Need help troubleshooting a Whirpool control board (it's not the caps!)
  • UL161
    • Aug 2021
    • 17
    I have a Whirlpool Side-by-side refrigerator that is only a few years old and I am now experience a problem where the cooling coil valve that enters the refrigerator side is not opening consistently. (the freezer is perfect ice cold). I have found out the problem can be overcome by simply pulling the power for a few minutes. Upon restart it works for some period then randomly stops. In speaking with a tech they claim this issue is likely due to an issue on the main control board. So I decided to pull it and I thought one cap looked bad so I replaced all 4... I thought I had solved it but ~24 hours later, it exhibited the same intermittent symptoms. Anyone have a clue what other part on this board might be the issue???
    • 31025
    maybe the valve is sticking - connect a meter or lamp to it
    • UL161
      • Aug 2021
      • 17
      Definitely not a valve issue.. it is electronic
        • 31025
        well it could be a relay issue - and c58 doesnt look great - top should be flat
        i dont think c58 is the issue - just something unrelated.
        • UL161
          • Aug 2021
          • 17
          actually agree with you. I replaced c58 + the other 3 caps... (picture is before my repair).... still having the issue..... If it were a relay... I would assume that would just be dead and unrecoverable with my power off power on trick... what do you think... I am certainly not an expert however so not positive about my statement on that point, just my understanding how the part works.
            • 31025
            no, what useually fails is the switching contacts get pitted from arcing and then they get unreliable.
            maybe you can switch them with a battery and then meter the contact resistance but thats not reliable without a load.
              • Jul 2011
              • 6039
              Where is the power supply board located at because I do not see a switching power supply transformer or the switching power supply regulator on this board because you might not be getting any power to supply power to this board
              I have worked on this type of board before on another refrigerator and it was a power supply problem so I would look for the power supply board and see if it powering ON or not
              • UL161
                • Aug 2021
                • 17
                sam_sam_sam.... Thanks for this suggestion.. I am actually thinking that the power supply board might be causing the issue to some extend too. It is actually on a separate board next to this one... (see this link on ebay... Board is basically this model. ) I think one 10uF Cap on this board looks a bit suspect... Maybe I should just try to reCAP the power supply board too. What do you think??
                  • 31025
                  OMFG!
                  get that board out and inspect it,
                  the one on the ebay link had so many cracked solder joints it was hard to believe!
                    • Jul 2011
                    • 6039
                    Originally posted by stj
                    OMFG!
                    That is not unusual for Whirlpool controllers board to be like that sometimes after a few years in service poor quality control on the part of manufacturers of these boards really sad that they do not have better quality controls in place but it not just Whirlpool that has this there are a lot manufacturers that seem to have this problem as well
                    • UL161
                      • Aug 2021
                      • 17
ID:	3169656 Click image for larger version
ID:	3169655 Click image for larger version
ID:	3169654 Click image for larger version
ID:	3169653 Here are a few picture of my power control board.. I don't think it looks in as bad shape as that one on ebay... That said, I think it is probably worthwhile to just replace the 7 caps on the board. Would you agree?
                        • Jul 2011
                        • 6039
                        I highly recommend that you use a magnifying glass to see the fine cracks around the pin soldering joints to the board or if see flux around the pins or around the pin holes to solder traces if you see either one remove the solder and redo them
                        You need to look at pin connectors on this board for bad-rings around that look like the solder separation from the pins to board because or gaps between the pins and solder joints to the board Whirlpool has had some very serious issues with this in the past I have repaired a few there board in the past
                          • Jul 2011
                          • 6039
                          Click image for larger version  Name:	IMG_3067.jpg Views:	0 Size:	2.03 MB ID:	3169656 Click image for larger version  Name:	IMG_3066.jpg Views:	0 Size:	1.94 MB ID:	3169655 Click image for larger version  Name:	IMG_3061.jpg Views:	0 Size:	2.13 MB ID:	3169654 Click image for larger version  Name:	IMG_3062.jpg Views:	0 Size:	2.07 MB ID:	3169653 Here are a few picture of my power control board.. I don't think it looks in as bad shape as that one on ebay... That said, I think it is probably worthwhile to just replace the 7 caps on the board. Would you agree?
                          Take a picture of the bottom of the board so I can see the soldering joints and the traces
                          What is the part number of the device that is mounted on the heat sink
                          Because iI think I see the switching power supply regulator because if I see it right it has 5 or 6 pins
                          By the way the capacitors that KZE or KY are a very good series in caps I would not necessarily replace them at this point but if there is a capacitor near the switching power supply regulator I would definitely recommend changing it especially if the UF value is less than 100uf it might be 10uf, 22uf, 33uf, 47uf
                          • Yanleb
                            LG 60PK550 Logic Control Board EBR63450301
                            by Yanleb
                            Hi all, I just want to share the repair of my 60PK550-UA TV set.
                            The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
                            But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
                            All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
                            C57: 3.30V
                            C61:...
                            07-20-2023, 12:38 AM
                          • howardc64
                            by howardc64
                            07-24-2025, 05:17 PM
                            Linear Garage Door Opener Control board took a crap install a new control board back normal
                            by sam_sam_sam
                            I have been having issues with this garage door opener for a while first the range of the remote was a lot less and sometimes it would start to go down and stop for no reason that I could find and would every once in awhile to start with then it started going more frequently until last Saturday when I opened the garage door it refused to close so I cranked up force all the way maximum limit this did not work also the sensor on one side that has a green and red lights that are supposed to be on when the door is open and there are no obstacles in the way on the original board the only light that...
                            02-08-2025, 06:52 AM
                          • m1ch43lzm
                            by m1ch43lzm
                            05-12-2025, 08:37 PM
                          • redoxy
                            Control Board Replacement for 2K display
                            by redoxy
                            I am looking at the option of replacing my control/driver board to one with HDMI and/or Display port input on a 2K LED (I think IPS) screen.
                            The display is Samsung LTM270DL07.
                            I have tried using the model number to search for a compatible control/driver board but so far my efforts have been futile.
                            I am looking for inputs on what board could potentially be used for my display.
                            Attached are pictures of the display label information and connectors (CON30 CON40 only) and pictures of the current control board.
                            Also attached is a technical...
                            03-14-2023, 08:52 PM
