Need help with Low voltage protection circuit
  • flinx
    • Aug 2010
    • 132
    Re: Need help with Low voltage protection circuit
    Originally posted by budm
    "The idea of hysteresis is to provide some feedback from pin 1 to pin 3 of the IC with a resistor, however you will need to add a resistor between the zener and pin 3 of the IC because it would otherwise have no way to increase the threshold. Looking at this, you will likely need to use the other amplifier in the LM358 to provide more consistent triggering, mostly because the voltage output of the LM358 will depend on the setpoint.."
    +1
    BTW, using compactor IC such as LM393 with open Collector output is more suitable than using OPAMP.
    I have 10 lm393.
    "...off the record, unnamed government sources
    alluded to unsubstantiated innuendos about
    alleged indiscretions and insinuated that they
    are rumored not to be without basis for further
    speculation..."
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8690
      Reproduction royalties to ... guess.
      As far as I know this *should* work but no guarantees. Circuit on the left is the cutoff circuit, right is the original circuit. If you plan to hack the existing board, be careful there are subtile differences.
      • flinx
        • Aug 2010
        • 132
        I built the circuit except the only thing I do not have is a 15v zener. closest I have is 12v.
        I could try scrounging one off a board if they had readable identification marks.
        speculation..."
        • petehall347
          • Jan 2015
          • 4426
          #44
          add a 3v one to the end of it
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8690
            12V is fine, just needs to be less than 20V (Vgsmax) but above 5V (Vgsth). Circuit is poorly tuned and behavior/power consumption can be improved by changing component values. Should be able to get it less than 10mA draw, but at 10mA it's still pretty horrible. This also depends on voltage input too.
            Note that the diode will limit current draw value, probably should omit that 1N4007 and short it out.
            Again, no guarantees. It still has the problem of being setpoint dependent behavior though it should be somewhat linear, and because of this I did not do threshold value calculations.
            Also the 1M resistor is probably superfluous, the zener itself should be sufficient to turn the mosfet off.
            • flinx
              • Aug 2010
              • 132
              I used 3 5.1v zeners in series. I do not have the IRF9540n in the schematic and am using my IRF5305.
              I have tested the circuit and since my power supply cannot go much higher than 19 volts (I have a better one on the way). I have the pot connected to In+, in-, and pin 3 of the lm358 set so that the transistor turns off at 17.26v and on at 16.3v.
              The mosfet gate voltage is 6v when the transistor turns off, and 8.5v when it turns on.
              The mosfet seems to be on all the time.
              The second 10k pot seems to do nothing.
              speculation..."
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8690
                I'd expect the second pot to do very little, it should change the voltage spread slightly.
                Do not use three zener diodes in series. The circuit depends the single zener to discharge the gate - if wired correctly, should drop below 1V (with respect to source, of course.)
                Also it should be mentioned that the voltage at pin 3 will change depending on the voltage at pin 1. What's unfortunate about this and the original circuit is that ideally the amplifier is running at fixed voltage instead of the varying voltage to ensure the behavior of the circuit is reliable.
                Ensure the voltage at pin 1 will switch between IN- plus around ~0.2V to IN+ minus ~1.5V. If it doesn't, something is wrong.
                • flinx
                  • Aug 2010
                  • 132
                  I checked the workings of the lm358 part of the circuit with one of the battery alarms it is based on, and except for the hysteresis they both work pretty close to the same.
                  I then started over and rebuilt the design in your pdf from scratch again on my breadboard.
                  The differences between mine and yours are:
                  transistor is a 9014n I also tried a BC550 (accounted for pin differences) I do not have a pn2222a
                  mosfet is IRF5305
                  12v zener
                  removed 1n4007
                  Hysteresis is still a little over 1v which is good.
                  Nothing I do short of dropping the supply voltage below 10v shuts off the mosfet.
                  The behavior of the circuit is like this:
                  Changing the supply voltage causes 9014n to turn on at 17.44v and off again at about 18.55.
