I am looking for a transformer secondary of 60 volts @ 30 amp
    • Jul 2011
    • 6040
    The primary voltage is 480 single phase the second voltage needed is 60 volts
    Now it could be 30 volts 0 volts 30 volts preferred
    Or it could be 60 volts 0 volts 60 volts and just use one side of
    Output amp need to be at least 30
    Dose anyone know where I can find one
    This is what is the device I am working on
    The problem with this one is that it is over heating and smelling like it is over heating
    When it has a load on it
  • redwire
    • 3910
    Re: I am looking for a transformer secondary of 60 volts @ 30 amp
    Are you sure about your specs? 60VAC 30A output is 1,800VA and about a 45lb beast. That small transformer is probably overloaded and why it is stinking.
    1,500VA control transformers are common but standard secondary voltage (like Hammond HPS Imperator) is 24V or 90V.
    I thought you could undervolt a 600V (550/575V) transformer at 480V to get your voltage, but nothing around 48V or so.
    You show 60-0-60 but want 30V so I'm confused. What is this thing powering.
      Waht is the VA rating of that transformer as printed on the tag.
        • Jul 2011
        • 6040
        Only half of the winding is being used so it is 60 volts
        The device it is hook to it was drawing 23 amps DC
        So if you have a transformer secondary that has 30 volts 0 volts 30 volts then you would have 60 volts
          • 31063
          this is probably a good application for a switching psu!
            • Jul 2011
            • 6040
            Maybe but here is a concern it powering a brake coil
            Here is the other concern how many amp is going to be on the 120 volts side
            Where do I find a 60 volt switching power supply
              • 31063
              120v?
              i thought you said 480v
              if you want to drop 120v to 60v just put it through a diode to half the phase and then put a big cap on it
              • redwire
                • 3910
                Is the brake (current) the same as always? I have seen brake solenoids fail with shorted turns, which causes current to go way high. 1.4kW is a huge brake!
                At 23A and 60V whatever is switching that is under a lot of stress.
                There are 60VDC 20A SMPS https://www.aliexpress.com/item/4000402859916.html
                It might be better to use more than PSU in parallel for safety, if the brake operation is critical. SMPS won't last as long as iron.
                  What is rectification scheme?
                  • mikey5791
                    Is it possible for transformer substitution?
                    by mikey5791
                    Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                    Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                    My questions are
                    1. How do i test to see if the transformer is in good working condition?
                    2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                    Hope you guys understand what i was asking. My intention is...
                    11-03-2022, 02:11 AM
                    ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) Book Specification for Upgrade or Repair
                    This specification for the ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T101HA - X5DHD boardview and T101HA - X5DHD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                    09-06-2024, 04:40 PM
                    ASUS Transformer T304UA-P71SP-CA Hybrid (2-in-1) Pro Specification for Upgrade or Repair
                    This specification for the ASUS Transformer T304UA-P71SP-CA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T304UA-P71SP-CA boardview and T304UA-P71SP-CA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                    09-06-2024, 12:00 PM
                    ASUS Transformer T304UA-GN042T Hybrid (2-in-1) Pro Specification for Upgrade or Repair
                    This specification for the ASUS Transformer T304UA-GN042T Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T304UA-GN042T boardview and T304UA-GN042T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                    09-06-2024, 11:50 AM
                    ASUS Transformer T304UA Hybrid (2-in-1) Pro Specification for Upgrade or Repair
                    This specification for the ASUS Transformer T304UA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T304UA boardview and T304UA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ASUS...
