BAUN - UVST - 0617,Can anybody Identify these Please?
  • Ritchie_Uk
    Prawnography
    • Mar 2021
    • 185
    • Uk
    Re: BAUN - UVST - 0617,Can anybody Identify these Please?
    Hey R_J I need to re-check in a few hours, so I don't give you false information.
    I will attempt to draw out a basic schematic.
    Originally posted by R_J
    Here is a photo of the MicrOne version, the logo and markings are different, but I suspect the operation will be the same.
    I asked if you traced out the pins to see if this is the same ic, For example, pin 3 seems to connect to CON3, is this where the battery connects???
    • Ritchie_Uk
      Prawnography
      • Mar 2021
      • 185
      • Uk
      Hey Noppa -Thank-you
      I can't wait to check in a few hours, as it's late now
      • Ritchie_Uk
        Prawnography
        • Mar 2021
        • 185
        • Uk
        Noppa - Would you happen to know what SOT it is please?
        I know it's cheap, and the moment I collected it, it wasn't worth the repair, but it's for a friend.
        I love problem solving
        Thanks again..
        • Ritchie_Uk
          Prawnography
          • Mar 2021
          • 185
          • Uk
          Hi Petehall
          Sorry, I missed your post
          what is the black socket on the right for ? u1 looks like it may connect to it
          • R_J
            • Jun 2012
            • 9594
            I know it’s cheap, and the moment I collected it, it wasn’t worth the repair, but it’s for a friend.
            Thanks again..
            The TP4054 is a sot23-5, just look at the datasheet, the XX4054 seems to be made by may companies with a slightly different part number
            After a closer look at the picture in post #10, I see CON3 is the battery connector, so this must be the correct ic.
            • Ritchie_Uk
              Prawnography
              • Mar 2021
              • 185
              • Uk
              #26
              I think this might be the Manufacturer
              http://www.hjc-ic.com/en
              • R_J
                • Jun 2012
                • 9594
                They are a distributer not a manufacturer. Just pick your favorite parts supplier and order one.
                • Ritchie_Uk
                  Prawnography
                  • Mar 2021
                  • 185
                  • Uk
                  #28
                  Aah Ok let me look
                  • Ritchie_Uk
                    Prawnography
                    • Mar 2021
                    • 185
                    • Uk
                    #29
                    Hi R_J
                    You are correct, the CON3 is the internal Battery
                    I will look for a replacement, and see if I have any on old Laptops
                    Its been an uphill struggle ans Manufacturers and component suppliers really Wont or dont Help, so the folk sin this Group have really helped go in the right direction
                    Will Keep you updated
                    Stay Safe
                      • 31214
                      tp4054 on aliexpress
                      you get 10 for a $
                      • Ritchie_Uk
                        Prawnography
                        • Mar 2021
                        • 185
                        • Uk
                        #31
                        Thankyou stj
                        I was starting to worry where to get one from.
                        I have started to use ebay, a couple of weeks ago.
                        Would you know of a trusted supplier, or shall I just use Aliexpress?
                        I was scammed already last week.
                        Stay Safe !!
                        you get 10 for a $
                        • Ritchie_Uk
                          Prawnography
                          • Mar 2021
                          • 185
                          • Uk
                          #32
                          Thankyou stj
                          is it related to a lithium battery?
                          ME4054?
                          http://www.microne.com.cn/ProductDetail.aspx?id=100
                            • 31214
                            https://www.aliexpress.com/item/32769860761.html
                            change the shipping option to:
                            AliExpress Saver Shipping
                            the default one - "Cainiao Super Economy" is slow as fuck and often loses packages!
                              • 31214
                              where in London are you?
                              • Ritchie_Uk
                                Prawnography
                                • Mar 2021
                                • 185
                                • Uk
                                #35
                                Watford Hertfordshire
                                • Ritchie_Uk
                                  Prawnography
                                  • Mar 2021
                                  • 185
                                  • Uk
                                  #36
                                  stj - Thankyou for the useful Tip
                                    • 31214
                                    yes, i know it well - right in the center of London /sarc
                                    • Ritchie_Uk
                                      Prawnography
                                      • Mar 2021
                                      • 185
                                      • Uk
                                      #38
                                      stj 😂
                                      Every time I mention my town, I have to explain for 5 minutes, where it is
                                      Shame you wernt closer, I had about 10 Laptops I got rid of.