                  At the same time the voltage coming out of the transistor is 7.67vdc, AND at the same time voltage rises on the gate of the mosfet from about 8.4 to about 8.59 then drops back to 6.97 AND at the same time voltage on pin 1 of the lm358 goes from .076v to about 17.12v instantly.
                  It looks something like this when graphed:
                  edit graph removed because it is wrong.
                  just in case I did something dumb and don't see it here is pics:
                  speculation..."
                  • flinx
                    • Aug 2010
                    • 132
                    here is the corrected graph I hacked together in excel that illustrates what is going on.
                    speculation..."
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8690
                      oh fiddlesticks this is what happens when I don't play with discrete P-channel devices and assume it works like PNP. You're right, there's a problem there, really need to have simulated it and got my current directions wrong. I'm still not going to simulate since there's no warranty expressed or implied :-P
                      Now I was hesitant on doing the lower left no-BJT version in the first place, though it may well just work. Do not use a "logic level" MOSFET here, IRF9540 and your IRF5305 should work fine. If you you have to use a logic level or the no-BJT version doesn't work, try the upper left version with three BJTs.
                      • flinx
                        • Aug 2010
                        • 132
                        IT VERKS! IT'S VERKING!
                        hysteresis is about 1.09v second pot has barely any measurable effect. maybe .04 volts?
                        But it VERKS!
                        now if my power supply would ever get here from china I could set the voltages proper.
                        To easyeda!
                        Can the lm393 be substituted for the lm358? pinouts are the same.
                        speculation..."
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8690
                          Reduce that 100K resistor in line to 47K or 68K to increase hysteresis, and you need the LM358, the LM393 will not work as drop in.
                            So you are using the lower left circuit utilizing both opamp?
                            What is the DCV at output pin 1 and pin 7 when it is not trip and when it trips?
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8690
                              For LM358, when not tripped pin 1 should be around the same voltage as pin 8, minus 1.5 volts or so. This was my main concern for direct driving in the first place.
                              Pin 7 should be no more than 0.2V.
                              When tripped, swap the voltages around.
                              Dang if this really doesn't exist anywhere I should productize this. But this is a ridiculously simple circuit and those chinese mass producers will beat me to the punch. Grr.
                              • flinx
                                • Aug 2010
                                • 132
                                47k gives 1.7 to 2.3 volt spread. excellent
                                speculation..."
                                  I look look at your first circuit:
                                  When battery Voltage is good, the pot is set so the + INPUT (3) is >5.1Vref on the -INPUT (2) so Output (1) swings high (max out = VCC - 1.5V per spec) which turns on the 2N2222 and P-CH MOSFET since now the Gate is toward ground providing > 3V Vg-s.
                                  When battery goes low to the point that - INPUT (3) is < 5.1V, the Output (1) will switch low (0.2V) which will cause the 2N2222 and MOSFET to be off.
                                  Am I missing something?
                                  I think the error is in OP post #46:
                                  • eccerr0r
                                    Solder Sloth
                                    • Nov 2012
                                    • 8690
                                    should make it clear that this will not work at 5V. The minimum operating voltage is probably around 8V minimum in order to bias everything properly.
                                    • flinx
                                      • Aug 2010
                                      • 132
                                      circuit board
                                      with 1oz traces it can handle about 8 amps, with 2oz it can handle 13, and with a 12 gauge bare copper wire soldered to the bottom traces for b- to out- and b+ to source it should be able to handle at least 20 amps.
                                      The mosfet would be laid down, soldered to the board and the output wire taken directly from the tab.
                                      board is 2.6"x1.4" I'm sure it could be made much smaller with SMD but that's not my bag.
                                      also I would most likely not be using this with anything below 14 volts.
                                      speculation..."
                                        You should put down Thermal Vias for the MOSFET.
                                        Is the copper plane as heatsink for the MOSFET large enough for it to handle 20A or are you going to use heatsink to keep MOSFET junction at safe temperature?
                                        Also consider VIA Stitching for high current.
