LED driver board, orient electric, 7W
  • claws77
    • Apr 2024
    • 97
    • India
    datasheet= https://www.alldatasheet.com/datashe...C/SIC9753.html
    i have tried to make the schematic similar to typical application
    A1 = varistor
    V_C5 _measured wrt -ve = 57-60V pulsating DC, VDD_measured wrt GND_IC = 12-14, VDD_measured wrt -ve = 60-62V pulsating, V_Drain wrt -ve =309V,
    1. L2 is unknown, how to measure inductance with multimeter?
    2. what is happening after rectification and varistor? what does this IC do? how does it provide constant current ?
    3. R8 36Kohm is to discharge the capacitor C5 100uF only, right?
    4. how to test if this IC is faulty?
    • 30997
    it's an online buck convertor,
    A1 is a VDR to supress spikes
    R8 is to provide a load if the leds fail so the voltage doesnt spike really high,
    you cant read the inductor with a multimeter
    • claws77
      • Apr 2024
      • 97
      • India
      thanks, how to test if IC is faulty.
        • 30997
        test the leds and replace c4
        • claws77
          • Apr 2024
          • 97
          • India
          LEDs are fine.
          this is a bypass capacitor so can i replace it with any higher value for capacitance and rated voltage
          the current one on board is 4.7uF and 50V
          • claws77
            • Apr 2024
            • 97
            • India
            i have 4.7 uF and 400 V and 10 uF & 63 V
              • 30997
              10uf is better
              and check the diodes
              the fact it's pulsing means it's trying to run.
              • claws77
                • Apr 2024
                • 97
                • India
                nothing
                • claws77
                  • Apr 2024
                  • 97
                  • India
                  i have succesfully blown the input (AC) side of the rectifier.
                    • 30997
                    how?
                    is c3 shorted?
                    • claws77
                      • Apr 2024
                      • 97
                      • India
                      no, i was working on metal plate, and there was some movement and the live wire touched the plate and near the soldered joint and back plate of LED (heatsink) made a connection. i think.
                      R1, R2, L1, and the first LED(only) was blown(open) so i replaced them all only for them be blown again (this time i made sure everything was insulated) maybe something else is shorted too. hope its not the IC.
                      Can i not use this LED circuit without input filtering. if i am unable to find the right parts.
                        • 30997
                        the only input filtering is R2 and L1
                        • claws77
                          • Apr 2024
                          • 97
                          • India
                          my bad R1 is a fuse, kind off.
                          • CapLeaker
                            Leaking Member
                            • 8133
                            If R1, R2 and L1 blow up all the time, either your bridge rectifier D1 to D4 is shorted or A1 is shorted. Check them out first. Sure you can take L1 out and solder an and replace R2 with a 1 Ohm resistor (fusible resistor fireproof) or similar.
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8701
                              check the resistance between drain and GND of the IC, if that is shorted, replace IC. I think when you shorted the plate to mains and killed everything the first time you probably backfed power into the IC and killed it... though do check the diodes D1-D4. I don't think anything else would cause repeated fusing of R1/R2.
                              By the sound of the symptoms you probably just had a weak LED to begin with that was causing the flickering...
                              • osrex
                                LED DRIVER KEEPS DYING
                                by osrex
                                Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
                                i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
                                i have no datasheet at all for the LED lights, all i have is its length.
                                long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
                                as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
                                05-05-2025, 03:36 PM
                              • chth96
                                How can I identify varistor which have been blew up?
                                by chth96
                                I mistakely pluged 100v japanese retro game console to 220v outlet.
                                So It seems that glass fuse and varistor have been blew up.
                                I can identify that voltage and ampere value of glass fuse(250V LF 1.6A),but It is impossible to identify varistor type in my sega saturn PSU(YAMAHA 35M07U XR258)
                                Is there any way to identify varistor type in my sega saturn PSU?
                                Any reply would be appreciated.
                                EDIT:
                                It seems that I finally found out what type this black varistor is. It is Panasonic ERZV05D221 “ZNR” Transient/Surge Absorbers (Type D) Varistor Voltage...
                                11-26-2023, 08:52 AM
                              • howardc64
                                Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
                                by howardc64
                                Problem
                                Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
                                Model & Board Pics
                                Conflicting Spec
                                Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
                                https://www.shopjimmy.com/vizio-gj-2k1...
                                10-10-2024, 01:16 PM
                              • charif
                                Audio Driver for Thomson P14C4BK128
                                by charif
                                Need Audio Driver for Thomson P14C4BK128 (Windows 10/11)
                                I'm looking for help finding the correct audio driver for my Thomson P14C4BK128 laptop.
                                The sound is not working properly, and I believe the audio driver is missing or not installed correctly.
                                Here are the details:
                                • Model: Thomson P14C4BK128
                                • Operating System: Windows 10 64-bit
                                If anyone has a working link to the driver or knows where I can download it, I'd really appreciate it.
                                Thanks in advance for your help!
                                04-30-2025, 05:41 PM
                              • bohaboha
                                how to install gl usb2.0 uvc camera device driver on windows 10
                                by bohaboha
                                Hello all am trying to reinstall my AMCAP Microscope on windows 10 but it is not working anymore. But the cam and the drivers are present in the Device Manager but there it saysWindows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) the drivers is : gl usb2.0 uvc camera device driver and i also get this mesage: Windows found driver software for your device but encou​ntered an error.
                                but it is quite strange because it did work on this same OS for one week ago and even for sometimes ago on that same but now nix.
                                any help?
                                01-26-2025, 08:33 PM