                                        • 31214
                                        for 10 laptops i would jump a train to watford.
                                        reason i asked, a lot of people say London when they arent in london.
                                        i got stung once, bought a heavy item on ebay with the intention of collecting and then the fucking seller said he was on the border of kent - the coastal facing border!
                                        • Ritchie_Uk
                                          Prawnography
                                          • Mar 2021
                                          • 185
                                          • Uk
                                          #40
                                          I got scammed 2 weeks ago
                                          I advertised a TV in the Buy/Sell section on Badcaps that has a good screen, and are hard to get hold of
                                          If I ever get anymore Laptops, you are free to pop over, I can give you my address.
                                          • thesame
                                            DVR HIKVISION DS-7208HWI-E1/A BOARD DS-80104 REV 2.2 help identify burnt components
                                            by thesame
                                            Hy guys , i have a DVR board DS-80104 REV 2.2 that was powered wrong, i have some smds on the board that are blown and i can't identify them , maybe if someone has this board somehow and we can identify the smds', i have searched online and i can't find a schematic.
                                            The smds are SOT-23-6 , one of them i think it has the marking ADJF since i found another one on the board with this marking , but the other one it seems that it starts with AG or it looks like. I would really apreciate if someone could help me identify those IC's .
                                            02-27-2024, 04:31 AM
                                          • silver60618
                                            Lenovo Legion 7 - Help Identify IC
                                            by silver60618
                                            Hi gang, its a long shot, but working on Lenovo Legion Pro 7 motherboard NM-F091, and trying to identify this component near GPU with marking "eHFQH" that is burned and shorting the board. Looks like power management IC
                                            I couldnt find any schematic or boardview. The CPU side also has same chip. Any way to identify this chip? or take measurements from the good chip to determine what it is?
                                            Any help would be appreciated...
                                            07-02-2025, 12:16 PM
                                          • chth96
                                            How can I identify varistor which have been blew up?
                                            by chth96
                                            I mistakely pluged 100v japanese retro game console to 220v outlet.
                                            So It seems that glass fuse and varistor have been blew up.
                                            I can identify that voltage and ampere value of glass fuse(250V LF 1.6A),but It is impossible to identify varistor type in my sega saturn PSU(YAMAHA 35M07U XR258)
                                            Is there any way to identify varistor type in my sega saturn PSU?
                                            Any reply would be appreciated.
                                            EDIT:
                                            It seems that I finally found out what type this black varistor is. It is Panasonic ERZV05D221 “ZNR” Transient/Surge Absorbers (Type D) Varistor Voltage...
                                            11-26-2023, 08:52 AM
                                          • freakorio
                                            Need Help To Identify Component on Ymain LJ41-05120A
                                            by freakorio
                                            Hi guys , i hope this is the right place , i got Plasma Samsung PS-50Q91H and i need to repair Ymain LJ41-05120A , but those component are burn and i can not identify to replace those part , and the part are blue capacitor and the location are C5105 and C5106 and here i attach the part that need to identify , and one more thing , i also need to replace Zener Diode on location ZD5502 and the part are BZV55C because mine is short but i don't know the voltage because those parts are release with many type of voltage. Looking forward for your kindly reply
                                            05-21-2024, 02:32 AM
                                          • baiceanu_stefan
                                            nm-f251 Schematic, boardview or help identify componente
                                            by baiceanu_stefan
                                            Hello, I have a legion pro 5 16arx8 serial number pf4bf4aw mb code nm-f251 rev1.0 which was dissasembled by the client for cleaning. Now it does start but for 20 secs after that fans run at maximum and then shut down. Found PU8302 burned but cannot identify it the part. It is written eHFAA on it but didn't found any info, no boardview, nothing. Can anyone help identify the part so I can order it from somwhere? Ataching some pictures of the motherboard, serial number and part. Than\k you...
                                            04-24-2024, 12:49 AM
