Marantz PM-66SE Burns Transistors
  • hyva_ana
    • Sep 2022
    • 21
    • Finland
    While ago I replaced those big filter caps to that amplifier. After that started to happen. I connected the amplifier normally to the mains and almost immediately several transistors burned out. I really didn't do anything else (at least on purpose) than replaced those big caps C801 and C802.
    After that I replaced those burned transistors (I can't remember exactly what they were) and measured all the others, and now everything should be ok. But, when I power up that amplifier part with two bench power supplies connected in series there is obviously still something wrong. The voltages fluctuates up and down and (NPN's) Q761, especially Q762 gets very hot - of course depending on the input current. I just can't figure this out. I have measured practically everything on that board but I just don't see, what's wrong with it.
    When I remove (PNP's) Q763 and Q764 from board, the voltages is no longer fluctuating, but when I connect either of those, then the fluctuation and heating starts again.
    I'm not good at explain this situation, but I hope that you get something out of this, and I'm more than glad to give you more information. If needed I can try to remember out which transistors burned out in first place.
    Schematics:
    https://share.icloud.com/photos/086M...9Uj8AAYIxiI5QA
    https://share.icloud.com/photos/034p..._Muf5RWPQc-ukg
    Board:
    https://share.icloud.com/photos/0c6u...yW6oiKThMKGtRQ
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: Marantz PM-66SE Burns Transistors
    Again as a broken record, those main filter caps rarely fail on audio equipment... Sometimes they make them with a fake bulge.
    So Q763/Q764 are still good/not shorted?
    You should check the transistors upstream in replacement cases like this, especially Q757-Q760) to make sure they're likewise good and not shorted.
    You did check all the voltages printed on the schematic (with Q763/Q764 removed so you don't fry any more stuff)? Any hot resistors?
    • petehall347
      • Jan 2015
      • 4431
      • United Kingdom
      i take it you had the transistors screwed down to the heat sinks and insulated ?
      did you put the caps in the right way round ?
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        geesh, i don't know why i give people benefit of doubt when reassembling power transistors... you're right, have to assume they don't, and this indeed does make more sense why it would all fail at the same time...
        • hyva_ana
          • Sep 2022
          • 21
          • Finland
          Yes. screwed down to the heatsinks and properly insulated. Caps inserted as they should be.
          I have not found any shorted transistors and all transistors I have changed are likewise.
          About voltages, they seem to be all over the place:
          B; C; E
          Q802 -18.5 V ; -43.4 V ; -18.0 V
          Q801 25.1 V ; 44.3 V ; 24.6 V
          Diodes:
          Cathode; Anode
          D805 0 V ; -18.7 V
          D804 25.2 V ; 0 V
          D803 -18.8 V ; -18.5 V
          D806 ~32.9 V ; ~8 V
          D802 25.0 V ; 25.4 V
          • hyva_ana
            • Sep 2022
            • 21
            • Finland
            R806 and D804 gets hot. From transformer comes 32.8 VAC. After bridge rectifier comes + / - 44.8 VDC. All of the voltages are higher than printed on the schematic.
            Voltages from QN02:
            B C E
            -22.1V ; 44.7V ; -22.1V, so far away from what those should be.
            • petehall347
              • Jan 2015
              • 4431
              • United Kingdom
              QN02: appears shorted base to emitter as no volt drop .
              • hyva_ana
                • Sep 2022
                • 21
                • Finland
                No it's not. Just removed it from the board and measured.
                • petehall347
                  • Jan 2015
                  • 4431
                  • United Kingdom
                  is it the KI or AE model ?
                  • hyva_ana
                    • Sep 2022
                    • 21
                    • Finland
                    I'm not sure what you mean, but in front panel is a plate which says "KI Signature", so maybe it's KI model?
                    • petehall347
                      • Jan 2015
                      • 4431
                      • United Kingdom
                      ok i see now at least one channel has railed ..
                      see what voltage at QN01 emitter or L751 .
                      • petehall347
                        • Jan 2015
                        • 4431
                        • United Kingdom
                        what i would do at this point is remove all output transistors for safe keeping .then add resistors from where the bases and emitters connect to keep the feedback path intact . for those 1k usually works for me .. its important to not have any loads connected to speaker outputs for now until its going to work again with the outputs back in .
                        • hyva_ana
                          • Sep 2022
                          • 21
                          • Finland
                          Voltage is -0.9V
                          I'm pretty new to audio amplifiers, so what do you exactly mean by "add resistors from where the bases and emitters connect"?
