Liitkokala Lii-M4 charger doesn't charge AA battery past 10 hours
  • flat-earther
    • Dec 2022
    • 178
    • palestine
    I have a Liitkokala Lii-M4 charger made for AA AAA 18650 21700 batteries.
    When I charge AA Ni-MH batteries it never goes past 10 hours, charging finishes at exactly 10:00h shown on the display. I don't recall seeing this problem when charging 18650s.
    Sometimes it can finish charging a battery in less than 10 hours, but it never goes past 10 hours. It's hard to believe my battery would coincidentally take exactly 10 hours to charge to 100%.
    What do you think, is it just a trash charger with a design flaw, a 10 hour timeout which shouldn't exist, or am I not comprehending something here?
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8820
    It took 10hrs to get 0691 ma in there?
    • flat-earther
      • Dec 2022
      • 178
      • palestine
      yeah it's too slow. don't buy this charger.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8820
        There is something totally wrong. You can charge an old NIMH battery faster than this charger whatever it is. Man 69ma per hour? Dayum… might as well put a hand crank on there and get a faster charge! It takes a whole day to recharge one NIMH if it is fully discharged!? Smack it against the wall and get a real charger!
        You aren’t trying to charge a full battery by any chance?
        • flat-earther
          • Dec 2022
          • 178
          • palestine
          The cell was discharged in my flashlight.
          This device sucks as a charger but I'll still keep it for the capacity test it has, it helped me identify several bad cells I had. The cell in the image for example tested above 2000mAh, so it should charge more than 691mAh.
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8820
            But let’s say 700mah per 10 hrs. That’s 2100mah taking you 3 resets and 30 hrs to charge for a NIMH AA. That’s utter garbage.
            • harp
              • Jun 2022
              • 728
              • Planet Earth
              So, what is specifications say on back label, or manual? My sanyo ni-mh charger take 250mA to charge 2x AA, and shutdown by design after about 14 hour... I think it is dumb model limited with time interval. In past, I charged ni-mh with smart, fast charger, and yes, it charge it in hour and half, the batterys are hot to touch, and very soon the battery is for trash... it is so smart that detect that battery is ruined, and wont start charging anymore... dumb charger is better I think, but with your is something wrong if the battery is good I guess...
                • 31944
                when a battery takes too long to charge - touch it.
                if it's burning hot then it has an internal leakage problem.
                i have had lithium cells get so hot i threw them onto a metal plate with a fan over them - throwing them out of a window was contemplated!
                • flat-earther
                  • Dec 2022
                  • 178
                  • palestine
                  well here's the manual if it matters https://manuals.plus/ae/1005009422514462
                  This charger is so weak the cells never get hot...
                    • 31944
                    5v input? thats a bit lame.
                    try another psu and cable.
                    my older lit' uses a 12v 2.5A supply.
                    • flat-earther
                      • Dec 2022
                      • 178
                      • palestine
                      Thank you stj, how embarrassing, now I realize my fault, I overlooked the fact that I used my computer's USB3 port as the power supply and evidently it's not powerful enough, because now I used a 5V 2.1A AC adapter and it successfully charged 2 cells in under 10h.
                      I need to try charging 4 cells at once. I realize in my original post I created a worst case scenario, an unspeced PSU and 4 cells at once.
                      BTW I originally bought this charger because it has USB input so I could use it off grid from a power bank, but that's not practical because I found out that once the batteries are mostly charged, the draw is too little and the power bank goes to sleep... had this happen with two power banks.
                      • flat-earther
                        • Dec 2022
                        • 178
                        • palestine
                        I did some testing, I placed 4 batteries to charge with the 5V 2.1A AC adapter and used a USB power meter and it showed 5.16V 0.22A, I don't think that low current would overload my computer's USB port...
                        After that I plugged the entire thing to my computer and it showed 0.22A, but the voltage sagged to 4.96V.
                        In my original post I think I also used a 1 to 3 USB port splitter and I may have had something else plugged into it also, so it actually had to be worse than that because now I tested my USB splitter and with a 0.42A draw it had a 0.1V voltage drop across it.
