wearing out mechanical D'Arsonval movements?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    I was wondering if it's possible/has anyone been able to wear out the bearings of a mechanical meter purely by using it?
    I suspect that connecting an AC voltage to a DC meter will vibrate it fast but does not do much movement, but what about a 1Hz source or something like that, would it cause enough wear over time to cause a D'Arsonval movement to wear out and break/become inaccurate?
  • redwire
    • 3910
    Re: wearing out mechanical D'Arsonval movements?
    There's many different types and quality for analog panel meters. I've never seen one really wear out, although I have one edge-wise from a trucker's CB radio that got sticky, I think damaged from vibration. It's a Taiwan cheap build.
    Better, older meters used sapphire jewel for the pivot but I think friction-less taut-band is used nowadays.
    "Conventional pivot-and-jewel meters often required bearing replacement after less than one million cycles."
    "... no movement deterioration was encountered on the taut-band meters after 50 million full-scale oscillations."
    "Particularly severe service conditions have demonstrated the stamina of the taut-band design in the field. One railroad reported that pivot-and-jewel ammeters on diesel locomotives required frequent repair, with overhaul and recalibration typically after eight months. Occasionally servicing was needed after only 30 days. Taut-band instruments in this same service for four years required calibration adjustment only twice, with no parts replacement."
    https://www.weschler.com/blog/the-ta...-analog-meter/
    If you have AC wiggling the needle, it gets smoothed out by the needle and mech mass as well as the shorted-turn damping on the moving coil. The meter's rectifier gives 2X freq. ripple so say 120Hz you can hear it.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      I suppose that damage from shaking the whole unit or other environmental damage (dirt, water, oils, dropping, etc.) shouldn't count towards its "best case" longevity - assume that it's in a clean, fixed location environment. But it seems like these should last a very long time, wondering if springs break after use a significant amount of use or not, also the difference between fast (take less than 1 second to stabilize) and slow (possibly take 2-3 seconds to stabilize) settling meters...
      • redwire
        • 3910
        I think a panel meter's enemy is shock and vibration. The springs are coil like clock springs or taut-band and seem to not fatigue fail.
        In the old days, for shipping, you shorted a panel meter out with a piece of wire to prevent the needle from banging around, block generator-action.
        The slow meters seem to have heavier mech to dampen out noisy signals. There is a counter-weight as well. It depends on the meter's sensitivity as lower FSD say 100uA movements are wimpy compared to say 1mA which have more torque.
        I have some old Simpson VU 142 4" meters and they are super fast, very lightweight needle.
        • eccerr0r
          lowest current galvanometer/analog meter (passively powered!)
          by eccerr0r
          Most analog meters are actually current driven - a current is needed to deflect the pointer full scale. They can be lots of different values. There are ones that can take several amperes to swing the pointer as they have internal shunts.
          On the other hand there are many that are rated in microamps for the intent that they draw as little power as possible from the devices under test. Some are 1mA, 500µA, 200µA, 100µA, and the ubiquitous 50µA frequently used in analog VOMs. There are even 20, 25, 30 µA and even down to 10µA. Been collecting a bunch of different ratings and...
          04-16-2025, 12:41 AM
        • abajor
          Evaluating Mechanical Hard Drives SMART Data in Linux (Ubuntu) Using the Disks Utility.
          by abajor
          I've gotten into the habit of Looking at peoples Mechanical Hard drives with a Ubuntu thumb drive to boot their system.
          I understand the raw values are not really uniform between manufacturers, but I have noticed that high seek and read error raw values at the very least correlate to a drive that is going to have sub par access time, and extremely slow OS booting.
          The odd thing is I've often seen very high seek and read error rates on drives with fairly low on time.
          Does anybody have any other takes on evaluating smart data? I've used Crystal Disk Info, It seems to present...
          04-23-2024, 11:43 PM
        • RolandVossen
          JVC VHS : what is the mechanical function of the 'slider cam' ?
          by RolandVossen
          Dear reader,
          I am (trying to) repair a JVC HR-D530E VHS recorder. The problem was that the tape is not ejected. Pressing 'eject' results in some whirring of the mechanism, after which the machine shuts itself down. I discovered that if I fiddle with a mechanical part on the bottom (the so-called 'slider cam'), that the problem temporarily goes away. In the attached photo, it concerns that part within the red 'ellips'.
          I noted that the 'slider cam' actually consists of two pieces that can slide a bit over each other (denoted with '1' and '2' in the photo). When sliding...
          01-01-2024, 06:43 AM
        • dicky96
          Need LAN connection over several hundred meters - how to do this?
          by dicky96
          Hi guys
          Here is a project I have been working on. I am supplying a company who have a license from the government to re-open the open air markets which have been closed due to COVID-19
          They have to fulfill certain restrictions to open the markets, we are currently three weeks into an eight week trial.
          The main requirements are:
          1. The temperature of every person visiting the market is taken.
          2. There is a capacity limit of how many people can be in the market at a given time, and it must be observed.
          3. Everyone must wear a mask (Actually...
          11-05-2020, 12:15 PM
        • SimsonS53
          Asus RoG Strix GL553V - Keyboard Dead
          by SimsonS53
          Good day,
          it just so happen that I got my hands on a Asus RoG Strix (GL553VD ~2017),
          in absolute mint condition. But with a "dead" keyboard.
          I checked all the obvious stuff:
          Condition of the connectors, there is absolute ne evidence of liquid damage or mechanical stress. As mentioned, absolute mint condition, as it was actually never used.
          All keys have no function at all, and doesn't work in the UEFI.
          So I don't think it's an software/driver related issue.
          I also set the UEFI to defaults to verify it's no software issue.
          07-23-2023, 10:19 AM
