Unknown Smd Diode probably.
  • Argirisarchi
    • Mar 2018
    • 8
    • Grecce
    i need help with a bad smd diode i have on a sony projector inverter.
    Watch the photo i attached.
    Thank you for your help.
  • R_J
    • 9579
    Re: Unknown Smd Diode probably.
    It might me a 28 volt TVS diode SMAJ28A marked "CG". If it checks shorted it will be bad, if it checks open it is liklely good.
    • Argirisarchi
      • Mar 2018
      • 8
      • Grecce
      Yes its bad. I checked it . How sure you are about the SMAj28A.
      The board i am fixing is very rare and the one i find has 150$ + import charges.
      • R_J
        • 9579
        It is hard to make out the exact letters but the logo seems to be for Tiawan Semiconductor I see the first letter is a "C" but is the second a "G" or could it be a "0" similar to this Ø ?
        When you say it is BAD do you mean it is shorted? where is it in the circuit? is it a diode that supplies a voltage from a tranformer or is it a protection diode across a supply voltage like a zener?
        You say it is in the inverter, I take it you mean the lamp inverter, correct?
        Maybe post a picture of the complete board (both sides) and the Model of the projector.
        It could also be a non standard or custom part number stamped on the diode for the inverter manufacture
        • Argirisarchi
          • Mar 2018
          • 8
          • Grecce
          Yes this diode its shorted. I attached the picture to see the circuit.
          The boards part number is 4h.1nt40.a02
          • Argirisarchi
            • Mar 2018
            • 8
            • Grecce
            So i replace the original diode with the SMAJ28A
            but i get no results.
            • badcappo
              Unknown diode specs V6 18
              by badcappo
              Hi there, looking for a compatible replacement for a diode type labelled "V6 18" from a dead Panasonic plasma TV power source. Possibly a V6 600 volts diode as seen here: https://electronics.stackexchange.co...nt-diode-v6-88 ?
              Thank you ...
              03-09-2025, 07:13 AM
            • Vincenzo2
              Element 32 inches tv (ELEFW328B) Unknown component: Diode or zener?
              by Vincenzo2
              My Element 32 inches tv (ELEFW328B) lost it's backlight (confirmed with a flashlight test) and the connector on the PCB (it has one board that has a processor chip, switch mode power supply, and backlight circuit) that has the two wires that go to the backlight LED strips has a very low voltage (28-29 volts) when turned ON, in my opinion.
              Started testing components and found an SMD diode or zener that is shorted (even zero fusing resistors read a few tens of milliohms, while this thing reads zero).
              I put some pictures here to show that it is labeled "M7"....
              09-07-2023, 07:43 PM
            • yurik_avs
              Power supply ADP-300ER Zener diode parameters unknown
              by yurik_avs
              Guys, I have a question about the ADP-300ER power supply. While the spare parts I ordered are on their way, I decided to once again check the piping chains of the burnt mikruh. I found the zener diode in a break, so apparently I didn't detect it right away. His positioner is ZD41. Can anyone tell me its voltage? It is located in the harness of the IC41 NCP1612A3 microcircuit
              Here is an extract from the datasheet for this chip. This pin is grounded until the PFC output reaches its nominal level. It is also grounded if
              NCP1612 detects a fault. The rest of the time, i.e. when the PFC...
              12-12-2023, 05:32 AM
              Lenovo ThinkPad P51s + ThinkPad Stack Mobile Projector Mobile workstation P Specification for Upgrade or Repair
              This specification for the Lenovo ThinkPad P51s + ThinkPad Stack Mobile Projector Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P51s + ThinkPad Stack Mobile Projector boardview and P51s + ThinkPad Stack Mobile Projector schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum....
              09-06-2024, 06:11 AM
            • asr
              Finding replacement diode iPad Pro 3rd gen A1701
              by asr
              Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
              Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
              07-09-2024, 06:24 PM
