Xiaomi Roidmi EVE Pro battery died!
  • CidiRome
    • Jan 2015
    • 49
    • Portugal
    Hi there.
    I hope one of you may be able to help me.
    My Xiaomi Roidmi EVE Pro battery died.
    I disassembled the battery and tested the cells to find 2 dead and other 2 almost dead.
    I then dug some batteries from my notebook battery bucket and recovered 8 cells to rebuild the battery.
    Yet I can't get the BMS to start working again: the output is 0 Volts and it won't charge either.
    Did not try to put it in the robot yet, but I don't think the robot will reset the BMS...
    The current cell balance is good with a total voltage around 14.5V.
    Any Ideas?
    • Jul 2011
    • 4683
    Re: Xiaomi Roidmi EVE Pro battery died!
    Try this do you have an adjustable power supply if so try slow bringing of the voltage from around 0 volts to around 10 volts or so and then see if it will charge you might have to limit the current because some BMS protection board are weird like that I have a few of them that if you go over 2 amps they play dead but if you limit the current to 500 to 1000 milliamperes they work fine
    The other possibility is that the voltage is a little to high and the BMS protection board is locked out
    Or you need the third wire to activate the BMS protection board although I have not run across one yet like that
    If that does not work then maybe that is why the battery are dead the original ones and the BMS protection bad
    9 PC LCD Monitor
    6 LCD Flat Screen TV
    30 Desk Top Switching Power Supply
    10 Battery Charger Switching Power Supply for Power Tool
    6 18v Lithium Battery Power Boards for Tool Battery Packs
    1 XBox 360 Switching Power Supply and M Board
    25 Servo Drives 220/460 3 Phase
    6 De-soldering Station Switching Power Supply 1 Power Supply
    1 Dell Mother Board
    15 Computer Power Supply
    1 HP Printer Supply & Control Board * lighting finished it *
    These two repairs where found with a ESR meter...> Temp at 50*F then at 90*F the ESR reading more than 10%
    1 Over Head Crane Current Sensing Board ( VFD Failure Five Years Later )
    2 Hem Saw Computer Stack Board
    All of these had CAPs POOF
    All of the mosfet that are taken out by bad caps
    • CidiRome
      • Jan 2015
      • 49
      • Portugal
      Hello.
      Thank you for trying to help.
      It seems that the issue is this component that Sorin is referring to in this Video:
      https://www.youtube.com/watch?v=zVGD...ygUFZDZzYzQ%3D
      I will try to dig one from the battery bucket.
      Cheers.
        • Jul 2011
        • 4683
        Thank you for sharing this information and the link to it this will help me a lot with attempting to repair BMS protection board issues
        Could you please show a picture of where this fuse is located on your BMS protection board
        9 PC LCD Monitor
        1 Dell Mother Board
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8273
          deleted, I posted to wrong thread
          • CidiRome
            • Jan 2015
            • 49
            • Portugal
            Hello.
            Please check the attached picture.
            Hope it helps someone else.
            Cheers.
              • Jul 2011
              • 4683
              Originally posted by CidiRome View Post
              Hello.
              Cheers.
              Did you try to temporarily bypass the fuse and see if it comes back to life and functions correctly or not
              I would not recommend leaving with out the fuse if you plan on using this BMS protection board but just for testing purposes
              9 PC LCD Monitor
              1 Dell Mother Board
              • CidiRome
                • Jan 2015
                • 49
                • Portugal
                Hello.
                I know that it will work if I bypass it, because I get voltage in the cable if I short it with the tweezers.
                I ordered it to replace.
                Cheers.
