4056 Chip
  • giulio93
    • Aug 2021
    • 258
    • Italy
    4056 Chip
    Hi everyone. I have this laser saber mobo that fails (the sword is totally death). I noticed a hole in the top right chip. I can read from the chip 4056 2043. I don't know the company who mades this chip ( i don't recognise the simbol). I have some questions.
    Is it the chip for the lipo charge?
    Can I replace with another 4056 chip? I found a lot of chip named in that way.
    I found a lot of chip 4056 but with a TP at the beginning of the name. Is the same chip?
    I need some programmer to reprogram it (like bios chip) or not?
    Thank you
  • petehall347
    • Jan 2015
    • 4431
    • United Kingdom
    Re: 4056 Chip
    Q5 looks cracked
    • giulio93
      • Aug 2021
      • 258
      • Italy
      Re: 4056 Chip
      Q5 looks cracked
      the 4056 ?
        • 31154
        Re: 4056 Chip
        what is "CH" ?? a speaker?
        • giulio93
          • Aug 2021
          • 258
          • Italy
          Re: 4056 Chip
          the white and yellow lines come to the control button.
          • giulio93
            • Aug 2021
            • 258
            • Italy
            Re: 4056 Chip
            Q5 looks cracked
            I see it know. This should be good to replace it
            https://www.ebay.it/itm/173122873712...wAAOSwjXNaa3-b
            My doubt stay for the 4056 chip.
            for exaple this is good?
            https://www.ebay.it/itm/363356997400
              • 31154
              Re: 4056 Chip
              it's not the charger is it?
              • R_J
                • 9580
                Re: 4056 Chip
                The tp4056 is a li-Ion charging ic, Here is a link to a charger module with the same brand ic https://www.amazon.com/Battery-Charg.../dp/B07PDLPNDX
                The prog (pin2) is just done with a resistor to set the charge current, no programing required. It looks like a bit of hot glue on Q5 and not cracked
                • giulio93
                  • Aug 2021
                  • 258
                  • Italy
                  Re: 4056 Chip
                  Ok, so the chip I linked it's ok?
                  • giulio93
                    • Aug 2021
                    • 258
                    • Italy
                    Re: 4056 Chip
                    I desolder the chip and this is what under. It is normal to have the connection between the Central bad and the top right and the third right?
                      • 31154
                      Re: 4056 Chip
                      that confirms it's not a tp4056 charging chip
                      • giulio93
                        • Aug 2021
                        • 258
                        • Italy
                        Re: 4056 Chip
                        Is there a chance that cleaning the pads has detached the green layer? That I did damage? Cause the chip in the pics you posted is exactly the same as mine. The only difference is the "1610"
                        • R_J
                          • 9580
                          Re: 4056 Chip
                          It is a ME4056SPG from Microne, here is the datasheet, see page 16 (Suitable for charge status indicator, which the application not need battery’s temperature detection)
                          • giulio93
                            • Aug 2021
                            • 258
                            • Italy
                            Re: 4056 Chip
                            Is it a chip that manage the lipo charge ?
                            this one is good? https://it.aliexpress.com/item/40001...rch-mainSearch
                            • R_J
                              • 9580
                              Re: 4056 Chip
                              Yes, That is the same ic, the last number (1650) is a date code.
                              • giulio93
                                • Aug 2021
                                • 258
                                • Italy
                                Re: 4056 Chip
                                Ok guys I replaced both the IC and the other chip (a diode?). Now the laser saber is charged properly and the light works fine. But I have a problem. The saber doesn't emitt any sound but when it turned off. So the speaker works. It should be make sounds when you move it quickly. Any ideas?
                                thanks
                                  • 31154
                                  Re: 4056 Chip
                                  how does it sense movement?????
                                  • giulio93
                                    • Aug 2021
                                    • 258
                                    • Italy
                                    Re: 4056 Chip
                                    I dont know. but before the fail, the saber sword emits sounds when you move it quickly and when you hit something with it. Do you need a motherboard back's pic?
                                      • 31154
                                      Re: 4056 Chip
                                      probably need full pics of both sides and a list of whats on all the wires
                                      • smic717394
                                        • Jun 2017
                                        • 95
                                        • Spain
                                        Re: 4056 Chip
                                        Hi, I have a similar problem the saber was dear, so I removed the battery and give it a push with the bench power supply reconnect the battery and for a second the saber came on, the dead, so I removed the battery and tried again to charge it again, this time I think I put the battery the other way around, but nothing happened, so I removed the battery and try to charge it again , putting the battery the correct way, but nothing, I connected the adapter no light, nothing. I did noticed that if I give the battery a bit of charge, and connect it, the 4056 gets mad hot. nothing else beside the 4056 gets hot.
                                        I checked the datasheet of the ME4056SPG, its basically the same as the TC4056 or I'm missing something. Question, inverting the polarity should have like a diode or something to protect it? Its a removable battery. What else could get burn by inverting the polarity to check?
                                        Thank you.
                                        • acedogblast
                                          by acedogblast
                                          11-02-2024, 05:13 PM
                                        • DynaxSC
                                          ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                                          by DynaxSC
                                          Hi
                                          I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                                          08-04-2025, 12:20 PM
                                          by SMDFlea
                                          Bad...
                                          09-02-2021, 04:40 PM
                                          MSI Sword Sword 15 A11UC-630XIT Notebook 15 Specification for Upgrade or Repair
                                          This specification for the MSI Sword Sword 15 A11UC-630XIT Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Sword 15 A11UC-630XIT boardview and Sword 15 A11UC-630XIT schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 02:00 AM
                                        • BMCappelletti
                                          Asus Chromebox CN62 - wrong chip put on BIOS reader
                                          by BMCappelletti
                                          Long story short:
                                          - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
                                          - gave the computer to his son a couple years later
                                          - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
                                          - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
                                          (seems like the story was not that short)
                                          He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
                                          01-08-2025, 07:27 PM
