Help to identify destroyed transistor from a power supply's pool's robot KWADOO v.2
Hi guys,
Trying to repair a pcb from a power supply's pool's robot ( KWADOO v.2), i can't identify the burned transistor Q3.
Could you help me ?
Thks a lot
Jean
Re: Help to identify destroyed transistor from a power supply's pool's robot KWADOO v
Looks like an LDO regulator to me.
Pin 1 GND, pin2 and tab Vout, pin 3 Vin?
Maybe something similar like an AMS1117
Or:
Pin 1 Vss/adj. pin2 and tab Vout and pin 3 Vin.
Pics aren’t that great to see where the pins go and what these resistors are. See where the pads connect to.
It looks like a SOT-223 transistor to me, emitter connects to ground, collector to clamp diode and the load, base to that resistor and then a via to somewhere else. Like BCE or GDS.
I would follow the base trace pin 1 to determine what it is; N-ch mosfet (goes directly to PIC MCU) or NPN transistor (through another resistor to PIC) BCP56.
The PC board is a bad design - the transistor copper-fill area for heatsinking has a cut or island around it, so the heat stays local.
The transistor burned up because it was overloaded, so fix that first.
Thks you both for your answers.
I think it was a transistor because of the inscription Q3. Under the microscope i could read the brand ON on the piece of the recto.After some researches, i found that it was perhaps a transistor P1F, but i'm not confident.If i follow the trace from the resistor (10 ohms), it goes to the negative of the two condensators ( ground ?)
If i found the type of this transistor, is it possible to replace it by one with three legs ?
Thanks a lot for your help.
Jean
We process personal data about users of our site, through the use of cookies and other technologies, to deliver our services, personalize advertising, and to analyze site activity. We may share certain information about our users with our advertising and analytics partners. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