                          And, I have not connected any other thing than transformer leads in to it.
                          • petehall347
                            • Jan 2015
                            • 4431
                            • United Kingdom
                            first remove the output transistors then connect 1 resistor in place of each output transistors .. ignore the collector connecting point and solder resistor where base and emitter legs came from .
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8701
                              ignore xNxx components for now, apparently they failed to do their job or at least they rather protect the speaker only, ignoring the driver transistors. Also their readings don't mean much if you have Q761 or Q763 out.
                              What are all the voltages at the bases of all the transistors (Q753 Q755 Q757 Q759 Q761 Q763) and the voltage across capacitor C751?
                              OK I Hate icloud, uploading here:
                              • petehall347
                                • Jan 2015
                                • 4431
                                • United Kingdom
                                i think this channel is ok and its the other one thats gone to negative rail . yes it does have -900mv showing at the output but i think thats coming back from the protect circuit .
                                • eccerr0r
                                  Solder Sloth
                                  • Nov 2012
                                  • 8701
                                  also some oops mistakes that you should check for is swapping npn and pnp...
                                  I guess the other channel is worse off but neither channel should get hot when quiescent.
                                  • hyva_ana
                                    • Sep 2022
                                    • 21
                                    • Finland
                                    And these are the output transistors?
                                    • petehall347
                                      • Jan 2015
                                      • 4431
                                      • United Kingdom
                                      outputs are the 4 big ones on the heat sinks
                                      • hyva_ana
                                        • Sep 2022
                                        • 21
                                        • Finland
                                        I removed those output transistors and soldered 1kohm resistors between base and emitter places. Now resistors "in" Q762 and Q764 gets burning hot after couple of seconds when I turn the power on, and same goes to Q759 but it warms slightly slower - anyway, temperature in it rises so much, that I must shut power off after a few seconds.
                                        • acedogblast
                                          [Marantz SR5012] Center channel keeps going into ASO/Overcurrent protection.
                                          by acedogblast
                                          First off I would like to thank this community as it has provided me with great information that has helped me greatly on my repair for this Marantz SR5012 AV receiver. I am creating this new thread as the other 2 that I have created here has had their original question/problem solved and I plan that this is the final thread on my repair. Please note that this is my first time repairing audio amplifiers so I may not be aware of common issues and things to know.
                                          Lets start at what I have done so far. Random speaker popping on all channels is fixed by replacing the 2 large filter...
                                          03-01-2023, 08:24 PM
                                        • Daniel Larsson
                                          Marantz SR7500 burning output transistors - so far 2 channels are gone. Help!
                                          by Daniel Larsson
                                          Will start with the question and the full story follows below.
                                          Can someone please let me know what voltage I should see per pin on the protection circut IC81, TA7317P?
                                          My voltages per pin with the IC removed, only measuring on the soldering pads now, are:
                                          1 -0.39
                                          2 0.0
                                          3 0.0
                                          4 0.0
                                          5 -12.5
                                          6 11.94
                                          7 0.0
                                          8 11.74
                                          9 11.74
                                          The full story is that my Marantz SR7500 shut down a couple of days ago stating "CHECK POW5".
                                          I checked the service manual to find out that the...
                                          05-30-2025, 11:39 AM
                                        • mikey5791
                                          Need help to replace burned resistor in 350w atx psu
                                          by mikey5791
                                          Hi to all forum members,
                                          Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                                          The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                                          Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                                          Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                                          12-26-2024, 04:55 AM
                                        • karatzdi
                                          Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
                                          by karatzdi
                                          I know some might say... just buy another one. Sell it as parts..!
                                          So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
                                          Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
                                          Spent some time downloading the Service...
                                          06-11-2024, 08:38 AM
                                        • MrCommunistGen
                                          Polk Audio RTi100 Plate Amplifier won't power on and intermittently honks and buzzes
                                          by MrCommunistGen
                                          My childhood best friend was killed about 9 years ago. His parents are finally letting go of his things, and they offered me his Polk RTi100 tower speakers. The Polk RTi100 towers are one of a handful of designs from the early 2000s that is a full range 3-way tower with a built-in self-powered subwoofer. This is accomplished with a plate amp integrated into the speaker input panel.
                                          I think they used them for a while, but they've been sitting for at least a few years now. After about 40 hours of driving to their house and back (both they and I have moved in the last 9 years) I got...
                                          07-12-2021, 05:11 PM
