Help to identify destroyed transistor from a power supply's pool's robot KWADOO v.2
  • Jean4634
    • Jul 2022
    • 13
    • France
    Hi guys,
    Trying to repair a pcb from a power supply's pool's robot ( KWADOO v.2), i can't identify the burned transistor Q3.
    Could you help me ?
    Thks a lot
    Jean
  • CapLeaker
    Leaking Member
    • 8344
    Re: Help to identify destroyed transistor from a power supply's pool's robot KWADOO v
    Looks like an LDO regulator to me.
    Pin 1 GND, pin2 and tab Vout, pin 3 Vin?
    Maybe something similar like an AMS1117
    Or:
    Pin 1 Vss/adj. pin2 and tab Vout and pin 3 Vin.
    Pics aren’t that great to see where the pins go and what these resistors are. See where the pads connect to.
    • redwire
      • 3912
      It looks like a SOT-223 transistor to me, emitter connects to ground, collector to clamp diode and the load, base to that resistor and then a via to somewhere else. Like BCE or GDS.
      I would follow the base trace pin 1 to determine what it is; N-ch mosfet (goes directly to PIC MCU) or NPN transistor (through another resistor to PIC) BCP56.
      The PC board is a bad design - the transistor copper-fill area for heatsinking has a cut or island around it, so the heat stays local.
      The transistor burned up because it was overloaded, so fix that first.
      • Jean4634
        • Jul 2022
        • 13
        • France
        Thks you both for your answers.
        I think it was a transistor because of the inscription Q3. Under the microscope i could read the brand ON on the piece of the recto.After some researches, i found that it was perhaps a transistor P1F, but i'm not confident.If i follow the trace from the resistor (10 ohms), it goes to the negative of the two condensators ( ground ?)
        If i found the type of this transistor, is it possible to replace it by one with three legs ?
        Thanks a lot for your help.
        Jean
        • lotas
          • Jan 2016
          • 4811
          • Russia
          On p1f (sot-223) - pzt2222a
          • Jean4634
            • Jul 2022
            • 13
            • France
            Thks a lot, i'm going to search one in my junk.
            • magneh
              Behringer Eurolive B205D repair - help identifying transistor
              by magneh
              Hello
              Got this speaker from a friend , defective. Power led comes on and off , in a loop.
              Disassembled, got the board out, and after a bit of measuring I found a low resistance on a 5v6 line. With a bit of current I found a transistor heating up on that line (labeled T1 and 113 as on pic).
              After removing this guy, I got a value of 0.7 in diode mode on that 5v6 line, which before had 0.02 or something like that.
              I tested powering it up without the IC, and the speaker turns on and stays on, and works fine
              Still, I need to replace this transistor....
              06-18-2025, 02:34 AM
            • elsomer
              help to identify transistor msi ms-15ck1
              by elsomer
              hi people, i need some help to identify a transistor(q14) that is missing on the board, so the gpu has no voltage i think that q14 activate the phases for gpu, but i dont have schematic or boardview, but i think its the same transistor than q15 and q16, thanks...
              02-17-2025, 05:30 PM
            • rddube
              Help with blowing transistor NAD T752 receiver
              by rddube
              I guess I need help from the masters to try and find what is frying a 2SC5669 transistor on the left channel of this front center Amp for a NAD T752.
              Was working perfectly and all of a sudden I heard a pop, and then a glow from the amp. Not only did the 2SC5669 burn a leg, but R520 which is a 220 ohm resistor partially burned - it now measures 110 ohms.
              I bought this amp second hand fairly cheap as it was not working, it went into protection mode. I finally traced it down to the same transistor Q510, the one that just popped. It was shorted...
              09-01-2022, 05:19 AM
            • amigo744
              xbox series x u82 5 pin transistor voltages ?
              by amigo744
              hello there,
              xbox series x hdmi u82 transistor 5 pin,
              can anybody tell me voltages of this transistor in standby and power on mode ???
              on which pin of this transistor are the voltages ?
              regards
              08-16-2023, 08:05 AM
              AO4601 AO4601L Transistor (Applications Laptops) Datasheet
              Complementary Enhancement Mode Field Effect Transistor
              The AO4601 and AO4601L use advanced trench technology MOSFETs to provide excellent RDS(ON) and low gate charge. The complementary MOSFETs may be used to form a level shifted high side switch, and for a host of other applications. Standard Product AO4601 is Pb-free (meets ROHS & Sony 259 specifications). AO4601L is a Green Product ordering option. AO4601 and AO4601L...
              11-05-2024, 08:21 AM
