Testing SMD caps
  • sam67
    • 256
    Testing SMD caps
    When testing SMD capacitors on pcb using 200 ohm setting does it give reliable readings when testing for shorts and opens ?
    Just thought i'd ask ,what other methods do you use ?..i do have mike's Esr v4 for the electrolytic caps.
  • 999999999
    • Sep 2006
    • 774
    Re: Testing SMD caps
    No. Some circuits will have parallel paths, though if you had a reading of totally open you can be sure the cap isn't shorted at that particular moment.
    • sam67
      • 256
      Thanks for your reply ,what is the best method that can give a reliable reading when using either digital or analogue meter.
      • shadow
        • Feb 2007
        • 732
        In reality, to test nearly all components reliably requires you to remove the component from the circuit. Test it and either put it back in circuit if it is alright or replace it if it has failed.
        • sam67
          • 256
          Trouble is there are loads of smd caps on a main board and to remove them one at a time would take forever.. surly there must be an easier way
          • 999999999
            • Sep 2006
            • 774
            Do you really need to test all the SMD caps? I'm sure there are some SMD 'lytics on mainboards somewhere, but generally most, the rest aren't very prone to failure unless the solder joints crack from flexing the board too much.
            What you can do is check for the expected values in each subcircuit when power is applied. A multimeter will do that for some circuits, or a scope for the rest. If circuit meets needed parameters the caps can be assumed sufficient/ok/good enough/etc.
              • 31267
              SMD leak like government.
              put a soldering iron on the "-" pin and see if it stinks - that's the first test.
              • sam67
                • 256
                Hi guys ,
                Thanks for the response ..I just wanted to get more info on testing smds like caps resistors e.t.c in case i come across a problem in the future ..Just looking for a quick way of confirming which are bad and which are good so i can eliminate them.
                The SMD components are that small and trying to desolder them one at a time would be a real pain just to see which ones had gone bad.
                  • 31267
                  they leak far more often than they fail "in secret" if you know what i mean.
                  • 999999999
                    • Sep 2006
                    • 774
                    sam67, be more specific. Testing a circuit is all about exactly what the circuit does. There is no one way to test "a mainboard" because it is comprised of so many circuits.
                    Generally speaking the only way to have a clear and sure determination that a capacitor is good, within specs, is to desolder it. Yes it would be a real pain but if you are speaking of the non-electrolytic capacitors there is not any real reason to suspect them at all unless you have a specific reason and in that case, you would replace any that are suspect.
                    A suspect part would have visual abnormality, or if you just suspect a cracked solder joint you can reflow that joint. If you measure a short you have to pull all parts in the subcircuit till you find it. If you measure too much ripple, only then suspect a drift in capacitance value or open circuit at capacitor(s).
                    Generally speaking though, we have a paradox. Electrolytic capacitors are among the most likely discrete components to fail in switching power supply subcircuits, but non-electrolytic surface mount capacitors are among the least likely parts to fail in subcircuits so the better thing to wonder is what else in that subcircuit is the first place to look.
                    • sam67
                      • 256
                      Thanks 999999999 ,
                      I was just curious about the small SMD components but your answer ,
                      Well, answered that for me
                      Cheers
                      sam67
                        by momaka
                        03-12-2025, 03:42 PM
                      • Paxman_Swede
                        by Paxman_Swede
                        Hello!
                        01-14-2025, 09:51 AM
                        Casing Power MPT-301 [PCB ATX9806b-p REV: A3]
                        by momaka
                        This one should make @Pentium4 smile (if he is still reading BCN forums) – I got a new old stock / open box Casing Power MPT-301 PSU on eBay for $4 total.
                        Yes, it’s a very generic-looking box, but the manufacturer isn’t (at least not back in the days), which is…
                        Macron Power Technology Co. LTD.
                        Let’s look at the PSU itself.
                        The shell/case also appears quite generic, like many “sold-with-the-PC-case” units. However, the shell is well-formed and has decent steel thickness. In terms of...
                        06-02-2021, 10:05 PM
                      • captain150
                        by captain150
                        03-16-2025, 07:34 PM
                      • Foetuss
                        Gigabyte GA-6OXT :: caps question
                        by Foetuss
                        Good evening
                        I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                        Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                        But I was also suprised about the bigger boys, which are 330µF 25V.
                        Could it be they used 25V caps because they were cheaper / available at that time?...
                        02-11-2025, 12:22 PM
