Thermal Cutoff/Fuse ID -Surge Protector
  • m4a2t0t
    • Mar 2013
    • 276
    According to This PDF Its rated 109c functioning and 103c holding but all I can find is 109c functioning and 83c (10A) / 88c (15A) holding or 128c functioning and 103c holding.
    It is labeled D108 PPqH
    Should I try and match the functioning temp or the holding temp?
    The protector is 6 outlets rated at 15A. That PDF shows 25A @ 240v but say 5 LRA @ 120V. I can only find 10A and 15A versions.
    Thanks for any help
    • Jul 2011
    • 6027
    Re: Thermal Cutoff/Fuse ID -Surge Protector
    I would probably go with this one
    “ I can find is 109c functioning and 83c (10A) / 88c (15A) holding”
    This will mean probably that it will trip sooner than the original one did but this might be better in the long run
    • m4a2t0t
      • Mar 2013
      • 276
      ok thanks
      • redwire
        • 3900
        I would match the fusing temperature 109°C. This is a power strip so it is supposed to prevent fire when the MOV's overheat.
        If it was a food cooker that goes unsafe just above boiling temperature I would also be wanting the holding temp to be a match as well so it doesn't pop when cooking normally. But as you found, most TCO out there are not like the data you found German made. Thermal cutoffs are typically about a 30°C difference between normal operating and unsafe temperature.
        You can buy MOV's that have the thermal fuse built in, like Littelfuse TMOV but they are a lot thicker. The TCO will be coupled to the MOV's with Kapton tape or a braided sleeve, so a hot MOV=hot TCO.
        • faraday28
          • Jan 2022
          • 15
          • Indonesia
          109C functioning: meaning that fuse will be blown up/disconnected after reaching 109C under minute or 30s or less.
          103C holding: meaning the fuse would hold @103C 168Hours* without any load. (holding temp meaning max temp which fuse never break @0 Amp)
          83c (10A): meaning the fuse can hold at 83C with 10A current load.
          use resistive load, because outlets always in resistive load rating.
          *designed product by Elmwood.
          Use same spec 109C functioning temp. the hold temp can be vary because the specification criteria is made by manufacture and can be vary from one to another as same as capacitor manufacture write max ripple rating, but as long as the functioning temp is match, you are good to go.
          Edit: and current rating must be match as the original parts.
          • corrize
            A funny fuse story – Lumix LX100 II
            by corrize
            Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
            I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
            The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
            There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
            And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
            10-19-2023, 09:58 AM
          • jshhh
            Help replacing fuse on my Mimaki CJV300-160 vinyl printer
            by jshhh
            Hi guys,
            I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
            How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
            Anybody know how to remove this type of fuse?
            (The fuse is toward the bottom of the image labeled F2)...
            06-17-2025, 01:35 AM
          • Babbar
            by Babbar
            04-12-2024, 01:12 AM
          • nobbnobb1
            Upgrading Whole Home Surge Protector MOVs (Eaton CHSPT2SURGE)
            by nobbnobb1
            I have a whole home surge protector (Eaton CHSPT2SURGE). This is the lower end model as compared to the CHSPT2ULTRA. When I took it apart, I noticed it's basically the same PCB as the higher end model, just missing the extra MOVs for higher capacity. Coincidentally, I have a pack of brand new Bourns 20D241K MOVs laying around:
            https://www.digikey.ca/en/products/d...0D241K/2799098
            The only thing I noticed is that these Bourns MOVs are not thermally protected with a fuse. I'm wondering if it's safe to just simply install these extra MOVs for extra capacity,...
            06-04-2025, 08:40 AM
          • drykid
            Matsui 175S microwave fuse replacement
            by drykid
            I recently picked up a used Matsui 175S microwave that was powering up (starts, turntable rotates) but not heating. From looking online the most likely culprit was the fuse, but unfortunately in this one the fuse had heated up and fused with the (badly designed) fuse holder and couldn't be removed. I guess this might indicate further issues beyond the fuse itself but at this stage I just want to replace the fuse and see how I go from there.
            Anyway since I couldn't get out the fuse itself the easiest fix was to replace the fuse holder assembly that runs between the...
            12-21-2020, 01:15 PM
