Anyone repaired Ionmax ION390? I have extra screws :(
  • Widget
    • Aug 2015
    • 74
    Re-assembling a Ionmax ION390 air purifier after removing the top LCD control panel, I seem to have 2 extra screws that I, for the life of me, cannot see where they go. I've taken a couple of pictures, buuuuut there's always that one picture you need, but you didn't take :/.
    I know it's a long-shot but has anyone repaired this before would have an idea?
    Last edited by SMDFlea; 04-27-2023, 01:26 AM. Reason: Added external images to badcaps
  • Widget
    • Aug 2015
    • 74
    Re: Anyone repaired Ionmax ION390? I have extra screws
    Not much luck with the screws, but it seems I have another issue. I noticed some legs were broken from what I assume is the LED backlight(?). Does anyone know the name of this part, whether it can be replaced or whether the piece I have is universal (ie I can get from Aliexpress)?
      • 31067
      lcd backlight is a good search term, i'v seen them but you need to know the size in mm.
      or you could try drilling out the leds and replacing them using clear glue/resin
      nothing to lose really
      • Widget
        • Aug 2015
        • 74
        Thanks for the reply STJ
        I've been looking around but haven't much luck finding the same style. I'm not too sure how they're designed either, or what all the dots do. Are the dots the LEDS or does the sheet just distribute the light? I'm assuming the dots aren't the LEDs but I'm really unsure of how it's constructed. It looks like transparent acrylic block layered with transparent film that has dots, layered with another layer of white film (I can only assume its to diffuse the light?)
        What sort of LEDs are used in the panel?
        I've taken some measurements of the panel in case anyone knows of a potential replacement off the top of their heads.
        [EDIT] Added more images. Had a closer look, looks like the LEDs enter into the acrylic piece though it appears to be domed, the remnants of the old LED seem to have a flat surface. Any clues what they might have used here?
          • 31067
          the dits are a defuser pattern,
          they usually just use 3mm leds
          • redwire
            • 3910
            I would say it used wide angle square LED's crazy glued/tucked into the notches, what size are they?
            They come in 2x3x4mm or bigger longer like 2x3x7mm. You want the ones with the LED die up close to the end, not way back in the plastic = wide angle. Like this Aliexpress kind of thing.
            It looks like the cutout is for a 3mm T-1 LED. They just glue them in.
            • Widget
              • Aug 2015
              • 74
              Hey redwire, thanks for the reply . I think you may be right. I feel they are the square/rectangle shaped LED bulbs, like you've linked but likely clear Blue coloured.
              I used some digital calipers and the measurements I got were, 2.7mm thick for acryclic, the hole is 3mm wide, 4mm deep & it looks to be 2mm thick, which match the dimensions in the link you posted.
              Visually it looks like it take the domed (T1?) bulb, but upon inspection, it looks like the LED in there has a flat square shaped. I used some tweezers and was able to put them into the top of the dome and it went down, so it didn't appear there was any casing in that section if that makes sense (see pics). Also wondering if it's worth trying to find those leds in 'ultra bright'? Not sure how much light is produced at a wave-length of 460-465NM
              If the old LEDs are glued in, do you reckon solvents (IPA or Acetone) would break down the glue?
              • redwire
                • 3910
                Sometimes it's higher risk to do a perfect repair and I settle on something good enough.
                You can try take a dental pick and scrape out the old glue without scratching the edges...
                Acetone is the best solvent for cyanoacrylate, but if it eats the backlight diffuser plastics... as it does eat acrylic plastics... the damage and mess gets worse.
                If an LED dry fits, then I would just glue in the 3mm or square LED and keep the repair simple. White/blue LEDs are crazy bright as they are, to get more brightness, using more current for them would take a resistor change on the board.
                • Widget
                  • Aug 2015
                  • 74
                  Thanks for the feedback redwire . You're right about the Acetone, good suggestion. I'll try dry-picking it out, see if I can do it that way.
                    • Jul 2011
                    • 6040
                    Thanks for sharing this link I have need some several times and could have used some to repair some back light for displays but luckily I have several replacement controller boards for my desoldering station so have not been desperate enough to ask for help finding them yet
                      Lenovo ThinkPad T16 + Extra 8GB memory Notebook Specification for Upgrade or Repair
                      This specification for the Lenovo ThinkPad T16 + Extra 8GB memory Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T16 + Extra 8GB memory boardview and T16 + Extra 8GB memory schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                      09-07-2024, 06:21 AM
                    • howardc64
                      by howardc64
                      Problem
                      08-04-2024, 10:36 PM
                    • chronic519
                      Mats / mods: detected and repaired GPU fault. Cant seem to test after!
                      by chronic519
                      Hello.
                      GPU came in, green lines. Spent lots of time using to get the Mats / mods drive working (found on youtube).
                      Found issue with a RAM block
                      Replaced, green lines gone.
                      Trying to test again, assuming getting the false positive. Originally had over 1K on a single bank. Now getting tosses low between banks.
                      Used a good card to test and same results low errors 32+.
                      I am just search for some form of command to do a full test on the GPU.
                      I just ran the mats command with my good GPU and passed after roughly 40 min.
                      The repaired one, ran...
                      05-20-2025, 07:56 PM
                    • jimmyboy111
                      Repair Log - TCL ROKU 65S4 BACKLIGHT DEAD
                      by jimmyboy111
                      Hopefully I can save someone some time or maybe they can avoid fixing these garbage epoxied TV sets
                      .. stripping down was a pain .. tons of screws all along bezel edge .. the top of the glass LCD panel is glued to the casing (for a reason)
                      .. all in all took around 4-6 hours to repair teardown .. swap .. reassemble .. current adjustment and then burn in and extra evening
                      .. single blown backlight led top left row .. 3030 5.5v (6v) .. I had some in stock from another set
                      .. swapping LED no problem .. one bad led .. the solder pad under this LED is normal .. no...
                      02-01-2022, 11:33 PM
