Is Altium the best pcb design software or is there better?
Zero to Expert in pcb design
Tags: None
Re: Zero to Expert in pcb design
Depends on your needs. For some niches some tools are better than others.
For simple boards, KiCad, DipTrace, even Eagle could be good enough.
For more complex stuff, there's other players in the market like Zuken (Sony likes them) or PADS from Mentor, or Orcad ... -
I want a program that will auto check my design for mistakes in my selection of components and design, is there anything out there that does that?Comment
No, I'm afraid you'll actually have to do some work.
Nothing will auto-check a design beyond the wiring (netlist) and some basic spacings and clearance.
PCB CAD programs are all very basic. Every component footprint you have to check and verify yourself unless you can afford expensive third-party libraries. Knowing how to route traces for high speed, to avoid noise and EMC, you learn the hard way. A few books are on PCB design but the CAD programs are still quite stupid and don't have AI yet.Comment
bit of advice,
pick the software that has the largest component library - preferably with the ability to add user/3rd party library's
i use eaglecad for that reason.
version 7.7 - the last version before it got raped in the ass by the AutoDesk takeover!!Comment
How complex is the board that you are trying to design?
Altium is not cheap.Never stop learning
Originally posted by redwireKnowing how to route traces for high speed, to avoid noise and EMC, you learn the hard way.
Originally posted by stjpick the software that has the largest component library - preferably with the ability to add user/3rd party library's
If you're just doing one or two boards, pick "whatever is cheapest" -- or, farm it out to a service bureau. Only make the investment in the tool if this is a skill you want/NEED to develop and think you will have an ongoing set of future projects to justify the cost/investment you'll be making.
[I deliberately hold off hardware designs and board layouts until I have several that need to be done. Clustering them, like this, lets me amortize the RE-learning required (to get back up to speed with the tools) over multiple designs. Otherwise, you spend a lot of time trying to remember the quirks of each particular tool -- only to forget it, again, before you get around to the next design.]
[[ALL EDA packages have bugs. Familiarity with your package (from actual USE) helps you remember which "wacky behaviors" are the result of YOU doing something incorrectly vs. the tool screwing up ("known bug")]]Last edited by Curious.George; 07-04-2019, 05:39 PM.Comment
I kinda like Mentor Graphics PADS almost as well as Altrium. Proteus also has a lot to offer.Comment
You have to decide what you want from the package. If you just want to layout some boards (and don't care about back annotating the schematic, etc.), then you have lots more choices than if you're trying to put together a whole package for Manufacturing.
My designs tend to be more complex and dense (6-8 layer padstack, components on both sides of the board, schematic sliced into several tiny boards which are "folder" together, etc.). So, I need the tools to handle lots of details that I could easily overlook.
For example, when the second "pane" of the board is folded behind the first, will any components on the BACK of the first pane mechanically interfere with components on the back of the second pane?Comment
Humm, Diptrace Full is only $995....I wonder if its Schemat Capture allows users to take a picture of any board and it will produce a likely pcb with components....? Is there anything out there with this capability? I like OrCad's licencing to VM, so I can take it anywhere.Last edited by captainKKK; 07-05-2019, 09:15 AM.Comment
Nobody does that, because nothing's smart enough to automatically figure out the number of layers a PCB has, and x-ray capability to figure out traces within internal layers.
Also, big components like transformers or inductors or even electrolytic capacitors can hide traces under their footprints making traces undetectable.Comment
You mean smart enough yet.....
How long do you think a chinese expert would take to conceive a new computer motherboard design and take it from design to production?
Did you know, Intel has a free tool called Embedded Board Planner? Through a web interface, you can for example design your own Intel Atom based processor board....https://www.fedevel.com/welldoneblog...6-motherboard/Last edited by captainKKK; 07-05-2019, 07:28 PM.Comment
(This is where having LOTS of display real estate pays off! Open schematic on one monitor, layout on another and have a third/fourth to call up datasheets for specific components on the board)
This is 100 times better than tracing foils by eye. But, still increibly labor intensive! What it really buys you is some reassurance that you haven't confused yourself (again!) when you flipped the board over to see where a signal at a particular feedthru continues along...Comment
Without resorting to building a custom, one-off test fixture of pogo pins to electrically probe the (depopulated) PCB, can you tell me another method of doing that -- other than what I've described?? :>
Or, do you think manually probing every combination of pin-pairs with for continuity is a RELIABLE way of doing this?Comment
You must have great digital dexterity and eyesight to hold probes on SMT pads without them slipping off and touching a neighboring pad (which would give you "bad data").
I trust the machine to get those things right so I don't have to waste my time (and risk inaccuracies in the result).Comment
This specification for the HP EliteBook 840 G5 + LaCie Porsche Design USB 3.0 1TB Mobile Drive Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G5 + LaCie Porsche Design USB 3.0 1TB Mobile Drive boardview and 840 G5 + LaCie Porsche Design USB 3.0 1TB Mobile Drive schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users...09-06-2024, 08:50 AM
This specification for the HP ProBook 650 G4 + LaCie Porsche Design USB 3.0 1TB Mobile Drive Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 650 G4 + LaCie Porsche Design USB 3.0 1TB Mobile Drive boardview and 650 G4 + LaCie Porsche Design USB 3.0 1TB Mobile Drive schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly...09-06-2024, 08:50 AM
This specification for the HP ProBook 640 G4 + LaCie Porsche Design USB 3.0 1TB Mobile Drive Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 640 G4 + LaCie Porsche Design USB 3.0 1TB Mobile Drive boardview and 640 G4 + LaCie Porsche Design USB 3.0 1TB Mobile Drive schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly...09-06-2024, 08:50 AM
This specification for the HP ProBook 450 G5 + LaCie Porsche Design USB 3.0 1TB Mobile Drive Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G5 + LaCie Porsche Design USB 3.0 1TB Mobile Drive boardview and 450 G5 + LaCie Porsche Design USB 3.0 1TB Mobile Drive schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly...09-06-2024, 08:50 AM
- Loading...
