hard drive logic board Diode identification
  • ntec
    • Jun 2020
    • 55
    I need to replace this small diode that is found on the logic board of a hard drive. What type of diode is this so I know I buy the correct one.
  • R_J
    • 9579
    Re: Diode identification
    What type of drive? there are different types.
    Where is the diode in the circuit? is it across the supply voltage? if it is it is likely a zener or TVS diode
    • kasfamily
      • Aug 2014
      • 774
      • Russia
      Re: hard drive logic board Diode identification
      It looks like this BZX585-C3V3
      • Aliencomputres
        • Aug 2019
        • 210
        • România
        If its a protection diode,remove it and recover data.Dont use furter without diode !
        • CapLeaker
          Leaking Member
          • 8286
          The hdd should turn on without that TVS / zener diode installed, but you loose over voltage protection. The new PSUs where you can disconnect unused cables aren’t standardized. So a Thermaltake cable.will fit in an EVGA PSU, but it reverses the voltages on the sata end. And then exact this will happen when you turn the computer on the first time. Guess how I found out.
          I’ve replaced the diode and kept the HDD running. Got over 8000 hrs on it, no problem.
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8701
            The new PSUs where you can disconnect unused cables aren't standardized. So a Thermaltake cable.will fit in an EVGA PSU, but it reverses the voltages on the sata end.
            I was recently looking at my Antec NeoHE "modular" and a random SATA power cable that seemingly uses the same connector. As skeptical as I usually am I tried tracing the wires on the cable, and lo and behold: the wires don't go in the same order. Might have saved a zener diode's life here...
            I wonder how many versions of the cable here, surely hope it's not all 180-odd combinations...
            • CapLeaker
              Leaking Member
              • 8286
              Here is my old venture:
              https://www.badcaps.net/forum/showthread.php?t=58320
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                I ended getting a 12v to 5v dc-dc converter. It didn't work, output was shorted. Turns out there was a zener crowbar that was fried and melted the plastic case.
                Oddly enough it isn't obviously clear which connector is input and output for the dc-dc converter, so guess what happened...
                • karto95
                  Repairing a Seagate hard drive with damaged logic board
                  by karto95
                  I'm currently facing an issue with my Seagate hard drive that has a damaged logic board. I've obtained a replacement logic board from a donor hard drive, but unfortunately, I'm unable to recover the BIOS of the original board due to damaged firmware. I'm wondering if it's possible to make the hard drive work with this donor logic board.
                  I have a CH341A programmer, so I'm hoping that it can be useful in this situation. I've attached the BIOS file .bin of the donor board for reference.
                  If anyone has any suggestions or experience with this...
                  03-21-2023, 04:05 AM
                • m1ch43lzm
                  by m1ch43lzm
                  05-12-2025, 08:37 PM
                • ohren
                  by ohren
                  09-08-2023, 05:24 PM
                • Greenacre
                  Netgear NAS RN21400 logic board.Part Identification Diode
                  by Greenacre
                  Afternoon, I hope someone is able to help me identify this components value. It is faulty. The markings show 633 and LG.
                  This is form a Netgear NAS RN21400 logic board.
                  Thank you all in advance. I have attached the image showing the component in place on the board. I have removed the Power port.
                  I apologise if I have posted in the wrong place. I couldn't find a forum for part identification or NAS stations....
                  03-31-2022, 08:11 AM
