Meaning of one simbol in schematic
  • harp
    • Jun 2022
    • 645
    • Planet Earth
    please tell me what means simbol with curved arc (like headphones) on shematic? Why is there and can it be omitted?
    Also, I wish to build device like that, with isolation transformer and variac, so seek to achieve a expert tip about that, maybe schematic with some genius feature (some switches, lights, etc...) on it that work wery well in practice. I see few videos where sugested only that ground is not connected, nothing else about featured and usefull control.
    • 31269
    Re: Meaning of one simbol in schematic
    it indicates a link between 2 points or a removable connection.
    very strange to find it printed on the front of something though.
    • redwire
      • 3912
      The symbol is for a circuit breaker. So there are two plus a fuse for the variac's protection. I think it's a thermal circuit breaker, so the curved element heats up and pops up.
        • 31269
        i would put a switch on the ground connection.
        sometimes it's good, but if you connect something that has an earth-bonded psu then it can partly bypass the isolation
        • redwire
          • 3912
          With an isolation transformer, do not ground one (output) leg or it defeats the entire purpose of using one, it is no longer isolating pri-sec.
          I can't think of when you need to ground an isolation transformer's output.
          People misinterpret electrical safety codes which want all (mains) power transformer's secondary grounded to make a neutral.
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8706
            WTF that schematic is really wrong. That has a variable resistor there instead of a true variac... So while that is a circuit breaker, take the schematic with a grain of salt.
            • harp
              • Jun 2022
              • 645
              • Planet Earth
              Oh, I forgot all to thank you!
              • TinkerTron
                Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                by TinkerTron
                Hey everyone,
                I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                Instead, here's what's been bugging me so far:
                The schematic...
                03-06-2025, 02:03 PM
              • atunguyd
                Acer x163w Monitor PSU schematic
                by atunguyd
                Ii wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
                The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...
                03-05-2025, 02:08 PM
              • Thetechdude
                MSI Ventus RTX 4080 16G Broadview schematic needed
                by Thetechdude
                Hi guys, I'm working on a MSI Ventus RTX 4080 16G. The GPU has 12v, 5v, however what I assume is the 1.8v rail has 1.1v and what I assume to be PEX is 0v. As you may have guessed already there is no Vmem and no Vcore.
                I have looked around in related forum posts for a schematic so Much appreciated if anyone can share a Broadview schematic.
                Thanks.
                07-15-2025, 11:15 AM
              • ianpoultonknights
                Zenbook Flip 15 UX562AI schematic
                by ianpoultonknights
                Had one of these come in for repair with a blown battery and a WiFi issue, battery has been replaced with genuine battery (twice) and won't take a charge works fine on AC, WiFi issue gone away. Looking for a schematic so I can trace the charger circuit UM562F is only one I can find, this is the 562AI model.Had a unit come in for repair — 562AI model — with a blown battery and WiFi issue. WiFi fault has cleared, but battery won’t charge despite replacing it twice with genuine parts. Device operates fine on AC power. Suspect charger circuit fault. Only schematic I’ve found so far is for...
                06-26-2025, 02:41 PM
              • Adv10119
                Need help please! schematic for LA-9982P rev 3.0 (A02)
                by Adv10119
                Please help, i need schematic diagram for Dell inspiron 3537 board LA-9982P rev 3.0 (A02). Specific for A02.
                I have a one beep with no display problem. Did reprogrammed the bios but no luck. i tried to troubleshoot using rev 3.0 (A08) version schematic and boardview but there's components/rails in the schematic that is none in my actual board, this is why I'm having problem checking every power rail needed if ok. attached is the photo of my actual board.
                I'm not sure if A02 and A08 is really different schematic version from each other, but I have to try....
                01-31-2024, 01:18 AM
