Re: Need help with Low voltage protection circuit
One of my ideas was to use an off the shelf battery alarm. This circuit is similar to one I built a long time ago, but you can buy the alarm for a couple of dollars. It does not have a relay so I took the circuit and made my own board with a heavy duty 30 amp relay.
![](https://cdn.badcaps-static.com/image_cache/1508ec73da2b430a4386d0e36d7ee364.jpg)
this board is 1.56"x 2.68"x 1.25" not ideal.
I have not ordered any boards made yet, but my test version does work.
The issue is there is no hysteresis and the off and on voltages are almost the same.
I Do not know enough to modify the circuit to get a 1 or 2 volt spread in the on off.
That's why I decided to try the mosfet circuit.
Through hole components are preferred as any one can make it.
