Burnt Resistor Value
  • mferna14
    • Jun 2018
    • 1029
    Hi all, This is my Coffee maker main board. Last week there was an electrical surge & it blew out the fuse and this 2 watt resistor. Can anyone figure out the value of the resistor. It on the AC line, hope someone can help view this attached photo or if anyone has this schematics. Thanks in advance.
    • 31091
    Re: Burnt Resistor Value
    you have bigger problems, that burned because something downstream is shortcircuit.
    • mferna14
      • Jun 2018
      • 1029
      Thanks for the reply.. If you see the photo close, before the resistor there was a thermistor which was burnt too, this was shorting the AC lines, once replaced the short was 100% gone & there are no shorts further on in the circuit. Now it's only the resistor value I need to know to repair this board. If anyone can help me finding this Value, by the shape I know it's 2 watt. Thanks
      • redwire
        • 3910
        What make and model of coffee maker is this? We aren't psychic.
        The dropper cap must have shorted.
        • R_J
          • 9558
          It is a wire wound resistor, so you may be able to get a resistance reading between the broken wire in the middle and one end. that might get you close to the value.
          My guess is it is a Braun KF7000BK
          • mferna14
            • Jun 2018
            • 1029
            Yes this is a Braun KF7150BK.. I checked the resistance, but meter shows no value.
            • R_J
              • 9558
              You won't get a reading ACROSS the resistor you will need to clean part of the exposed wire to get any reading, This value should be close to half the original value. You could also provide a clear picture of the trace side, maybe we can figure out a close value.
              • mferna14
                • Jun 2018
                • 1029
                Thanks R_J., will do that & inform you...
                • CG2
                  LED uplighter dimmer burnt resistor
                  by CG2
                  I've got a 240v LED uplighter which isn't working. Pulling it apart shows a clearly burnt resistor on the circuit board, and I'm hoping some of you will have suggestions on what to replace it with. First, here are some photos. Power comes in, through the fuse and choke, then through the big blue variable resistor labelled B500K (ignore the similar blue component at the bottom - it's a simple switch for an attached reading lamp). It then passes through the burnt resistor (or at least did once), through diac DB1 and the unburned 30 ohm resistor to the gate of the triac.Now I assume there's a simple...
                  02-14-2024, 09:23 AM
                • trickartt
                  Allen & Heath Xone:02 (DJ Mixer) - Burnt out Resistor
                  by trickartt
                  Hello Badcaps!
                  I am trying to troubleshoot my Allen & Heath Xone:02 DJ mixer. I have had this for somewhere close to 20 years and have played music through it in one form or another pretty much every single day since I've had it, though these days it's usually from a wireless streaming receptacle (Apple Airport) more than the turntables that are also connected to it.
                  This week my music stopped working, and after a bit of a wild goose chase, I realised my mixer was dead. I checked the 500mA fuse in the device beside the power supply and found it was blown, so I replaced...
                  05-04-2024, 12:07 PM
                • sparcktikus
                  Ersa Rds 80 soldering station burnt resistor
                  by sparcktikus
                  Hi
                  I have an Ersa rds 80 soldering station which has developed a fault and just showing err on display
                  I have found a burnt resistor on pcb can anyone help me identify this resistor if you have a circuit diagram or similar unit
                  The printed circuit board markings are rd80 ver 2.0 and the resistor in question is R6
                  Many thanks...
                  04-04-2023, 04:29 AM
                • jinu_j
                  by jinu_j
                  Hi
                  05-03-2025, 10:51 PM
                • mikey5791
                  Need help to replace burned resistor in 350w atx psu
                  by mikey5791
                  Hi to all forum members,
                  Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                  The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                  Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                  Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                  12-26-2024, 04:55 AM
