8 way AA/AAA battery charger short circuit Powerkan N8
  • flat-earther
    • Dec 2022
    • 209
    • palestine
    This Powerkan N8 AA/AAA 8 slot battery charger developed a problem that caused the USB port it was plugged into to shut down.
    I measured resistance on some capacitors on the PCB and they were at 0ohms so I knew there was a short circuit somewhere.
    I used my thermal camera when plugging it in and saw that a component U3 got hot briefly before the unit shut down.
    I removed that component, and now the short is gone and the charger works on slots 1-4, but slots 5-8 don't work anymore, they light up even without battery in them and behave weird, so now the charger is only a 4 slot charger.
    Does anyone know what that failed component does and what it is?
    I may not replace it if I have to buy it as it's a cheap charger.
  • flat-earther
    • Dec 2022
    • 209
    • palestine
    BTW the charger failed in under 2 months.
    Recently I bought the same charger again and it failed as well, in 10 days.
    The same part developed a short circuit. part in old unit marked A319CA, in new unit A348CA.
    Since there are 2 of those components inside every charger I took the remaining working one from the old charger to the new one to make the new charger working again.
    • Boardview and Schematic Bot
      NVDC charger configuration...
      11-05-2024, 03:28 PM
      ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
      Highly Integrated Narrow VDC Battery Charger for Notebook Computers
      The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
      for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
      Narrow VDC applications where the system power source is
      either the battery pack or the regulated output of the charger.
      This makes the max voltage to the system equal to the max
      battery voltage instead of the max adapter voltage. Operating
      at lower system voltage can improve...
      11-05-2024, 04:43 PM
    • flat-earther
      how to prevent a connected charger from draining battery when not charging?
      by flat-earther
      I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
      So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
      but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
      So the battery is backfeeding the charger and being drained.
      How can I prevent...
      08-07-2025, 01:04 PM
    • ryancog
      Lenovo Legion 5 Pro 16ARH7H Short On "5V Always-On" Rail
      by ryancog
      Hello there,
      I've got a Lenovo Legion 5 Pro 16ARH7H (AMD Ryzen 7 6800H, NVIDIA RTX 3070Ti) that seems to have "developed" a short on the 5V "Always-On" rail.
      Background
      I don't have too much in the way of useful information here, I don't think. This laptop has been used for the past few years without any notable issues/incidents. The laptop is often "docked" w/ the AC adapter (Lenovo's rectangle one) connected. A few days ago, I finished up working on things in the evening, and the next morning I found the laptop off w/o any...
      04-20-2026, 10:50 PM
      Bauer tool battery pack charging with a HERCULES charger modification
      The Bauer power tool battery charger just has to many issues with the charger over heating because I several HERCULES Hercules battery chargers that are 3 amp charge and because they have gone on quite a few times over the years before they came out with the fan cooling battery charger I going to modify one so I can charge Bauer battery packs faster than the crape battery charger that they have
      Here is how this modification is going to be done I taking a 1.5 amp hour battery enclosure and gutting it removing the battery cells and replacing some Ryobi 1.5 amp hour battery pack that...
      05-06-2023, 12:17 PM
