I am looking to buy at least up to a 30 watt engraving laser ( to use on a 3D printer format )
( 24 volt format preferred will use 12 volt format )
I looking for recommendations for a good laser head ( with heat sink ) with PWM control ( PWM controller separate from the laser is preferred ) I have googled this to find as much information as I can but what I can not find is good recommendations for just any brand
I do have the circuit for the interface to the 3D printer controller board for the PWM output for the input to laser ( optic sensor circuit ) which I have to make this circuit board
Now for the buck converter for the laser 24 volt to 12 volt
I not sure what type to use because I saw where someone has used one but you had to hook up the buck converter a special way for it to work correctly
I looking to spend up to $200.00 ( I would consider spending more if it for quality reasons )
Does anyone who visits this forum can give me some recommendations on a good quality laser product and where to buy it
24 volt laser head with heat sink ( 24 volts so I do not have use a buck converter)
PWM interface ( 0 to 5 volts ) ( PWM controller board separate from the laser head preferred )
30 watt maximum output ( range of wattage I am looking for 10 to 30 watt )
High quality ( this is a must requirement if possible )
I would like be able to use PayPal to pay for this purchase if preferably possible
Thanks for any input anyone has about this subject
Still alive and well, thank you
