Logitech G29 Help request to find smd transistor reference.
  • nunofcc
    • Jul 2019
    • 29
    • porto
    Good night,
    I am going to ask your help to find out what is the reference of this smd transistor. Or what is an equivalent transistor?
    Thank you for your help.
  • tester272001
    • 91
    Re: Help request to find smd transistor reference.
    maybe a pic with more of the circuit would help? it could be a diode. do you know it is definately a transistor ??
    • redwire
      • 3910
      SMD marking O1 (not 01) my best guess is Si2399DS SOT-23 P-Ch 20V MOSFET
        Zoom out so we can see how the pins are connected in the circuit.
        Did you test out the 3 junctions to see what it is shown as?
        • nunofcc
          • Jul 2019
          • 29
          • porto
          Good afternoon, the sign is ok.
          I removed it from the plate and found the following values in the image.
          I would like to know a commercial reference of any compatible.
          Grateful for your attention
          • nunofcc
            • Jul 2019
            • 29
            • porto
            Since Q1, Q2 and Q3 are the same according to what I was able to visualize. Sincerely
            • redwire
              • 3910
              This is the part number
                So is your tester showing it as bad?
                • nunofcc
                  • Jul 2019
                  • 29
                  • porto
                  good afternoon, I tested one with the same reference that is on the same circuit. what's bad is Q1, but Q2 and Q3 are the same. I removed the Q2 to test. what was tested is good. Sincerely
                  • nunofcc
                    • Jul 2019
                    • 29
                    • porto
                    good afternoon,
                    very grateful for your help. I will search for the component with this reference and I will test it. then post here if it worked or not. thank you.
                    • redwire
                      • 3910
                      OP is fixing a Logitech G29 racing steering wheel, motherboard 210-001492-009
                      The burnt transistor Q1 must be for the motor?
                      • simplylcd
                        • Nov 2015
                        • 13
                        • United Kingdom
                        Good night,
                        Did you find a reference for the wheel I need to find U8 and U9
                        https://www.badcaps.net/forum/attach...1&d=1627597271
                        • Thordero
                          • Oct 2021
                          • Brazil
                          Hello simplylcd, did you discovered U8? Look what happened with my U8...
                          • Thordero
                            • Oct 2021
                            • Brazil
                            Forgot to attach images
                            • ploggy
                              • May 2021
                              • 7
                              • United Kingdom
                              Sorry to bump but this is exactly what's happened to my wheel PCB too but for me the burned component is at U9 on the PCB instead of U8 for you, I think they components are the same but I cant find out what the component is?
                              It says A1 on one of those parts I assume my burned one says A1 also but I don't know for sure due to the markings being burned off.
                              Can someone identify this component for me please?
                              • redwire
                                • 3910
                                Re: Logitech G29 Help request to find smd transistor reference.
                                It looks like a SOT563 package, smd marking "A1" and likely an ESD protection diode array.
                                But I couldn't find an exact p/n. U8, U9 are the same part. Can you confirm the IC's package.
                                • ploggy
                                  • May 2021
                                  • 7
                                  • United Kingdom
                                  Thank you how do I confirm the IC's package?
                                  • redwire
                                    • 3910
                                    You measure the package size with a set of calipers, only 1.6mm across. But don't zap the board with static electricity doing it either.
                                    My best guess would be U8 and U9 are BAW56S dual pair (4) diode array.
                                    You could take multimeter diode-test readings from a good IC and compare to what you are getting. There are 4 diodes in the IC.
                                    • ploggy
                                      • May 2021
                                      • 7
                                      • United Kingdom
                                      I haven't got calipers to check size but I have a Multimeter.
                                      On my Multimeter the diode test shares the same position as the continuity.
                                      I uploaded a fresh pic with the measurement on it, on the "good" ic on the bad ic it beeps across all pins
                                      • redwire
                                        • 3910
                                        this is the pinout
                                        • Francesc V.
                                          Diode marked as "E57".........not able to find it by reference
                                          by Francesc V.
                                          Hi:
                                          I have what it might seem a zener diode. It's marked as E57, but I haven't found any reference that might match my observations.
                                          I've took one from the same circuit and tested isolated with the power supply and a 1k resistor. with 10V, the possible zener stays at 6.6V.
                                          It seems a SOD123 package. It measures (2.6mm x 1.6 mm).
                                          Any idea? it's a 6.6V zener?
                                          06-14-2025, 09:56 AM
                                          LENOVO ThinkCentre ThinkSmart Edition Tiny M920q for Logitech ThinkCentre M i5-9600T Specification for Upgrade or Repair
                                          This specification for the LENOVO ThinkCentre ThinkSmart Edition Tiny M920q for Logitech can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkCentre ThinkSmart Edition Tiny M920q for Logitech boardview and ThinkCentre ThinkSmart Edition Tiny M920q for Logitech schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on...
                                          09-12-2024, 01:58 PM
                                        • Vesko356
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                        • everell
                                          EVGA 500 watt with fan twitch
                                          by everell
                                          This is an EVGA 500 watt Model 100-W1-0500. On power up only has a small fan twitch. Usually this is just a bad capacitor on one of the output lines. Not this time. I pulled out my storage scope and looked at the output lines during the first 10 msec after power up. 12 volt line was 11.5 volts. 5 volt line was 4.5 volts. But....the 3.3 volt line was also 4.5 volts. Couldn't find a short between the 5 volt line and the 3.3 volt line. So pulled out my multimeter and tried to find a bad component using resistance measurements. Nothing. So I took a guess that the mag-amp transistor might be bad. It...
                                          09-15-2022, 05:50 PM
                                        • Francesc V.
                                          Dell dockstation WD15 is dead
                                          by Francesc V.
                                          Hi:
                                          A friend gave me this DELL WD15 dockstation that does nothing. Not detected by computer, no digital output.........just leds shines when it’s plugged in.
                                          Here are the findings, followed by good pictures. :-)
                                          When pluged in, LED3 glows
                                          Measuring some voltage in the circuit.
                                          Inductors
                                          - PL202 has 5V
                                          - PL201 has 3.3V
                                          - PL300 has 1V
                                          V. Regulators
                                          - UT30 has 19v as input and 6V as output. It seems ok.
                                          - UT27 (same reference as UT30, has no input/output voltage).
                                          Thermal find...
                                          07-09-2025, 12:12 AM
