Roborock S7 Max Ultra - water ingress
  • stav242
    • Jan 2014
    • 64
    I picked up a dead Roborock S7 Max Ultra, which has run through some water.
    The main motherboard was dead, found a blown smd MOSFET on the rear.. replaced it and got power back.
    " A1SHB " (HM2301B SI2301) SOT-23 Transistor MOSFET P-Channel 20V 2.8A
    But it's still not passing POST, I can run some tests but the power rails seem to drop below acceptable thresholds and the board reboots.
    I presume some other components were damaged when the initial power spike blew the MOSFET.
    Anyone have a schematic ?
    • 32068
    a robot mop - what idiot came up with that idea?
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8887
      Actually it was iRobot (Roomba) that had one long time ago. I just find Roborock beats Roomba by a mile, less the lidar motor.
      • Boardview and Schematic Bot
        ZTE Nubia Z40 Pro & ZTE Nubia Z50 Ultra Boardview
        Z40 Pro zs1B PCB layer.pcb
        Z40S Pro Z6HA shim- PCB layer.pcb
        Z40S Pro Z6GA SUB PCB layer.pcb
        Z40S Pro Z6EC MB+SUB YiDianTong.pcb
        Z40S Pro Z6EC MB PCB layer.pcb
        Z50 Ultra shim PCB layer.pcb
        Z50 Ultra z8nA SUB PCB layer.pcb
        Z50 Ultra z8sA SUB PCB layer.pcb
        Z40 Pro shim PCB layer.pcb
        Z50 Ultra z8xA MB+SUB YiDianTong.pcb
        Z50 Ultra z8xA MB PCB layer.pcb...
        09-30-2026, 11:59 AM
      • c_corr
        HP EliteBook 830 G7 blown low power mosfet unclear type
        by c_corr
        Trying to repair a HP 830 G7 board where I found the Q7001 a low power mosfet blown probably caused by supplying current to a shorted capacitor from the 5V line -> I plan to locate the shorted cap with the usual lab PSU set to 1V and limted to 2-3 amps and a thermal camera.
        Blown mosfet is shortcircuited and has a hole in its casing so I cannot read its marking properly hence my problem.
        Looking in the only schematic available everywhere on the internet the Q7001 shows as being a PJS6416-AU N-channel mosfet but the schyematoic image shows a P-channel mosfet and also there...
        06-21-2026, 04:33 AM
      • Jane
        How do you test MOSFET in laptops ?
        by Jane
        I tried to use this method:
        Testing an N-channel MOSFET:
        Step 1: Discharge the Gate (turn off the MOSFET)
        Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
        Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
        Step 2: Charge the Gate (turn on the MOSFET)
        Now, place the red probe on the Gate (G) and the black probe on the
        09-27-2024, 03:31 AM
        20 year old Kenmore refrigerator ice maker bad water valve coil took a crap
        I got lucky that when I got home and was about to get some ice out of the ice dispenser I hear and see water running down the outside of the ice dispenser what the heck is going on here
        At first I thought that the ice dispenser mold was cracked so I brought a new ice maker because this one has been in there for about 10 years now
        Well I put the new one in and wait and I wait for the water valve to open and let water in no such luck well there is a way to check the function of the motor and the water valve on this ice maker just need a jumper wire “L” to...
        04-09-2023, 08:04 PM
        LG Gram Ultra-Lightweight Notebook Specification for Upgrade or Repair
        This specification for the LG Gram Ultra-Lightweight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Lightweight boardview and Ultra-Lightweight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
        09-07-2024, 03:40 AM
