D882 sot-89
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8706
    D882 sot-89
    What the ...
    I had the magic smoke come out of my universal pogo pin charger.
    Was probing around the transistors on the board and found a D882, supposedly NPN, was not working as it should. Interesting.
    First I looked up D882 and got a TO-126 device. No way. The device was SMT.
    Then I found a SOT-89 D882. That's more like it.
    Then I was reading the specs as I do not think I have any D882s on hand. I read on a datasheet from shenzen topsky:
    Ic Max: 3A continuous (red flag alert right away...)
    Pc Max: 500mW (reasonable for a SOT89)
    Wait a minute.
    Oh well, will have to look for one so I can fix this pogo universal Li-ion charger and hope nothing else is wrong, but the contradiction on the datasheet made me go wtf... there's no way to pass 3A continuous and still stay under 500mW dissipation...
  • diif
    • Feb 2014
    • 6978
    • England
    Re: D882 sot-89
    A different manufacture uses the heading ABSOLUTE MAXIMUM RATING with this note below.
    Note Absolute maximum ratings are those values beyond which the device could be permanently damaged.
    Absolute maximum ratings are stress ratings only and functional device operation is not implied.
      • Jul 2011
      • 6070
      Re: D882 sot-89
      I have also found this to be some what confusing as well but I try use any device in its normal operating range and on the lower end of the range if possible
      I looked up this charger and found that it has the following in its description “ Automatic polarity detection”
      If yours has this capability be very careful using this function because you can destroy it
      I have a charger that says that it can do this as well but there is a catch to this if you install battery in one direction and for what ever reason you change your mind and decide to reverse the direction you might fry the device that allows you hook it in either direction if you do not power it completely power off the device and let the circuit be completely discharge it’s self completely
      I had decided to torture test this claim that it has this function “Automatic polarity detection” and what it would take to destroy this function and found that it can not take this abuse ( I have several of this type of charger ) but not the brand that you mentioned in this post
      Automatic polarity detection is a great feature but it has its limitations to how you can use it
      For what ever reason this warning has not been given for these devices that can do this function
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8706
        Re: D882 sot-89
        Since passing 3A through would always exceed 500mW they may well just say 100000A is the limit because you'd exceed 500mW before getting close to that... If this was a MOSFET then things would be different, but not a BJT.
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8706
          Re: D882 sot-89
          BTW yeah, it's probably what happened, the auto polarity probably got confused and tried to reverse charge...killing the transistor.
          Which is a lot better than causing the battery to immolate...
          As for what to do with this transistor... not sure. Surprised the D882 TO-126 and the SOT-89 have different characteristics...
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8706
            Re: D882 sot-89
            Argh. I see the h-tree. Funny the magic smoke leaked out of something but I couldn't figure out what leaked - the nonfunctional D882 looks fairly intact and the rest of the h-tree looks ok...
            hmm... another mystery to be solved...
              • Jul 2011
              • 6070
              Re: D882 sot-89
              Hopefully you can solve this mystery to what happened to this charger
              • langbaobao
                DIY 3D-Printer WSON8 Pogo Pin Adapter
                by langbaobao
                Hi.
                I'm posting this here in part as a memo to self as well as to describe the procedure I used in case anyone else found it useful. I found a lot of the necessary information to make this work on this forum and I figured I would give something back. If this is not the appropriate place to post this, I don't mind it being deleted but I hope it can help other people.
                I got an admin password locked HP Elitebook 840 G5 recently that I wanted to unlock. I'm a relative newcomer to reprogramming and unlocking firmware. The only previous experience I had was unlocking a BIOS...
                01-08-2024, 05:58 PM
              • motormayhem
                Lenovo T460 Only Charges on One Charger
                by motormayhem
                Laptop Question
                I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                05-12-2023, 01:46 PM
                NVDC charger configuration...
                11-05-2024, 03:28 PM
              • flat-earther
                how to prevent a connected charger from draining battery when not charging?
                by flat-earther
                I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                So the battery is backfeeding the charger and being drained.
                How can I prevent...
                08-07-2025, 01:04 PM
              • flat-earther
                ASUS X54H laptop thinks it's always charging even with charger unplugged
                by flat-earther
                The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                Windows also shows ''Plugged in'' when charger is not connected.
                This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                If I let battery run out and say it has 3% Windows will...
                06-24-2025, 09:32 AM
