Some one posted a comment about modifying some G code for some kind of heater setup
    • Jul 2011
    • 6038
    I have tried to find this post but with no luck
    Can anyone help me find it
  • clearchris
    • Dec 2013
    • 687
    Re: Some one posted a comment about modifying some G code for some kind of heater set
    That's me! What do you need?
    https://www.badcaps.net/forum/showthread.php?t=83344
      • Jul 2011
      • 6038
      Originally posted by clearchris
      How do you program in gcode is this something that is easy to do or is it something that is difficult to do and learn
      “ I reprogrammed the gcode to get a better controlled slope where required and max output for when the required temp gain is closer to 1.4C/sec. Pretty happy with the slope. Near term I'm going to have to add at least a buzzer, longer term a stepper to open the door. “
      What I have in mind doing is use a Ender 3 controller board and use the heater extruder output and the heater bed output to control two heating beds or heating bed and a heater element ( at this point is just an idea but I want to see if concept is do able or not )
      For circuit board warmer that have many layers so removing components might be easier to remove
      Is there a way to 3D print letter and numbers if so what software do you use to create these items
      • clearchris
        • Dec 2013
        • 687
        Are you talking about using your 3d printer to pre-heat boards? I don't think those will get hot enough. And with the hot plates, you don't really need to do a profile, you just need tight temperature control (pid). You can do that with just an arduino, a thermistor and a heater. I have been meaning to put something like that together, I just haven't gotten my hands on a thick piece of aluminum yet. You could even pick up a cheap electric resistive stove and goodwill and rig it up with an SSR and a thick aluminum disc to spread the heat. It's not really worth the complexity of running klipper on a hotplate, because you really only need the PID control and one set point. You aren't doing trapezoidal reflows, etc.
        Do you have an arduino? You can pick them up for $3 or so, and there are plenty of libraries, including pid libraries that you can use.
        For adding text, which I really, really avoid doing because unless it's big, it doesn't print well, I use openscad. I haven't figured out how to do it in freecad yet. Here's an example or how to do a nametag in openscad (not mine). Openscad is more like a programming language than a cad software like freecad.
        https://www.thingiverse.com/thing:1026348/files
        • clearchris
          • Dec 2013
          • 687
          Also, chinese pid controllers are really cheap now, you can pick one up for $10-15. Really not bad, comes with an LCD display and controlls too. Almost not worth building your own unless it's for fun.
          https://www.ebay.com/sch/i.html?_sac...roller&_sop=15
          If you go this route, make sure the thermocouple is the right kind for the controller.
