Anyone recognize this power supply?
  • Cartel
    • Feb 2006
    • 112
    Its 13.8v and unknown amps, 100?
    There is no name and it has 5 identical modules in it.
    Dont know where else to ask.
    thanks
    • Jul 2011
    • 6039
    Re: Anyone recognize this power supply?
    It could be a forklift battery charger would be a good guess
    But very old model is my guess
    I would test each module by it self just make sure pay attention to how it is hook each other
    I would expect that to start the charging cycle you probably have at least a minimum of 8 to 10 for it to start charging would be my guess
      • 31028
      not a forklift, the cells are in series - 48v or higher.
      it could be an early solid-state charger for garages though.
      • R_J
        • 9535
        It might be from a audio display system used in stores.
        • CapLeaker
          Leaking Member
          • 8158
          Naw... doesn't have big enough filter caps. Looks like it used to run a lot and someone knew how to fix it (a lot). The screw holes are worn, extra grounding lug...
          My guess, a commercial PSU, ran something in some sort of an transmitter site. Second thought: An shore charger for the battery bank on a boat?
            Any printing on the circuit boards at all?
            • PeteS in CA
              • Aug 2005
              • 3581
              • USA, Unsure of Planet
              I think I saw a 1989 date code on that silver-colored 85C 1000uF made by El Cap.
              PeteS in CA
              • petehall347
                • Jan 2015
                • 4426
                • United Kingdom
                strange coil on the output . and what looks like a motor cap .
                  by sam_sam_sam
                  03-31-2024, 02:12 PM
                • howardc64
                  by howardc64
                  Problem
                  08-04-2024, 10:36 PM
                • shamsudeen
                  Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                  by shamsudeen
                  Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                  I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                  i know that in linear power supply the noise will be very low comparing to SMPS supply....
                  07-19-2025, 07:14 AM
                • CMCM
                  Russound CA4 Power Supply Repair
                  by CMCM
                  Hello Everybody,
                  Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
                  Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
                  The outputs marked 12v and 20v are all measuring only 1v.
                  The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
                  The capacitors physically look clean (no bludgesor leaks) and...
                  07-03-2025, 01:12 PM
