Help needed identifying a component - AEG Convection Microwave
  • guando21
    • Aug 2016
    • 34
    I have an AEG convection microwave that blew it's plug fuse. I can see a blown component on the main PCB but i'm struggling to identify it. Can anyone help? It had a blue label with some part numbers that was stuck over another label. I have searched for the numbers on both with no luck as yet. Photos are available here:
    https://drive.google.com/folderview?...LyaAC4U_8llYbB
    Thanks in advance.
    • 31055
    Re: Help needed identifying a component - AEG Convection Microwave
    that's a transformer, why do you think it's bad?
    if you replace the plug fuse, what resistance do you meter between the live and negative?
    btw, dont use google - it's a pin in the ass.
    upload pics here.
    • redwire
      • 3910
      I see a 12V SMPS with TOP257 IC. Can't see a fuse, is it for this section or the magnetron, the one that is blowing?
      That's the SMP transformer, which is custom part for the oven. They don't fail and the housing crack looks to be the potting compound.
      • R_J
        • 9551
        The main fuse is usually a high current fuse, It could be blowing because of a faulty door switch, If the monitor switch is bad (contacts shorted) as soon as the main door switch closes the fuse will blow. It could also blow due too too much load, either a shorted high voltage capacitor, high voltage diode, shorted magnatron or high voltage transformer
        • guando21
          • Aug 2016
          • 34
          Thanks for the replies...a bit more info might be helpful. The model number is AEG MCC3885E-m. A friend asked me to look at this after she called out a 'repairman' who replaced the 13amp plug fuse and switched it on. They said they heard an electrical crackling sound coming from the front left corner of the front panel. The repairman said he didn't have a torx screwdriver so couldn't remove the top cover and left it at that after charging £72 for his efforts
          Anyway...the component in the photos has a crack across the top of the casing and is located in the area where the crackle was heard so I assumed that was it. I haven't done any further investigation as yet but I will check what as suggested and report back.
          I usually work on larger stuff like white goods etc, I'm only doing this as a favour so any help would be appreciated.
          • guando21
            • Aug 2016
            • 34
            Pics here
            • R_J
              • 9551
              That appears to be the low voltage smps transformer for the control panel. If the unit did not blow the fuse when it was first plugged in, I don't think that is the problem, although cracked from heat it may not be the issue. If it was indeed bad, as in shorted I suspect the switching ic next to it would have left the board.
              • CapLeaker
                Leaking Member
                • 8188
                for £72 you can buy a new microwave! Gee!
                • R_J
                  • 9551
                  It is a combination CONVECTION, Microwave oven, they are usually quite a bit more .
                    • 31055
                    diode gone wild did a good eductational video recently.
                    https://www.youtube.com/watch?v=BNW7FnEKa7Y
                    • guando21
                      • Aug 2016
                      • 34
                      This thing cost nearly £500 and matches other built-in appliances in a set. Plus it's owned by an OCD person with special needs. My first response was to tell them to replace it but it's no longer available new and the current model doesn't match the others.
                      • guando21
                        • Aug 2016
                        • 34
                        Thanks for the other replies, I will have another look at it today and report back.
                        Cheers
                        • R_J
                          • 9551
                          If you replace the fuse, then plug it into the outlet and the display comes on, that transformer is ok. I would then try the convection part of the oven, if that is ok, the fault would be with the microwave section of the oven.
                          • guando21
                            • Aug 2016
                            • 34
                            Just to follow up... replaced the fuse and plugged it into an RCD for about 5-10 seconds. Had a low continuous crackling sound and the display panel flickered on and off for a few seconds and then stayed off. Also did a few other checks and I think the convection element was short. The device has now been returned to the owner and I recommended they buy a new one. Many thanks for the help.
                            • trepachka
                              Help identifying a chip for Lenovo Slim 7 16IAH7 - schematics needed
                              by trepachka
                              I have this Lenovo Slim 7 16IAH7 notebook that is not booting properly. All voltages are there: 5v, 3.3v, 1.8v but it's still a no-go.
                              I spotted this IC chip with markings "6611c" on it. The coil near this chip measures around 200 Ohms which I think is too low. But without the schematics, it's just a guess.
                              I wonder if someone has the schematics for this board or perhaps, can help me identify this particular ship. Thanks....
                              08-08-2025, 02:04 AM
                            • sofles
                              Bowers & Wilkins PX7 S2 Needed help with identifying charging IC
                              by sofles
                              Hi there,
                              Recently I bought broken Bowers & Wilkins PX7 S2, the problem with them is that battery discharges on its own even with headphones turned off. It is a quite common issue with this model and even with model higher PX8.
                              With help of thermal camera I found out that there is one IC that is hot even with headphones turned off. To check if I'm correct I bought another PX7 S2 working one and replaced small charging board with this IC and problem solved, battery no more drains on its own. After changing board back to original problem returned so I'm 100% sure problem...
                              05-30-2025, 01:11 PM
                            • bohaboha
                              Help Identifying a component and advices needed
                              by bohaboha
                              Advice on this: VPMS2GMB I found some but they don't have the same indications on the chipset
                              Does it have to be exactly the same or is it enough that it is a VPMS2GMB
                              Identification: this Ic Q80B-104HIP when I search with Q80B-104HIP I get results for :EN25Q80B-104HIP as you can see the first characters are not in the picture is :EN25Q80B-104HIP the right one ?
                              the last mentioned are from a samsung mainboard BN41-02751B-000
                              Now the last one ic from USB AMCAP DIGITAL MICROSCOPE is blown but you can almost see many signs but not all of them if you can assist with some identification...
                              02-20-2025, 03:43 PM
                            • MyBrainIsAStrainer
                              Quicko T12-955 Repair (Board Rev 3.3): Help identifying components needed
                              by MyBrainIsAStrainer
                              Hello! I'm newbie-ish in electronics and hope you can help me.
                              I use a Quicko (or Quecoo, not sure which is correct) T12-955 soldering station as my daily driver. Recently, I had a mishap. While changing tips, the metal contact inside the handle got bent and must have shorted against some other contact. Since then, the station only shows "Error" on its display. I fixed the bent contact but the error didn't go away. In fact, now it's completely dead.
                              After opening it, I found obvious two faults: A chip that looked molten (U5), and another chip which got very...
                              06-17-2023, 10:59 AM
                            • Dvsr
                              Help needed identifying SOT-23 component with marking "AKE87"!
                              by Dvsr
                              I am trying to fix a dead lane switching track piece for slot cars made by Carrera. I measured component on PCB and found out that at least two components have gone bad. I suppose they are transistor which drive the solenoids. Their marking is AKE87. Those components are marked T3 and T4 on circuit board. I tried to search that marking from the internet but didn't find anything. I would like to know if those are transistor and what could be used as a substitute.
                              Any help is greatly appreciated! Thanks in advance! ...
                              03-24-2023, 10:30 AM
