Meaco Arete 12l Issues
  • wetwop
    • May 2026
    • Scotland
    Afternoon,
    I have a Meaco Arete One 12l dehumidifier. Its been great for the past 1.5 years but has recently started failing in the following manner:
    1. It will start and run for a bit.
    2. Beep a few times in a random sequence.
    3. Fail to run again for more than a few seconds.
    4. Not turn on again.
    If I leave it for a bit unplugged it will just repeat this. So far I have tried the usual empty the tank, clean the filter, unplug for a day etc. I replaced the LCD screen on the PCB as this appears to be a common fault. No luck. I have no warranty as this was bought second hand, and Meaco customer support have told me not to do any maintenance (best to buy a new one ahahahahahaha).
    Meaco did say it sounds like a power or control circuitry problem but this is very vague. Anyone got any ideas on how to start diagnosing this?
    Many thanks
    • 31717
    pictures would help,
    power board is always a good place to start.
    • CG2
      Meaco Arete One / Deye Dehumidifier not working
      by CG2
      I've got a dehumidifier that has stopped working. Plug it in, press the power switch, and it beeps 5 times. Nothing showing in the display (which is just two 7 segment displays) apart from the two decimal points flashing. The model is a MeacoDry Arete One 18L, which seems to be a rebadged Deye (all the boards are marked Deye). Here's what I've got so far (details in case anyone else in future should need them).
      Starting with the power board. Mains power comes in at the red connector top left. The compressor is powered by the orange connector to the right of that and is switched by...
      08-17-2024, 07:47 AM
    • gretti
      MSI Z370-A Pro, works but does not power off or reboot and USB issues
      by gretti
      I have a MSI Z370-A Pro. The board does not reboot or shut down from the Windows recovery console. USB communications stop and the status light on USB 1 stays on and does not blink. I have programmed a new BIOS with a CH341A programmer already, swapped RAM, PSU, CPU. The board will power off when the power button is held and resets when the reset switch is pressed, but it will not react to the reset switch if already told by software to shut down or restart. The board will reboot from BIOS after a save and exit command.
      The MSI BIOS included the ME firmware for the board. The size...
      10-16-2025, 02:14 AM
    • SoulFreeze
      Audio Issues - Realtek ALC3306 - Lenovo Slim Pro 7 14ARP8 - Type 83AX
      by SoulFreeze
      Hi, trying to troubleshoot some problems with this laptop I just finished repairing which had power issues (Burnt Buck converter - SY8883DFC shorted to ground).
      After repairing the above issue, I realized the following remaining problem,
      Sound only comes from bottom speakers, top palmrest speakers don't work. Neither does the headphone jack (static/buzzing).
      The computer recognizes headphones are connected and displays a popup in windows
      Sometimes, the computer will boot up and the sound will be working fine. However, if I run intensive programs and the computer...
      06-21-2025, 09:53 AM
    • Nagyesz
      Lenovo IdeaPad Gaming 3 15ACH - Ideapad 3 well known solder joint issues
      by Nagyesz
      I have a Lenovo IdeaPad Gaming 3 15ACH, which has started exhibiting the well-known issues of the Lenovo IdeaPad 3.
      All stress tests run perfectly, and there are no performance issues. However, the solder joints are almost certainly starting to fail. If the top two screws on the back are not screwed in, moving the screen results in a BSOD or, in some cases, a slight artifact and freeze. This is a 2023 notebook..
      How can I extend its lifespan? Could reflow help?
      It has ryzen 5 5500h, rtx 2050, no soldered ram.
      Example of the artifacts:
      03-01-2025, 11:11 AM
    • pwnjuice
      Bitlocker issues
      by pwnjuice
      Customers laptop had a Motherboard go bad and replaced it. they want to try to get data but. I am having bitlocker issues. I will list below
      Issue 1: When connect the drive to my computer to decrypt it I get this message. "there are no supported protectors on this drive the drive cannot be unlocked"
      Issue 2: When I run powershell as admin and try manage-bde -protectors -get e: I get this message. " ERROR: An attempt to access a required resource was denied. I also get the same error when I try manage-bde -status e: When I try the same with terminal with
      01-06-2025, 05:33 PM
