Looking for Suitable Relay Replacement.
  • Benass
    • Oct 2020
    • 73
    • Uk
    Hello. I have Industrial Washing Machine PCB.
    Customer Requested Relays Replacement.
    I can't find WJ115F1 relays to buy. Looking for some help to identify possible alternative solutions.
    Or any tips, on how to approach this situation.
  • petehall347
    • Jan 2015
    • 4426
    • United Kingdom
    Re: Looking for Suitable Relay Replacement.
    try suppliers websites and use the filters to narrow it down .
    • lotas
      • Jan 2016
      • 4602
      • Russia
      https://www.ebay.com/itm/304003549326
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        what is it controlling? How close are you cutting?
        That CUI devices probably will work. Sometimes manufacturers assume worst case (using the NC switch), some manufacturers assume best case current ratings (using the NO switch) so you have to watch out for that.
        That seems to be a standard case type as well but not sure what it's called...
        • redwire
          • 3910
          The relay is the very popular Potter & Brumfield/TE "T90" series format BUT has a high 40A contact rating which makes it a bit big. These relays are usually 30A/2HP rated long life, but it depends on the safety agency.
          I don't think you can truly get 40A through the pins, PC board and connectors, there's just too much heat.
          Cheaper Songle SLA T90 30A, Song Chuan etc can be looked at as well.
          • Benass
            • Oct 2020
            • 73
            • Uk
            Sorry was afk for a while.
            This is an Industrial Washing machine board. I got a request thro whatsapp to look into possible replacement of all relays(9 in total)
            It comes with an error Relay related on the screen.
            I was looking for alternatives and T90 does come as one. I will have to look at it
              • 31028
              nice ceramic fuse, is the clip loose? why did it arc?
              • redwire
                • 3910
                It must have arced to nearby metal chassis or something... ahead of the fuse too. Maybe a mains transient?
                I don't think I would take on the job, not simple work as it appears.
                These relays can be really tough to desolder because they have huge pins and heavy copper on both sides. You need a lot of heat.
                You can see they cheaped out on the board and omitted the RC snubber networks by the big connectors, all 10 of them. These greatly add contact life by reducing relay contact arcing. And they omitted two MOV's. It's no longer a long life board. Ick.
                • r2digital
                  klipsch kda-500 amplifier suitable power supply capacitor replacement ?
                  by r2digital
                  I have a klipsch kda-500 that would turn on and allow me to get into the web management but it was picking up a lot of noise from audio sources so i decided to replace the smd caps on the power supply along with radial one. Some one was in here before me and they basically burned the bottom side of the traces off for the radial cap but i was able to repair it without any real problem. I thought i did a good job sourcing out replacement caps but apparently not and now i can't get the power supply to turn on it just constantly try's to keep turning on. Attached is a picture of the power supply before...
                  04-18-2024, 03:50 PM
                • ezenia
                  Suitable replacement IC? .PCB - X_BFJSFANRE_RLED_V4
                  by ezenia
                  I am not sure where exactly to put this thread, so hopefully this is the best place.
                  I have a USB fan that has suddenly been unable to increase its speed. It's just stuck on the first speed. This fan has 3 speed settings. Each time you press the power button, the speed of the fan should increase.
                  The way the button works with each press is: Speed 1 > Speed 2 > Speed 3 > OFF
                  Speed 2 and 3 don't currently work any more.
                  I suspect the issue might be with what looks to be some kind of driver IC. It is a 16-pin...
                  06-20-2023, 05:22 AM
                • valvashon
                  Repair Success! Middle Atlantic UPS2200R-IP
                  by valvashon
                  Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
                  Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
                  02-06-2024, 12:54 PM
                • fytonv
                  7 channel NAD receiver,Need help identifying a suitable cap replacement
                  by fytonv
                  My 7 channel NAD receiver has audio quality and volume issues on 2 of the channels. Sometimes they work and sometimes they don't. Sometimes they're at about half the dB level of the left channels, and then they cut out entirely. Powering off and on the receiver fixes it for a bit.
                  Without much experience to really know for certain, they only apparent issue I can see is with these electrolytic capacitors on the power supply. Bulging = bad, correct? I'm looking for replacements but I'm unsure what leeway I have with the temp ratings. Are there any other specifications I need to worry...
                  09-08-2022, 09:52 PM
                • vball
                  bad relay - looking for a replacement
                  by vball
                  Mouser #:653-G4B112T1FD130A24
                  Mfr. #: G4B-112T1-FD-US-RP-T130 AC24
                  I had a relay go bad in my Kenmore vacuum and it is no longer in stock from any appliance parts sites. I found the relay on www.mouser.com with numbers above.. but it is also not available from mouser. Can someone knowledgeable suggest an equivalent substitution from the mouser site?
                  Thanks,
                  Joe
                  08-21-2021, 12:34 PM
