Guest - Try our new boardview, Bios, & schematic search. Over 1.1 million files for download!
Need Help Identifying This DIODE mounted on a Frigidaire oven control PN:316131600
by repair-itI tried to locate online without any success but maybe someone else might have better luck. If it is a double diode - it's done - based on the reading I got in diode mode....
by magnehHello all!
could someone help identifying this ST diode?
Marking EUV C730
Photo attached,
Thanks in advance!... -
I have an MSI 3PA1 monitor on my bench that wont power on. I have tested the 2 (what I believe to be Schottky Diodes) and both are shorted in both directions (a common faulty from what I can see on Google) but I'm not certain what the markings on the Diodes mean so I need some help in identifying which ones to order from Mouser please?
I've done a search for 101C 5100C and all I can find are datasheets for 5100C which say they are 20-100V 5A Schottky Diodes but I'm not 100% sure if this is correct or not and what significance the 101C is.
We... -
by Donny2derbyHi there all.
Troubleshooting an SMPS and I’ve found a SMD diode shorted in both directions. The trouble is it has no identification on it. So what do I replace it with and how do I tell where the anode and cathode is and how to mount the replacement?
It is diode D1 on the image.
Regards.
Gareth....1 Photo -
by CbizzWhile reviewing the a1466 820-00165 board schematics, I came across a diode that I need to identify. The part in question is labeled D2920 (NSR1020MW2T1G), but my problem is that the schematic has the icon for a Zener Diode, but when I look up the part number, I only get results for a Schottky Diode. I don't have much experience with technical schematics at all and this part just so happens to be missing from the board I am trying to fix so I need to get my hands on the correct replacement part.
I have attached both the schematic portion in question and a screenshot of the part... - Loading...
