Re: Light bulb flicker when turning on after long time off.
Confirmed, yesterday, I saw Poland for the longer T8s and India for the longer T12s. I went into the West Lebanon, New Hampshire Home Depot with my father and a moron almost slammed into me, when walking inside.
Now, I have to watch for coronavirus symptoms!
Well, I went there and I'm at the highest risk of getting the " 'rona " so far! (That is, especially if I got virus particles in my eyes!) (I double-masked)
I shouldn't even have asked about the T5 HO fixture stock in the store! (Claremont, New Hampshire)
I should have just went to the same aisle where the other fluorescent fixtures are! I did and I saw the T5 54 HO fixture! Yesss!
Then I grabbed the first Phillips Alto T5 set ever. (Rated at 4100K, IIRC)
I don't get LEDs there, usually!
Heard that I should be fine if that employee was fully vaccinated. I'm one of the late ones to get a vaccine, even with BioNTech being around the longest for the major-league coronavirus vaccines. Got my first jab with no severe side effects.
I better not get the " 'rona " with severe symptoms! Unfortunately, we saw that Boris Johnson got the coronavirus with severe symptoms in "two-zero".Last edited by RJARRRPCGP; 05-29-2021, 09:32 PM.Leave a comment:
Makes more sense.
Boy, they really went down, it apparently started with their incandescents having what looked like pretty hit and miss quality. The printing on the bulbs for how many watts and etc., were inconsistent.Leave a comment:
Yes, Sylvania.Leave a comment:
Considering the fact they were bought by MLS Co. Who is a Chinese lighting company, it doesn't come as a surprise to me.Leave a comment:
Well, it looks like Signify moved a lot of T5 manufacturing to Europe, in Poland, the same as the F15T8s. I was at Home Depot in Claremont, New Hampshire today.
Home Depot didn't look nearly as bad as I dreaded. I actually had low expectations and got surprised with how good they are doing.Leave a comment:
Home Depot didn't look nearly as bad as I dreaded. I actually had low expectations and got surprised with how good they are doing.Last edited by RJARRRPCGP; 05-17-2021, 12:14 PM.Leave a comment:
I found out that they are likely by far, manufactured by the same factory.
The Feit and Ace branded ones won't have the green colored ends, TMK.Leave a comment:
Yeah, but in this case, these were just some standard 4100K and 6500K tubes in 2ft, and 4ft lengths. They still had the Alto branding though.Leave a comment:
Without those ends? I usually saw the gray ones with specialty ones, such as the red-spectrum'ed ag-spec'ed ones.Leave a comment:
Did they go to all China like they did with all their T5s?!
(The writing was already on the wall for T5s back in 2016, they didn't last as long, possibly already started getting manufactured in China as soon as 2015)
This time, it really looks like "light-bulb-mageddon" (of course, a.k.a. "light-bulbpocalypse")
What about the T8s? Are the T12s getting moved out before the T8s?
I probably should have added this, but the T12s are still made in the USA, just without the green endcaps, now i have not seen any silver endcaped Philips T8s in stores yet, mostly due to T12s being more popular in residential areas than T8, and most commercial places with T8 typically buy theirs from wholesalers.
Now my main worry about the transfer is for any place that still uses Slimline (single pin) or High Output type fluorescent tubes, because, as far as i can tell, Philips is the last manufacturer of these types of lamps, so i wonder if they'll even bother moving manufacturing overseas (especially since most of these lamps are over 4ft long) or if they might just discontinue them and leave everyone who still uses them in the dark (just like what they did with their low pressure sodium lamps a few years ago).Leave a comment:
I'm seeing people are tossing out their linear fluorescent fixtures so I suspect they are noting that demand is dropping at least for home use. I don't know about commercial/business use whether existing buildings are being retrofitted to LED, though I suspect this is happening slowly too... and thus demand for tubes go down and the desire to outsource them...
Then there's the FC8T9/22 or somethingrather... I've yet to see a cheap LED retrofit for this. Think I have an electronic ballast in my fixture, or at least the starting doesn't give the annoying flickering.Last edited by eccerr0r; 03-03-2021, 04:49 PM.Leave a comment:
What about the T8s? Are the T12s getting moved out before the T8s?Last edited by RJARRRPCGP; 03-03-2021, 04:16 PM.Leave a comment:
Actually F40T12's are around 2800-2900 lm... so LEDs are a bit more efficient than previously mentioned. F32T8's that are about the same brightness as F40T12's are closer to LED efficacy.Leave a comment:
Satco, Sylvania, Duracell (Sold exclusively at Batteries + Bulbs), and a number of generic brands that are not worth listing seem to get their linear lamps from China, i've also seen Satco F40T12s from China.
Oh, and the green end caps of Philips fluorescent tubes might be going away as Philips packs up the Salina, Kansas factory to move overseas (saw a few F40T12s at the Home Cheapo recently with silver end caps, made around December 2020).Leave a comment:
err... watch your energy conversions!
The fluorescent tube is necessarily generating more heat because more watts in and same light out. Energy cannot be destroyed, just converted.
however the LED has localized heating - some spots will be hotter. However, if the LED had a metal heatsink as big as a fluorescent tube, you'll find the LED(s) will be cooler!Leave a comment:
the 5000lumen tube isnt generating anywere near the heat of the leds though - and they spread the light all aroundLeave a comment:
by OscarAVHello,
I just came here to see if someone has had the same problem I have, and if he or she solved It, to know how to do It.
I have made a quick search for my laptop but I have not seen anything similar.
I have an old laptop, an HP Pavilion dm4-1065dx which takes a lot of time to be ready to start if the laptop has been unplugged for a while. It has no battery. The battery failed long time ago. It needs to be plugged to work. But as I said, It can take a lot of time until the charging led gets on, and I can switch on the laptop. I am using an external monitor... -
by sam_sam_samI have had these 70 watt high pressure sodium yard lights for many years now probably at least 15 years or more and there is a protection diode that after several years starts to go bad and when it does this it has momentarily shutting down the light and then a few minutes later it starts working again
This about the forth time I have fixed this one and you can tell if it the diode or not if it lights up and it only shuts down when the air conditioner turns on then it is the diode
If it cycling on and off constantly then it is the bulb itself that is the issue
by fixit007I picked up this TV that the prior owner said - just died.
Tested the fuse - burnt. A dead capacitor is visible too on the hot side (CP801). Got the replacement power board (cheaply - used). Replaced the board - the TV turned ON!
Now, about a month later (yesterday) I noticed the left side of the screen was flickering from time to time. That was already happening with the antenna input, not through HDMI.
Also, some glitchiness with a Fire stick on HDMI3 - I hit an app with quick dark screen in stick, the TV goes - no input. Then I had to choose the stick... -
by jaggHello, the laptop It turns on and off several times, it takes a long time to send video, possibly it is bios?
Here are the bios and the schematics.
Could someone help me verify that the bios is correct? thank you so much !!...-
Channel: BIOS Requests ONLY!
by sew333Hi. Yesterday i was in bathroom. And halogen bulb flicker for 1 second. Is this possible and why it flicker? Thx
Bulb looking something like that:
... - Loading...