                                        https://www.microtype.io/high-power-...n-tips-tricks/
                                        • eccerr0r
                                          Solder Sloth
                                          • Nov 2012
                                          • 8690
                                          Yeah I thought the initial version should work, but variations in the components used (specifically, leakage in the S9014/PN2222/... BJT is suspect) in the breadboard seems to make it fail. The later versions with active drive should compensate for non-ideal components.
                                          • alro7779
                                            MOSFET? Is its voltage reading normal?
                                            by alro7779
                                            Hello, guys!
                                            Got this 8-pin MOSFET (I presume) on the motherboard that I'm still trying to repair (HP Stream 11-ah117wm DAY0HGMB6C1 REV:C), close to the DC IN connector, and when I read voltage on Drain (5-8 pins) and Source (1-3 pins), I got the 19.81 VDC of the DC IN on each, but on the Gate (pin 4) it's 25 VDC. Is it normal? Now, I'm not quite sure the component is a MOSFET, but it looks like, and since it has the printed code on it totally unreadable, I can't try to find the datasheet. Can anyone give me a hand on this? Or maybe ff there's some MOSFET tutorial or something that you can...
                                            06-19-2025, 08:19 AM
                                            ISL6556ACB ISL6556ACBZ ISL6556ACR ISL6556ACRZ PWM Controller Datasheet
                                            Optimized Multi-Phase PWM Controller
                                            with 6-Bit DAC for VR10.X Application
                                            The ISL6556A controls microprocessor core voltage
                                            regulation by driving up to 4 synchronous-rectified buck
                                            channels in parallel. Multi-phase buck converter architecture
                                            uses interleaved timing to multiply channel ripple frequency
                                            and reduce input and output ripple currents. Lower ripple
                                            results in fewer components, lower component cost, reduced
                                            power dissipation, and smaller implementation...
                                            11-05-2024, 03:10 PM
                                          • bendeg
                                            Test circuit for curiosity : 2 x NE555 (astable + PWM) + n-mosfet + var 10k + pc fan
                                            by bendeg
                                            Hi reader,
                                            I'm trying to control a pc fan speed by giving PWM to the gate of a n-mosfet.
                                            1) generation of a clock with a 555 timer (~ 1,5 kHz, as seen in the datasheet, fig.12) (Vcc = 6V).
                                            Output to TRIG of second timer (pin 2) + red led
                                            2) generation of a PWM with a second 555 timer (as seen in the datasheet, fig.18), CONT (pin 5) modulated by a variable 10k resistor (Vcc)
                                            3) Using output of second timer to "pulse" n-mosfet gate (MDP13N50) + yellow led
                                            4) pc fan (12V, 0.18A) in series in drain-source of...
                                            05-01-2023, 07:59 AM
                                          • wrobbie
                                            Lenovo T14 (AMD, gen1) over-voltage protection IC keeps dying.
                                            by wrobbie
                                            My T14's (NM-C801) main USBC input keeps failing every few months. Initially, it worked fine for several years. The symptom is that once powered from the main USBC port using a 65W power brick, after some time (minutes, hours) charging will fail completely. Powering from the secondary (docking) USBC input still works. This laptop is basically always plugged in. The first time it happened, it took me a long time to find that the FPF2281 over-voltage IC for that USBC input was at fault. When the issue occurs, it will continuously reset power delivery negotiations with the power brick -- according...
                                            02-26-2025, 10:02 PM
                                          • someonenotyou
                                            SY8003 instead of SY8003A
                                            by someonenotyou
                                            Hi.
                                            I have a Lenovo HLS1C_HLS1D LA-L502P board with bad SY8003A DC/DC converter.
                                            I have a different mother board witch contains SY8003 DC/DC converter.
                                            Can I use SY8003 instead of SY8003A converter?
                                            These are the differences -
                                            • Short Circuit Protection:
                                              • SY8003: Uses latch-off protection. This means that when a short circuit is detected, the device will shut down and remain off until it is manually reset.
                                              • SY8003A: Uses hiccup mode protection. In this mode, the device will repeatedly attempt to restart after a short circuit is detected. If the short
                                            03-05-2025, 07:54 AM
