John Deere AM137667 components identification .
  • petehall347
    • Jan 2015
    • 4448
    • United Kingdom
    what are these black things to the right of the ic chip . ? both test as shorted .
    • 22084
    Re: components identification .
    The one on the left could be an ON semi 1SMB26AT3 ,marking ME https://cdn.badcaps-static.com/pdfs/...70e6d21d8e.pdf
    • lotas
      • Jan 2016
      • 4834
      • Russia
      S2g-13-f
      • petehall347
        • Jan 2015
        • 4448
        • United Kingdom
        i found ME marking as an inductor .. will see if it measures any inductance .
        • petehall347
          • Jan 2015
          • 4448
          • United Kingdom
          ok i only just thought to look on the board for same marked components and found the same S2g one and it measures as a diode on the board . i need to remove it to know for sure .
          that leaves the other one marked ME . it doesn't measure any inductance so this might well be a shorted tvs diode as suspected .
          will see what pins it connects to on the ic chip if any .
            • 22084
            I`m fairly sure its a TVS diode connected to the high side driver chip VND5050K https://cdn.badcaps-static.com/pdfs/...5759eb738e.pdf
            3.2 Load dump protection
            D ld is necessary (Voltage Transient Suppressor) if the load dump peak voltage exceeds the
            V CC max DC rating. The same applies if the device is subject to transients on the V CC line
            that are greater than the ones shown in the ISO 7637-2: 2004(E) table.
            • petehall347
              • Jan 2015
              • 4448
              • United Kingdom
              it doesn't seen to connect to that ic . i do know these are wired in series .. here is a pic with them removed . and yes i spotted the broke trace ..where the pass through is .. right where they join together .
                • Jul 2011
                • 6070
                To me this board looks like shit with all of what looks like flux
                What is the description of the device
                • petehall347
                  • Jan 2015
                  • 4448
                  • United Kingdom
                  the stuff is potting compound shit . took ages getting it as clean as it is .. its a control box for john deere garden tractor . box id ..AM137667
                    • 31278
                    what does it actually do?
                    • petehall347
                      • Jan 2015
                      • 4448
                      • United Kingdom
                      main thing it does is short the ignition coils when ignition is off . also it controls things like the pto but only if interlock safety switches are switched on such as seat switch and brake etc . the older tractors just had relays and safety switches .the more modern ones have these silly boxes to switch the odd relay . some older ones than this i have fixed by simply replacing relay drive transistors or patching traces when the battery has been connected backwards .
                      these particular boxes seem to have a large fail rate and it would be good to find and fix whatever the weak spots are .
                        • Jul 2011
                        • 6070
                        Why not do away with the this controller board and do like older version does it sense it only controller the PTO and ground the ignition coils when ignition is off make it simple to use and operate
                        • petehall347
                          • Jan 2015
                          • 4448
                          • United Kingdom
                          because the person wanting it done will be selling it and its lots easier to deal with this controller unit than redesigning and wiring the whole machine which would cost more than a new controller . oh yes it also does the hours counter so that would need to be sorted as well .
                          • petehall347
                            • Jan 2015
                            • 4448
                            • United Kingdom
                            now i have a problem finding the parts . RS dont appear to have them and none on ebay in this country . . are there any suitable subs ? https://uk.rs-online.com/web/zr/?sea...d%22%3Atrue%7D
                            • petehall347
                              • Jan 2015
                              • 4448
                              • United Kingdom
                              does this look right one for 1SMB26AT3 ? https://uk.rs-online.com/web/p/tvs-diodes/8062019
                              • petehall347
                                • Jan 2015
                                • 4448
                                • United Kingdom
                                does this look right for the other one ? https://uk.rs-online.com/web/p/schot...fiers/6291426/
                                • petehall347
                                  • Jan 2015
                                  • 4448
                                  • United Kingdom
                                  bump
                                  • petehall347
                                    • Jan 2015
                                    • 4448
                                    • United Kingdom
                                    are these the correct ones .
                                    1SMB26AT3,,,
                                    S2g-13-f...
                                    i do have a thread running but not getting replies . i could do with getting these ordered .
                                    • petehall347
                                      • Jan 2015
                                      • 4448
                                      • United Kingdom
                                      have ordered those parts anyway just in case i chose the correct ones .
                                      • petehall347
                                        • Jan 2015
                                        • 4448
                                        • United Kingdom
                                        Re: John Deere AM137667 components identification .
                                        soldered parts in .. fingers crossed it will now work ..
                                        new parts aren't marked quite the same as originals .
