Need help with Low voltage protection circuit
    Re: Need help with Low voltage protection circuit
    So how does it perform using noisy load such as Vacuum motor?
    • flinx
      • Aug 2010
      • 132
      I have not tested that yet.
      "...off the record, unnamed government sources
      alluded to unsubstantiated innuendos about
      alleged indiscretions and insinuated that they
      are rumored not to be without basis for further
      speculation..."
      • flinx
        • Aug 2010
        • 132
        SO...
        I got sidetracked by a project that I have been waiting a month for (stupid Post office).
        I finally hooked up the dustbuster to it, reset the shutoff voltage for 13 volts, and... My control head for my power supply couldn't handle the load. My power supply has a maximum current limit of 15 amps.
        When I hook everything up to the dustbuster and turn it on my PS resets. I did some poking around and checked the resistance of the motor. it's .59 ohms. Which means that at 16 volts it pulls about 27 amps cold start. Then it settles in at a comfy 11 or 12amps.
        So I have to hook it up directly to one of my switching power supplies that can handle that amperage.
        speculation..."
        • flinx
          • Aug 2010
          • 132
          Alright!
          I hooked the dustbuster and circuit up to a 15v somewhat adjustable switching power supply that can put out 40 amps and set it for 16v.
          It started up just fine and ran fine. I dropped the voltage as low as I could but not low enough to hit the cut off I set.
          Voltage did not dip too much when it started up (that I could tell). I did not have an amp meter on it, but I know it pulls at least 11 amps.
          After about maybe one minute my thermal camera showed the mosfet was 172° f\78° c and I shut it down since I don't have a heat sink on it.
          speculation..."
          • flinx
            • Aug 2010
            • 132
            if anyone cares here is a video of the device being tested under load to cut off.
            https://youtu.be/tkce2S1gxYA
            speculation..."
            • greg1985
              • Oct 2023
              • 13
              • Polska
              #86
              Originally posted by flinx
              Just got my boards back from JLCPCB
              IT works perfectly. though see if you can spot the error (on my part).
              Yes I forgot to join a copper area to a network.
              Hi. Nice project. Thank YOU for making this. Can You send me gerber file or pcb? I want to order from JLCPCB too. Thanks again for this project.
              • Dima Abramov
                • Apr 2024
                Hello i want to utilize this circuitry to put in to Power Tool adapter makita batteries -> other brand tools. The power tool draw can be constant 25-30 amps with peaks reaching up to 100 amps. So in this case IRF9540N from schematic is not a good choice because it would generate too much heat. Is there a better drop in replacement option? Something like PSMN1R2-30YLDX​ with 2.64 mΩ RDS for rough estimate .
                • truclacicr
                  • Apr 2019
                  • 296
                  • australia
                  #88
                  FWIW, R5 in the original circuit on page #1 provides hysteresis.
                  • alro7779
                    MOSFET? Is its voltage reading normal?
                    by alro7779
                    Hello, guys!
                    Got this 8-pin MOSFET (I presume) on the motherboard that I'm still trying to repair (HP Stream 11-ah117wm DAY0HGMB6C1 REV:C), close to the DC IN connector, and when I read voltage on Drain (5-8 pins) and Source (1-3 pins), I got the 19.81 VDC of the DC IN on each, but on the Gate (pin 4) it's 25 VDC. Is it normal? Now, I'm not quite sure the component is a MOSFET, but it looks like, and since it has the printed code on it totally unreadable, I can't try to find the datasheet. Can anyone give me a hand on this? Or maybe ff there's some MOSFET tutorial or something that you can...
                    06-19-2025, 08:19 AM
                    ISL6556ACB ISL6556ACBZ ISL6556ACR ISL6556ACRZ PWM Controller Datasheet
                    Optimized Multi-Phase PWM Controller
                    with 6-Bit DAC for VR10.X Application
                    The ISL6556A controls microprocessor core voltage
                    regulation by driving up to 4 synchronous-rectified buck
                    channels in parallel. Multi-phase buck converter architecture
                    uses interleaved timing to multiply channel ripple frequency
                    and reduce input and output ripple currents. Lower ripple
                    results in fewer components, lower component cost, reduced
                    power dissipation, and smaller implementation...
                    11-05-2024, 03:10 PM
                  • bendeg
                    Test circuit for curiosity : 2 x NE555 (astable + PWM) + n-mosfet + var 10k + pc fan
                    by bendeg
                    Hi reader,
                    I'm trying to control a pc fan speed by giving PWM to the gate of a n-mosfet.
                    1) generation of a clock with a 555 timer (~ 1,5 kHz, as seen in the datasheet, fig.12) (Vcc = 6V).
                    Output to TRIG of second timer (pin 2) + red led
                    2) generation of a PWM with a second 555 timer (as seen in the datasheet, fig.18), CONT (pin 5) modulated by a variable 10k resistor (Vcc)
                    3) Using output of second timer to "pulse" n-mosfet gate (MDP13N50) + yellow led
                    4) pc fan (12V, 0.18A) in series in drain-source of...
                    05-01-2023, 07:59 AM
                  • wrobbie
                    Lenovo T14 (AMD, gen1) over-voltage protection IC keeps dying.
                    by wrobbie
                    My T14's (NM-C801) main USBC input keeps failing every few months. Initially, it worked fine for several years. The symptom is that once powered from the main USBC port using a 65W power brick, after some time (minutes, hours) charging will fail completely. Powering from the secondary (docking) USBC input still works. This laptop is basically always plugged in. The first time it happened, it took me a long time to find that the FPF2281 over-voltage IC for that USBC input was at fault. When the issue occurs, it will continuously reset power delivery negotiations with the power brick -- according...
                    02-26-2025, 10:02 PM
                  • someonenotyou
                    SY8003 instead of SY8003A
                    by someonenotyou
                    Hi.
                    I have a Lenovo HLS1C_HLS1D LA-L502P board with bad SY8003A DC/DC converter.
                    I have a different mother board witch contains SY8003 DC/DC converter.
                    Can I use SY8003 instead of SY8003A converter?
                    These are the differences -
                    • Short Circuit Protection:
                      • SY8003: Uses latch-off protection. This means that when a short circuit is detected, the device will shut down and remain off until it is manually reset.
                      • SY8003A: Uses hiccup mode protection. In this mode, the device will repeatedly attempt to restart after a short circuit is detected. If the short
                    03-05-2025, 07:54 AM
