Honeywell Accenta G3 tamper alarm
  • Tom41
    • Oct 2005
    • 336
    • England
    This house has a Honeywell Accenta G3 alarm system. If the main unit loses power for any reason, the external siren sounds - even if the alarm is not even armed! Entering the code to disarm it is not an option as the keypads are completely dead when the power is out.
    I presume this means the backup battery inside the box has failed, but I can't get in there and replace it without also setting off a tamper alarm! Is there any way to disable the tamper alarm so that electrical work can be carried out with the power off? Or a way to replace the backup battery without setting off the alarm?
    You know there's something wrong when you open your PC and it has vented Rubycons...
  • petehall347
    • Jan 2015
    • 4001
    Re: Honeywell Accenta G3 tamper alarm
    here is the manual ...https://www.tlc-direct.co.uk/Technic..._A-G3_inst.pdf
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 6359
      If the alarm panel sounds an alarm while power is off, there must be a battery somewhere in order to sound the alarm.
        stj
        • 29511
        • some shithole run by Israeli agents
        the external bellbox has one incase the cables are cut - standard feature for decades
        • redwire
          • Dec 2010
          • 3415
          Tamper fault puts the unit into lockout and the keypad acts dead until that fault is cleared, only by entering User Code then Engineer Code. If that has been changed from default 9999 then only choice is phone the alarm company that knows it, or blow out the entire program back to factory defaults.
          I'd be tempted to disconnect the siren, yes it's another tamper fault event but at least then you can check/replace the battery.
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6030
            Yes, that means the backup battery in the main unit is dead. I had the same problem a few years ago. What I found is that duct tape over the siren will quiet it down enough for it to not irritate the neighbors while you replace the battery in the main system.
            A working TV? How boring!