                        I also tested my USB3 port with a 0.53A load the voltage sagged to 4.85V.
                        • CapLeaker
                          Leaking Member
                          • Dec 2014
                          • 8820
                          Well… yeah…. Gotta use the correct PSU. lol
                          But still it’s a garbage charger. 250mah? Might as well put a hamster on a hamster wheel trying to charge the batteries and it will outperform that charger. Lol
                          • harp
                            • Jun 2022
                            • 728
                            • Planet Earth
                            once the batteries are mostly charged, the draw is too little and the power bank goes to sleep... If you DIY... Power Bank Stay Awake! Here's A Circuit To Do That: https://www.youtube.com/watch?v=lOL3ic8msas
                              • 31944
                              still not right,
                              to avoid confusion charge a single cell at max current - 1A
                              see what the charger draws.
                              i think we need to see inside it.
                              are you using 1900mAH cells?
                              • flat-earther
                                • Dec 2022
                                • 178
                                • palestine
                                The Duracell cells I have are 2500mAh bought 12pcs over 3 years ago. when I used the capacity test on this charger months ago couple were dead, couple around 1000mAh ,most around 2000, highest one 2270.
                                This charger is 500mA for AA cells, the 1A option can only be selected if charging 18650s.
                                I now charged 4 Duracells at once and here are the results. The cells did get hot by the way, used the same AC adapter.
                                All these tested around 2000mAh when I tested them months ago, apart from the fourth on the right which was 1000mAh.
                                  • 31944
                                  allowing for losses from heat, those numbers look o.k.
                                  i guess the charger works - just a bit poor compared to my "Engineer Lii-500" that lets me charge AA & AAA stuff at 1AH
                                    • 31944
                                    btw, you mentioned "off-grid"
                                    i try to standardise all my stuff for 12v input.
                                    in a SHTF scenario 12v will be a lot more common to find.
                                    cars, portable solar panels etc.
                                    even if your roaming, any alarm panel will have a 12v lead-gel battery inside it - so comercial buildings = 12v sources.
                                    • nicoar10
                                      DELL E5420 only works from usbc charger but charge battery normally
                                      by nicoar10
                                      I have a Dell E5420 motherboard that works correctly when the battery is connected along with the USB-C charger. As soon as I unplug the USB-C charger, it shuts down. However, the battery can still be charged. I can’t find the battery detection on this model. I would appreciate your help.
                                      04-12-2026, 08:32 AM
                                    • coasterghost
                                      Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                                      by coasterghost
                                      For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                                      Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                                      Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                                      System Hardware:
                                      Processor: AMD Ryzen 7 PRO 5850U
                                      Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                                      09-08-2025, 10:46 PM
                                    • rsa4092
                                      Acer Nitro 5 - AN515-54-52PY - LA-H501P - low voltage on ASGATE, no power from charger on +19VB
                                      by rsa4092
                                      Hello, I’m having a problem with my Acer Nitro 5 laptop, which has a Compal LA-H501P motherboard.
                                      Initially, the CPU power regulator was replaced because the computer shutdown unexpectedly, and couldn't be turned on, the service centre diagnosed a short circuit in the CPU power regulator, replaced it and laptop was working. After about two months, a new problem arose – the laptop would shutdown under heavy load, even when connected to charger. In addition, the battery was charging very slowly – or rather, discharging – despite...
                                      06-23-2026, 06:00 AM
                                    • ipatch
                                      troubleshooting microsoft surface pro 4 no power no led charge light
                                      by ipatch
                                      hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
                                      10-05-2023, 11:59 AM
                                    • ace.code
                                      dell latitude 11th gen and up type c charger problem
                                      by ace.code
                                      hi
                                      i have latitude 7420 laptop with swollen battery not working ,the problemis that the laptop wont power on with any type c charger anker , ugreen any brand even with lenovo or hp charger ,it only power on with oem dell type c charger, but if you put working battery the laptop charges with any type c charger, is there a solution to power the laptop with any charger without the battery plugged, ps: i tested with 4 latitude 5320 and other same problem
                                      05-22-2026, 08:34 AM
