q752 is showing properly behavior as the difference between E and C is what it should be - around 4 volts and not 25V... At 25V this would cause your driver transistors to get hot and fry. Please ensure R752 is intact in any case and hopefully not flaky, but if your new measurement is correct then R752 is working.
                                      Again failure in QN01-QN03 will not cause your driver transistors to get hot, these merely cause shutdown to protect your speakers.
                                      • hyva_ana
                                        • Sep 2022
                                        • 21
                                        • Finland
                                        #39
                                        Only thing that goes to the amplifier board is that three pole transformer cable. Nothing else.
                                        Q752 stays cool as well as R752 and it is very good looking, like a new and reads 10 kohm.
                                        As I have told before, there is something "going on" on that board. Sometimes voltages are steady and stable, sometimes some voltages fluctuates all over the place and so on...
                                        • eccerr0r
                                          Solder Sloth
                                          • Nov 2012
                                          • 8713
                                          Do you have clips for your meter, perhaps what's next is to clip to specific points and carefully try to flex the board to see if voltages changes upon slight bending.
                                          If this ends up being a problem, then it's up to you to figure whether this is worth to fix or not.
                                          • acedogblast
                                            [Marantz SR5012] Center channel keeps going into ASO/Overcurrent protection.
                                            by acedogblast
                                            First off I would like to thank this community as it has provided me with great information that has helped me greatly on my repair for this Marantz SR5012 AV receiver. I am creating this new thread as the other 2 that I have created here has had their original question/problem solved and I plan that this is the final thread on my repair. Please note that this is my first time repairing audio amplifiers so I may not be aware of common issues and things to know.
                                            Lets start at what I have done so far. Random speaker popping on all channels is fixed by replacing the 2 large filter...
                                            03-01-2023, 08:24 PM
                                          • dansity
                                            JBL BALBOA 230 SUBWOOFER amplifier oscillating
                                            by dansity
                                            I'm trying to diagnose this amp but my knowledge run out and need advise.
                                            The transistors on the amplifier are rapidly heating up after power on and the speaker produces a wobbly humming noise. I can also measure a lot of weird things on the board.
                                            Checks I did so far:
                                            • visual inspection for burns, bulged caps and so
                                            • speaker terminal measures 0V during operation
                                            • checked all transistors for short and voltage drop - they all pass
                                            • checked all capacitors nearby transistors as well resistors
                                            • no shorts anywhere
                                            • Scoped the transistor and I can measure a 5Mhz sine wave on
                                            11-21-2025, 10:35 AM
                                          • Daniel Larsson
                                            Marantz SR7500 burning output transistors - so far 2 channels are gone. Help!
                                            by Daniel Larsson
                                            Will start with the question and the full story follows below.
                                            Can someone please let me know what voltage I should see per pin on the protection circut IC81, TA7317P?
                                            My voltages per pin with the IC removed, only measuring on the soldering pads now, are:
                                            1 -0.39
                                            2 0.0
                                            3 0.0
                                            4 0.0
                                            5 -12.5
                                            6 11.94
                                            7 0.0
                                            8 11.74
                                            9 11.74
                                            The full story is that my Marantz SR7500 shut down a couple of days ago stating "CHECK POW5".
                                            I checked the service manual to find out that the...
                                            05-30-2025, 11:39 AM
                                          • mikey5791
                                            Need help to replace burned resistor in 350w atx psu
                                            by mikey5791
                                            Hi to all forum members,
                                            Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                                            The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                                            Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                                            Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                                            12-26-2024, 04:55 AM
                                          • karatzdi
                                            Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
                                            by karatzdi
                                            I know some might say... just buy another one. Sell it as parts..!
                                            So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
                                            Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
                                            Spent some time downloading the Service...
                                            06-11-2024, 08:38 AM
