Try our new boardview, bios, & schematic search. Over 1.3 million files for download!
AcuRite 5 in 1 temperature sensor replacement repair
    Posted Photos 5 Photos
  • drake441335
    OLED65G6P-U.BUSWLJR Temperature sensor issue
    by drake441335
    I am a very beginner at tv repairs. I am trying to fix my tv before I end up buying a new one. I do not know names of boards, but I will do my best to explain what I have done so far.
    Tv is an LG OLED65G6P manufactured in april 2016. I had a warranty on it till September of 2021. Warranty is done. The problem I am having is when I turn the tv on after about two or so minutes a popup comes up and says the temperature sensor issue, and then it powers itself off. The tv works as designed, picture, sound, wifi, settings and everything, before it just powers itself down.
    So i did what any...
    02-13-2022, 03:34 PM
  • groomit
    Google Pixel 5 - Proximity Sensor Issues - Reflow/Replacement procedure tipps wanted
    by groomit
    I just replaced the battery on a Google Pixel 5.
    After that the proximity sensor isn't functioning properly any more. It is constantly activated. So when playing a voice message on Whatsapp, the Screen instantly turns off.
    Checking with a sensor app I can verify weird behavior of the sensor. It is triggered when nothing is near and sometimes works correctly when squeezing the phone next to the sensor hole.
    The rubber seal is on again (as mentioned in various suggestions in other forums).
    This smells like a cold or broken solder joint. So I'd like to reflow...
    06-11-2025, 02:21 AM
  • ErParucca
    Thinkpad X390 (motherboard NM-B891 shared with other models) : battery sensor reporting wrong temperature -> sudden power off
    by ErParucca
    I have a thinkpad X390 that would work fine if not for a problem: sensor temp5 (battery as far as I know) shows variable values over 100° C. When it reaches higher temps (I guess 110° as I was able to list temperatures up to 109°) it simply powers off. All other sensors show 0° except for the CPU which seems to report correct temperatures.
    In a wishful thinking I hoped replacing the battery (as far as I know the temperature sensor is in the battery) would fix the problem, but it didn't.
    Given this situation I can't even upgrade the firmware as the machine powers off...
    07-10-2025, 10:46 AM
  • jasonr2000
    Macbook Pro 16" 2019 No Display After Lid Sensor Issue
    by jasonr2000
    hi guys i have the above MacBook pro 2019 16"
    i did some dust cleaning recently and i somehow damaged the lid angle sensor. so i purchased the nerdtool1 lid angle sensor calibrating tool and a new sensor.
    installed it and followed the instructions to program the sensor.
    and now im still getting no display out of the MacBook pro.
    its booting up ok ive noticed the keyboard and touchbar is all lighting up.
    it was also showing a display before i replaced the damaged sensor and now i cant get any display out of it.
    02-18-2026, 01:54 PM
  • Windows8RTMUser
    Repair knowledge for -55c CPU temperature on AMD Ryzen CPUs in bios, the AMD Sideband temperature sensor interface (SB-TSI)
    by Windows8RTMUser
    Recently I came across an x570 Aorus Elite where the temperature in bios was reporting -55c, i had checked the CPU_TEMP line connected to the IT8688
    In my particular case, the SIC line going to the X570 chipset (PM_SIC) was shorted to ground, so far disconnecting the 0 ohm resistors connecting APU_SID and APU_SIC to the chipset has fixed my -55c issue, it seems like -55c is the fallback reading for CPU_TEMP which is just pulled up to VREF on most gigabyte motherboards
    I wanted to post this as even the ever-reliable vlab forum was stumped on this issue
    tags:...
    07-28-2025, 07:26 PM
